No audio out in Ubuntu 10.10 (BB C3)
Ive got BB C3. I have succesfully ported Ubuntu 10.10 as per the gidelines from http://elinux.org/BeagleBoardUbuntu and also installed xfce desktop manager with gdm.
Everything runs fine except the audio. Actually the volume adjust bar is also being shown but no sound output.
Please help me out.
try using at least 2.6.37-x0:
http://rcn-ee.net/deb/maverick/v2.6.37-x0/linux-image-2.6.37-x0_1.0maverick_armel.deb
Hello again,
I'm having trouble compiling iwconfig. I run this "make CC=arm-none-linux-gnueabi-gcc -lm" command and get
"arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -fPIC -c -o iwlib.so iwlib.c
arm-none-linux-gnueabi-gcc -shared -o libiw.so.29 -Wl,-soname,libiw.so.29 -lm -lc iwlib.so
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -c iwconfig.c
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -o iwconfig iwconfig.o libiw.so.29 -lm
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -c iwlist.c
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -o iwlist iwlist.o libiw.so.29 -lm
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -c iwpriv.c
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -o iwpriv iwpriv.o libiw.so.29 -lm
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -c iwspy.c
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -o iwspy iwspy.o libiw.so.29 -lm
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -c iwgetid.c
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -o iwgetid iwgetid.o libiw.so.29 -lm
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -c iwevent.c
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -o iwevent iwevent.o libiw.so.29 -lm
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -c ifrename.c
arm-none-linux-gnueabi-gcc -Os -W -Wall -Wstrict-prototypes -Wmissing-prototypes -Wshadow -Wpointer-arith -Wcast-qual -Winline -I. -MMD -o ifrename ifrename.o libiw.so.29 -lm"
when I compile it. The result does not run properly(surprise) on my BBXM. Can anyone point out what I am doing wrong?
David
Actually for fixed audio on the xM use 2.6.37-x2 as 'x0' can fail on
some mmc cards.. (error -110).. It has Steve's mmc fix..
script:
http://rcn-ee.net/deb/maverick/v2.6.37-x2/install-me.sh
deb:
http://rcn-ee.net/deb/maverick/v2.6.37-x2/linux-image-2.6.37-x2_1.0maverick_armel.deb
and remember to change ttyS2 to ttyO2 in your bootarg's..
or just wait till this weekend, i'm currently testing new images for
lucid/maverick/natty with this new kernel..
fromhttp://elinux.org/BeagleBoardUbuntuand also installed xfce desktop
manager with gdm.
Just noticed this is the C3, audio should work out of the box, try
muting/unmuting the audio in the volume bar..
It should work, something's oddly configured..
On C3, boot hangs here.
check for /etc/init/ttyO2.conf file.
There is a tty2.conf which I copied to tty02.conf and changed to read
Which is really odd, since i was testing that exact kernel yesterday
in maverick on my xM.. 2.6.38-rc3-d1 had broken sgx drivers, so my fix
was 2.6.38-rc3-d2...
Sid, did you build it yourself? Which userspace are you using?
I'll build up the same image again this morning, with a c4 board..
Hi Sid,
Here's what i'm getting: (boots fine)
http://pastebin.com/2ywLvscU
with:
setenv dvimode 1280x720MR-16@60
setenv vram 12MB
setenv bootcmd 'mmc init; fatload mmc 0:1 0x80300000 uImage; bootm 0x80300000'
setenv bootargs console=ttyO2,115200n8 console=tty0
root=/dev/mmcblk0p2 rootwait ro vram=${vram}
omapfb.mode=dvi:${dvimode} fixrtc buddy=${buddy} mpurate=${mpurate}
It's the one from rcn-ee.net/deb/natty/v2.6.38-rc3-d1, I used install-me.sh.
Regards
Sid.
Why do do you want to compile it? Both angstrom and ubuntu provide it.
Same problem with v2.6.38-rc3-d2.
Regards
Sid.
natty userspace with natty v2.6.38-rc3-d2 on my c4..
http://pastebin.com/AuT7Uz9J
i just can't replicate why your's doesn't boot..
setenv vram 12MB
Progress.
