I connected a serial console to the onboard uart because I kept getting the dreaded all flashing leds thing on a fresh install of the latest debian image.
It appears the Black is running out of space on /dev/mccblk1p1 with the following error:
Copying: /dev/mmcblk0p1 → /dev/mmcblk1p1
[ 52.056816] EXT4-fs (mmcblk1p1): mounted filesystem with ordered data mode. Opts: (null)
rsync: / → /tmp/rootfs/
rsync: write failed on “/tmp/rootfs/usr/lib/ruby/vendor_ruby/sequel/adapters/db2.rb”: No space left on device (28)
rsync error: error in file IO (code 11) at receiver.c(393) [receiver=3.1.1]
writing to [/dev/mmcblk1] failed…
Are you flashing a "4GB" image onto a "2GB" device?
Do you have to select the console version or go to an older image. " Debian 8.3 2016-02-11 2GB SD console "
The only others seem to be older versions.
Dave
Tried bone-debian-8.5-lxqt-2gb-armhf-2016-07-18-2gb.img.xz and it’s been stuck on the Cylon Leds for over and hour with the following being the last message on the console:
sfdisk: If you created or changed a DOS partition, /dev/foo7, say, then use dd(1)
to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1
(See fdisk(8).)
mkfs.ext4 /dev/mmcblk1p1 -L rootfs
mke2fs 1.42.12 (29-Aug-2014)
[ 41.059058] Unable to handle kernel NULL pointer dereference at virtual address 00000008
[ 41.067332] pgd = c0004000
[ 41.070081] [00000008] *pgd=00000000
[ 41.073716] Internal error: Oops: 17 [#1] SMP THUMB2
[ 41.078715] Modules linked in:
[ 41.081804] CPU: 0 PID: 127 Comm: mmcqd/1 Not tainted 4.4.15-ti-r36 #1
[ 41.088372] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 41.094504] task: dc121a00 ti: dc01e000 task.ti: dc01e000
[ 41.099954] PC is at set_data_timeout+0x8e/0xf0
[ 41.104517] LR is at set_data_timeout+0x4b/0xf0
[ 41.109079] pc : [] lr : [] psr: 20070033
[ 41.109079] sp : dc01fd78 ip : 00000000 fp : fa1d8100
[ 41.120634] r10: dcf4b340 r9 : 00000000 r8 : dcf4b000
[ 41.125893] r7 : ebc20000 r6 : 000c0087 r5 : 00000000 r4 : 000f0000
[ 41.132460] r3 : 00000004 r2 : 0000000f r1 : 00000001 r0 : bc9b3330
[ 41.139030] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment none
[ 41.146394] Control: 50c5387d Table: 9cff0019 DAC: 00000051
[ 41.152178] Process mmcqd/1 (pid: 127, stack limit = 0xdc01e218)
[ 41.158222] Stack: (0xdc01fd78 to 0xdc020000)
[ 41.162610] fd60: ebc20000 dcf4b000
[ 41.170852] fd80: 05f5c800 dc01fe5c dc01fe4c c0b59a88 c0b59a88 c0c352d0 00000000 c05a8c51
[ 41.179093] fda0: dc01fe5c dc01fe60 c0b59a88 dcf4b340 dc01e000 00000000 dc01fde8 dc8ba60f
[ 41.187333] fdc0: dc01fe5c dc01fe60 c0b59a88 c06dd347 00000002 dc01fe5c dc01fe60 dc8ba60f
[ 41.195574] fde0: 00000001 dc01fe4c dcf4b000 dc01fe5c 00000000 00000001 c0b59a88 c0c352d0
[ 41.203815] fe00: 00000001 c0596e37 00000000 c0c352d0 dc01fe5c 00000000 dc01fe4c dcf4b000
[ 41.212056] fe20: dc01fe5c 00000000 00000001 c0b59a88 00000000 c0596f83 dc01fe90 c0b59a88
[ 41.220297] fe40: dcf4b000 c0597421 dc08dc00 00000000 dc01fe90 00000000 00000000 00000000
[ 41.228538] fe60: 00000000 dc01fe64 dc01fe64 c0596f39 00000000 dc8ba60f 00100000 dcfdd000
[ 41.236779] fe80: 00000020 010ffe00 00100000 c059819f 00000026 00000001 00000000 00000000
[ 41.245020] fea0: 00000000 00000000 0000049d 00000000 00000000 0000c800 00000000 00000000
[ 41.253262] fec0: dc01fe4c dc8ba60f 8f3b4800 dcfdd000 dc0b1c08 dc1a7a50 24590081 dcfdd000
[ 41.261502] fee0: dc0b1c00 00008000 00000001 c05a3f7b dc1a7a50 00000000 00000800 00000000
[ 41.269743] ff00: 24590000 00000001 dc0b1c10 dc0b1c08 dc110568 dc01e000 00000000 24590081
[ 41.277984] ff20: 00000001 dc0b1c10 c0b59a88 c05a525b dd8efccc 00000000 dc01e000 dc8ba60f
[ 41.286226] ff40: dc01ff58 00000000 dcff5180 dc0b1c08 c05a51bd 00000000 00000000 00000000
[ 41.294467] ff60: 00000000 c004840b 00000000 00000800 dc0b1c08 00000000 00000000 dc01ff7c
[ 41.302708] ff80: dc01ff7c 00000000 00000000 dc01ff8c dc01ff8c dc8ba60f 00000000 dcff5180
[ 41.310948] ffa0: c004835d 00000000 00000000 c000ed15 00000000 00000000 00000000 00000000
[ 41.319189] ffc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 41.327430] ffe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 41.335688] [] (set_data_timeout) from [] (omap_hsmmc_request+0x475/0x4a8)
[ 41.344381] [] (omap_hsmmc_request) from [] (mmc_start_request+0xcb/0x1b0)
[ 41.353064] [] (mmc_start_request) from [] (__mmc_start_req+0x3f/0x50)
[ 41.361396] [] (__mmc_start_req) from [] (mmc_wait_for_cmd+0x59/0x84)
[ 41.369640] [] (mmc_wait_for_cmd) from [] (mmc_do_erase+0xf3/0x280)
[ 41.377708] [] (mmc_do_erase) from [] (mmc_blk_issue_rq+0x31b/0x36c)
[ 41.385863] [] (mmc_blk_issue_rq) from [] (mmc_queue_thread+0x9f/0x148)
[ 41.394285] [] (mmc_queue_thread) from [] (kthread+0xaf/0xc4)
[ 41.401838] [] (kthread) from [] (ret_from_fork+0x11/0x1c)
[ 41.409123] Code: 2a0e ea4f 4402 d921 (f8d9) 3008
[ 41.413995] —[ end trace 724fa7e6e10a23cb ]—
I am using a bench power supply which is capable of 6 amps at 5v, but it’s only drawing 350ma. So it can’t be improper power. Nothing else except the serial console is connected.
Thoughts?
FYI: I loaded Ubuntu and it worked fine. Using this image:
[https://rcn-ee.com/rootfs/2016-06-09/flasher/BBB-eMMC-flasher-ubuntu-16.04-console-armhf-2016-06-09-2gb.img.xz](https://rcn-ee.com/rootfs/2016-06-09/flasher/BBB-eMMC-flasher-ubuntu-16.04-console-armhf-2016-06-09-2gb.img.xz)
Think it could just be the way the init-eMMC-flasher-v3.sh is written. I guess I will go with that for now and keep an eye on Debian.
