Hello Everyone,
I have a beaglebone green and I converted the am335x-evm.dtb file to a dts file.
After that I made some changes in it to give the specification of the board connected
to the BBG. Then I changed that dts file to dtb file so that it can be read by the kernel
during the boot process.
At the end, I added a line in the the /boot/uEnv.txt file as follows…
dtb=am335x-evm.dtb
But now I am not able to boot into BBG. All the four leds are ON and doesn’t blink
anymore.
I have two questions to ask…
What was my mistake here?
And how can I recover my BBG?
Hello Everyone,
At the end, I added a line in the the /boot/uEnv.txt file as follows...
dtb=am335x-evm.dtb
But now I am not able to boot into BBG. All the four leds are ON and doesn't blink
anymore.
I have two questions to ask..
Your mistake was using using the dtb for the am335x-evm.dtb.. Here's
what that board looks like:
http://www.ti.com/tool/TMDXEVM3358
Doesn't look at all like the BBG
Just reflash..
Hello Everyone,
dtb=am335x-evm.dtb
anymore.
Your mistake was using using the dtb for the am335x-evm.dtb… Here’s
Doesn’t look at all like the BBG
Ah! yes I realized that later.
So now I reflashed the BBG.
I saw that /boot/dtbs/ folder in BBG has all the dtb files so I changed
the am335x-bonegreen.dtb file to am335x-bonegreen.dts file i.e. I
decompiled it so that I can make changes in it.
After making some changes, I converted dts file to dtb file so that it
can be read by kernel during boot.
I also added dtb=am335x-bonegreen.dtb line in the /boot/uEnv.txt file.
But I faced the same problem again. I tried to boot into the BBG but
all the leds are ON now and it is not booting.
I don’t know where am I going wrong.
I have to keep on reflashing the BBG and do the setup all over again
I don't know where am I going wrong.
Use the device tree source under /opt/source/dtb-4.14-ti/ instead..
Plus there is a built-in makefile so you can just run:
make
sudo make install
So you can't mess up..
