I was able to solve my nfs mount issue using USB - I don’t know how common this is but it may be helpful to others. Thanks to recalcati for help … (original email account was (rfine@tiac.net) - changed to richatnstar@yahoo.com)
Restatement of issue …
- Host is Dell Inspiron laptop (1200) w/Slackware 12.1; USB connection
between host and beagle board. - I created an SD with latest uboot/x-loader/uImage etc
from http://www.angstrom-distribution.org/demo/beagleboard/
a. uboot arguments modified to boot via NFS
b. Installed RFS from …/beagleboard/ site on host
c. Successfully booted bb and mounted to PC … (Linux version
2.6.28-omap1 (koen@dominion))
- On the host, I use “sudo /sbin/ifconfig usb0 192.168.0.1” when
the bb attempts to mount
d. I was able to log in & access NFS ok …
- Installed source for 2.6.29-rc8 & succesfully built kernel … no
changes to configuration.
a. Followed steps …
- make distclean
- make omap3_beagle_defconfig
- make uImage
b. copied image to SD - no change to uboot arguments
c. kernel boots OK but does not mount
- To double check … I installed another kernel source tree for
2.6.22; built the kernel etc that version mounted OK too
As recalcati stated in a response, the issue was configuration related - it took a while to sort out the required mods. I made these changes to the kernel configuration (‘make menuconfig’)
- Kernel hacking/Debug filesystem
[ENABLE] - probably not needed but handy while debugging - Device Drivers/USBSupport/USB Host Controller
[ENABLE] EHCI HCD - Device Drivers/USBSupport/USB Gadget Support
[Y] Gadget Drivers (was [M])
Possibly my RFS was missing Gadget Driver module which forced (3.) Kernel change?
Here’s the .CONFIG diff … between ‘omap3_beagle_defconfig’ (Mar 30 is UPDATED with changes)
4c4
< # Mon Mar 30 07:28:51 2009