I checked the SDHC but didn't find -d2 in /boot, so I set up bootargs to be the same as in your email ran install-me.sh again and rebooted.
I have everything working in Gnome, but the serial console doesn't come up to the login prompt, may be because of the double define in bootargs of console=tty02 and console=tty0.
[ 4.990509] fbcvt: 1280x720@60: CVT Name - .921M9-R
[ 5.017761] hub 1-2:1.0: USB hub found
[ 5.017883] hub 1-2:1.0: 7 ports detected
[ 5.022033] Console: switching to colour frame buffer device 160x45
[ 5.050598] regulator_init_complete: VDAC: incomplete constraints, leaving on
[ 5.058776] md: Waiting for all devices to be available before autodetect
[ 5.066223] md: If you don't use raid, use raid=noautodetect
[ 5.073791] md: Autodetecting RAID arrays.
[ 5.078277] md: Scanned 0 and added 0 devices.
[ 5.083190] md: autorun ...
[ 5.086273] md: ... autorun DONE.
[ 5.090454] Waiting for root device /dev/mmcblk0p2...
[ 5.104217] mmc0: new high speed SDHC card at address 390d
[ 5.114166] mmcblk0: mmc0:390d SD16G 14.9 GiB
[ 5.125427] mmcblk0: p1 p2
[ 5.205383] EXT3-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
[ 5.219909] EXT2-fs (mmcblk0p2): error: couldn't mount because of unsupported optional features (240)
[ 5.242004] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 5.254547] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 5.275390] devtmpfs: mounted
[ 5.282196] Freeing init memory: 312K
[ 5.313690] usb 1-2.2: new full speed USB device using ehci-omap and address 3
[ 5.524749] usb 1-2.3: new high speed USB device using ehci-omap and address 4
[ 5.751159] usb 1-2.4: new low speed USB device using ehci-omap and address 5
[ 6.134155] usb 1-2.5: new low speed USB device using ehci-omap and address 6
[ 24.632568] pegasus 1-2.3:1.0: eth0: update_eth_regs_async, status -22
[ 26.502288] pegasus 1-2.3:1.0: eth0: update_eth_regs_async, status -22
ssh sessions work though.
# ssh -X beagleboard
root@beagleboard's password:
Welcome to Ubuntu natty (development branch) (GNU/Linux 2.6.38-rc3-d2 armv7l)
  * Documentation: https://help.ubuntu.com/
59 packages can be updated.
0 updates are security updates.
Last login: Fri Feb 4 15:32:20 2011
-bash: alias: need: not found
-bash: alias: to: not found
-bash: alias: enable: not found
root@G3VBV_BB_C3:~# ls /boot/uboot
boot.cmd boot.ini boot.scr MLO tools u-boot.bin uImage uImage_new uImage_old uInitrd uInitrd_new uInitrd_old user.cmd user.scr
root@G3VBV_BB_C3:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/mmcblk0p2 15338304 5692804 8866348 40% /
devtmpfs 115708 564 115144 1% /dev
none 115864 24 115840 1% /dev/shm
none 115864 132 115732 1% /var/run
none 115864 0 115864 0% /var/lock
/dev/mmcblk0p1 72098 23836 48262 34% /boot/uboot
root@G3VBV_BB_C3:~#
Thanks & Regards
Sid.
Sweet it works...
to get serial console back:
you need a "/etc/init/ttyO2.conf" in ubuntu
I put the important bits here:
http://elinux.org/BeagleBoardUbuntu#Omap_Serial_Changes
It's there
Yeah, I figured that out about 10 minutes after posting…
opkg install wireless-tools
I was wondering if it is possible to use a d-link DWA-125 usb wifi adaptor with angstrom?
I managed to get my airlink AWLL3026 to work by “opkg install zd1211-firmware”(works 100%). I tried finding a driver with the search term “firmware” but could not find anything suitable. Suggestions? The underlying issue is I can’t find AWLL3026’s in local stores any more and need to diversify. I’ve got a couple of the D-links and was hoping to get them working. Thanks David On 11-02-04 01:18 AM, Koen Kooi wrote:
