Node builds without error, then crashes with Seg. fault. Build settings correct?
On my BeagleBoardXM Rev-c, Ubuntu 12.10, I’m trying to build NodeJS v0.10.0 using info found here:
https://groups.google.com/d/msg/beagleboard/T5_lVo0Ngn4/IeMZFIVNWj8J
“./configure”, “make”, and “make install” run without error, but when I try to run “node” or “npm”, I get a Segmentation fault.
Running ./configure generates the settings below. armv7 looks correct, does arm_fpu or some other setting look awry to anybody else?
{ ‘target_defaults’: { ‘cflags’: [],
‘default_configuration’: ‘Release’,
‘defines’: [],
‘include_dirs’: [],
‘libraries’: []},
‘variables’: { ‘arm_fpu’: ‘vfpv3’,
‘arm_neon’: 0,
‘armv7’: 1,
‘clang’: 0,
‘gcc_version’: 47,
‘host_arch’: ‘arm’,
‘node_install_npm’: ‘true’,
‘node_prefix’: ‘’,
‘node_shared_cares’: ‘false’,
‘node_shared_http_parser’: ‘false’,
‘node_shared_libuv’: ‘false’,
‘node_shared_openssl’: ‘false’,
‘node_shared_v8’: ‘false’,
‘node_shared_zlib’: ‘false’,
‘node_tag’: ‘’,
‘node_unsafe_optimizations’: 0,
‘node_use_dtrace’: ‘false’,
‘node_use_etw’: ‘false’,
‘node_use_openssl’: ‘true’,
‘node_use_perfctr’: ‘false’,
‘node_use_systemtap’: ‘false’,
‘python’: ‘/usr/bin/python’,
‘target_arch’: ‘arm’,
‘v8_enable_gdbjit’: 0,
‘v8_no_strict_aliasing’: 1,
‘v8_use_arm_eabi_hardfloat’: ‘true’,
‘v8_use_snapshot’: ‘true’}}
It looks like this might actually be a V8 issue. I was able to get Node to build by building a slightly earlier version.
Check out Node from their git repo:
git clone git://github.com/joyent/node.git
cd into the new directory:
cd node
Checkout the earlier version:
git checkout v0.8.22
Build:
./configure make sudo make install
Node now works (for me) without the segmentation fault.
Arch Linux Arm (currently) has node 0.10.2 which works fine. Maybe check how they compiled it
http://archlinuxarm.org/
https://github.com/archlinuxarm/PKGBUILDs/blob/master/community/nodejs/PKGBUILD
