node usb can't claim interface on OSX
Hi jkridner,
As I can see in BBBlfs code for OSX, a codeless kext is written to claim the interface first before the kernel driver binds it. Can we just write c code to implement the kext and claim the interface and then allow node-usb to claim the interface through node.js server ? Can you test this ?
Also do checkout these workarounds for node-usb on OSX first at https://github.com/tessel/node-usb/issues/61
Ravi Kumar Prasad (ravikp7)
Hi jkridner,
If you give me the code, I will build and run it.
I am pretty sure I avoided the kernel grabbing it, but not 100% sure. If a kext is required, please provide.
If we have a working C module that is portable, we can simply write a node module to be able to add it to etcher.io and other tools via npm.
Can you break down specifics for me to try in the email threads?
Hi jkridner,
I’ll try and extract it from BBBlfs OSX code and give it as a c module.
Sure, here’s first one Calling the semi-private __open() and __claimInterface() functions before the public open function seems to jiggle it into a position where it works.
this.open = function(callback) {
console.log(‘opening device’)
_device = usb.findByIds(0x132b, 0x2101);
_device.__open();
_device.__claimInterface(0);
_device.open();
_ifc = _device.interface();
_ifc.claim();
_wep = _ifc.endpoint(0x02);
_rep = _ifc.endpoint(0x82);
if (callback) callback(null, ‘OK’);
Second one,
added the following line in usb.js (line 26) in the open prototype after the this.__open() call (line 25):
    this.__claimInterface(0);
and it solved the issue.
Hi Jason,
This file .travis.yml at https://github.com/ungureanuvladvictor/BBBlfs/tree/osx describes how to build the codeless kext. Please give it a try now, I’ll prepare the timeline in proposal accordingly. If libusb can claim the interface in OSX then node-usb can too as it just binds libusb.
