Not able to boot from bootm command
I am using BBBW for learning Embedded Linux. I have taken an online course in which BBB is being used. Also, they are using Angstrom distribution of Linux. Since I did not get Angstrom distribution for BBBW I am using Debian 10.3 version from Beagleboard.ord. I am able to boot the board successfully from this. But my question is, when I enter into U-boot login page by terminating auto boot, I should be able to load kernel image at a specific address of DDR3. But I am facing issue with this. I execute below commands to load the kernel Image
load mmc 1:1 0x82000000 /boot/vmlinuz-4.19.94.ti-r42
where mmc is mmc interface
1 dev number (here I am using booting from eMMC i.e, MMC1)
1 is partition number. Since its debian ,eMMC has only one partition i.e, rootfs
/boot/vmlinuz-4.19.94.ti-r42 is image name which is present inside /boot/ folder
This command executes successfully. It shows some 10590617 bytes read which is the size of kernel image. But when I execute next command as below then I get error.
bootm 0x82000000
it gives Wrong Image format, Can’t get kernel Image.
Please help me with this. I tried with the address 0x80000000. But no success, same error.
Note: If you are using BBB and Angstrom distribution, then load command will be “load mmc 1:2 0x82000000 /boot/uImage”. This is given in online course. For them its working
Thank you
           bootm 0x82000000
it gives Wrong Image format, Can't get kernel Image.
That is correct, "bootm" would be the wrong loader for "/boot/vmlinuz*"
bootm requires an file with a u-boot wrapper around it. (created by
u-boot's mkimage tool)..
Use "bootz" for a raw "/boot/vmlinuz*" file instead of "bootm"..
Note: If you are using BBB and Angstrom distribution, then load command will be "load mmc 1:2 0x82000000 /boot/uImage". This is given in online course. For them its working
Hi Robert,
Thank you for your reply.
Use “bootz” for a raw “/boot/vmlinuz*” file instead of “bootm”…
The above solution helped me and it worked.
Thank you
