I am trying to get a program to run at boot up by placing it in the Cloud9 auto run folder but it does not work properly.
My nodes version is 0.10.24
My Kernel version is : Linux beaglebone 3.8.13 #1 SMP Tue Jun 18 02:11:09 EDT 2013 armv7l GNU/Linux
The program runs in the cloud9 environment and from the command line /var/lib/cloud9/autorun node controlautorun
I could create a service that is called at boot time but I really would like to find the problem with the auto run system.
The program communicates serially with another device so I can see immediately if the serial data is being sent.
The first thing I did was to send the console log to a file. It is not written-to when the controlautorun is started by autorun. I believe controlautorun is started and stopped before opening the serial port here is a log from journalctl:
Jan 25 13:34:41 beaglebone bonescript-autorun[134]: info: change: controlautorun.js
Jan 25 13:34:41 beaglebone bonescript-autorun[134]: info: start: controlautorun.js
Jan 25 13:34:41 beaglebone bonescript-autorun[134]: info: stop: controlautorun.js
Jan 25 13:34:42 beaglebone bonescript-autorun[134]: info: start: controlautorun.js
also from PS the process id seems to change which is consistent with starting and stopping:
root@beaglebone:~# ps -aux | grep controlautorun
Warning: bad ps syntax, perhaps a bogus ‘-’? See http://procps.sf.net/faq.html
root 3393 0.0 0.1 1956 576 pts/0 S+ 14:07 0:00 grep controlautorun
root@beaglebone:~# ps -auxwww | grep controlautorun
root 3395 0.0 0.1 1956 576 pts/0 S+ 14:09 0:00 grep controlautorun
Here is the first few lines of controlautorun.js:
var app = require(‘http’).createServer(handler);
var io = require(’/usr/local/lib/node_modules/socket.io/lib/socket.io’).listen(app);
var fs = require(‘fs’);
var bb = require(‘bonescript’);
var SerialPort = require(“serialport”).SerialPort;
var serialPort = new SerialPort("/dev/ttyO1",{baudrate:115200}
, false);
// logging ===
var util = require(‘util’);
var log_file = fs.createWriteStream(__dirname + ‘/debug.log’, {flags : ‘a’});
var log_stdout = process.stdout;
console.log = function(d) { //
log_file.write(util.format(d) + ‘\n’);
log_stdout.write(util.format(d) + ‘\n’);
app.listen(82);
var companyName = ‘Luminosys’;
var productName = ‘RGY800’;
var productModelNo =‘AB03’;
var productID= ‘100A’;
var macAddress = ‘11:23:45:C7:88:D3’;
var IPAddress = ‘192.168.7.52’;
var masterPsw = ’ ';
var user1 = ’ ';
var user2 = ’ ';
var user1Psw= ’ ';
var user2Psw= ’ ';
var accessPointName = ’ ';
var accessPointPsw = ’ ';
var state = ‘on’;
var serialTxDataLenght = ‘24’;
var txDataHeader = 03;
var colorA=3; // 0=off, 1= yellow, 2=green, 3= red, 4= flashing red 5= flashing green
var redTime=8;
var greenTime=4;
var yellowTime=3;
var clearTime= redTime-greenTime-yellowTime;
var redCountA=8;
var greenCountA=0;
var yellowCountA=0;
var TotalCycleTime;
var FlashingRed=1;
var SolarPresence;
var ADCValues;
var solarPowerPercent;
var batChargePercent;
var solarCurrentPercent;
var daylight;
var temperature;
var tA; //
var lightTimeDivide=0;
var timerA=5;
var timerB=4;
var phaseA=3;
var phaseB=3;
var syncB=0;
var flashingRed=0;
var batVolt;
var colorB=0;
var redCountB=8;
var greenCountB=0;
var yellowCountB=0;
var txABuffer = new Buffer(18);
var txASerialBusy=0;
var aSideWatchdog=100; // tbd
//****** serial port init**************
serialPort.open(function(){
console.log(’------------Serial 1 open------------’);
// serialPort.write("test usart1 ", function(err, results){
// if (err) console.log('error: ’ + err);
// console.log('Bytes written ’ + results);
serialPort.on(‘data’, function (data){
if (data[0] === 0x15 ){
console.log(’============Received NAK ===========’);
if (data[0] === 0x06 && data[data.length-1]===0x03){
console.log(‘Good Msg’);
var msgSwitch=1;
var jj=1;
var ii=1;
for (jj=ii; jj< data.length-1;jj++){
if (data[jj] ===0x20){
batVolt = data.toString(‘utf8’,ii,jj);
console.log('Battery Voltage = '+ batVolt);
jj++;
ii=jj;
break;
solarPowerPercent = data.toString(‘utf8’,ii,jj);
console.log('Solar Power = ‘+ solarPowerPercent+ ’ %’);
jj++;
ii=jj;
break;
daylight = data.toString(‘utf8’,ii,jj);
console.log('Daylight = '+ daylight);
jj++;
ii=jj;
break;
temperature = data.toString(‘utf8’,ii,jj);
console.log('Temperature = ‘+ temperature + ’ C’);
jj++;
ii=jj;
break;
batChargePercent = data.toString(‘utf8’,ii,jj);
console.log('Battery Level = ‘+ batChargePercent+ ’ %’);
jj++;
ii=jj;
break;
//console.log(data.length +’ data received: ’ + data);
} else {
console.log(‘Bad Msg’);
// ===== end open serial port ============
Any ideal on how to troubleshoot this problem will be greatly appreciated.
Thanks in advance
Claude Arpin
