hi. I use the Debian 9.12 2020-04-06 on BeagleBone AI.
for the first boot, I go to /var/lib/cloud9/BeagleBone/AI/pru directory and run
root@beaglebone:/var/lib/cloud9/BeagleBone/AI/pru# source setup.sh
TARGET=blinkInternalLED.pru1_1
and run make command
root@beaglebone:/var/lib/cloud9/BeagleBone/AI/pru# make
/var/lib/cloud9/common/Makefile:28: MODEL=TI_AM335x_BeagleBone_Black,TARGET=blin kInternalLED.pru1_1,COMMON=/var/lib/cloud9/common
/var/lib/cloud9/common/Makefile:147: GEN_DIR=/tmp/cloud9-examples,CHIP=am57xx,PR OC=pru,PRUN=1_1,PRU_DIR=/sys/class/remoteproc/remoteproc1,EXE=.out
/var/lib/cloud9/common/Makefile:150: warning: overriding recipe for target ‘all’
Makefile:4: warning: ignoring old recipe for target ‘all’
Makefile:9: warning: overriding recipe for target ‘clean’
/var/lib/cloud9/common/Makefile:225: warning: ignoring old recipe for target ‘cl ean’
- Stopping PRU 1_1
CC blinkInternalLED.pru1_1.c
“/var/lib/cloud9/common/prugpio.h”, line 4: warning #1181-D: #warning directive: “Found AI”
“blinkInternalLED.pru1_1.c”, line 36: warning #112-D: statement is unreachable
LD /tmp/cloud9-examples/blinkInternalLED.pru1_1.o - copying firmware file /tmp/cloud9-examples/blinkInternalLED.pru1_1.out t o /lib/firmware/am57xx-pru1_1-fw
write_init_pins.sh
writing “none” to “/sys/class/leds/beaglebone:green:usr1/trigger”
writing “none” to “/sys/class/leds/beaglebone:green:usr2/trigger” - Starting PRU 1_1
CC bitflip.arm.c
LD /tmp/cloud9-examples/bitflip.arm.o
CP /tmp/cloud9-examples/bitflip.arm.out
CC bitflip.pru1_1.c
LD /tmp/cloud9-examples/bitflip.pru1_1.o
CP /tmp/cloud9-examples/bitflip.pru1_1.out
CC bitflip.pru2_1.c
LD /tmp/cloud9-examples/bitflip.pru2_1.o
CP /tmp/cloud9-examples/bitflip.pru2_1.out
CC blinkExternalLED.pru1_1.c
“blinkExternalLED.pru1_1.c”, line 32: warning #112-D: statement is unreachable
LD /tmp/cloud9-examples/blinkExternalLED.pru1_1.o
CP /tmp/cloud9-examples/blinkExternalLED.pru1_1.out
CP /tmp/cloud9-examples/blinkInternalLED.pru1_1.out
CC blinkR30.pru1_1.c
“blinkR30.pru1_1.c”, line 29: warning #112-D: statement is unreachable
LD /tmp/cloud9-examples/blinkR30.pru1_1.o
CP /tmp/cloud9-examples/blinkR30.pru1_1.out
CC inputR31.pru1_1.c
“inputR31.pru1_1.c”, line 29: warning #112-D: statement is unreachable
LD /tmp/cloud9-examples/inputR31.pru1_1.o
CP /tmp/cloud9-examples/inputR31.pru1_1.out
CC neopixelDynamic.pru1_1.c
LD /tmp/cloud9-examples/neopixelDynamic.pru1_1.o
CP /tmp/cloud9-examples/neopixelDynamic.pru1_1.out
CC neopixelRpmsg.pru1_1.c
LD /tmp/cloud9-examples/neopixelRpmsg.pru1_1.o
CP /tmp/cloud9-examples/neopixelRpmsg.pru1_1.out
CC neopixelStatic.pru1_1.c
LD /tmp/cloud9-examples/neopixelStatic.pru1_1.o
CP /tmp/cloud9-examples/neopixelStatic.pru1_1.out
MODEL = TI_AM335x_BeagleBone_Black
PROC = pru
PRUN = 1_1
PRU_DIR = /sys/class/remoteproc/remoteproc1
rm /tmp/cloud9-examples/neopixelDynamic.pru1_1.o /tmp/cloud9-examples/neopixelDynamic.pru1_1.out /tmp/cloud9-examples/blinkInternalLED.pru1_1.o /tmp/cloud9-examples/inputR31.pru1_1.o /tmp/cloud9-examples/bitflip.pru1_1.o /tmp/cloud9-examples/bitflip.arm.o /tmp/cloud9-examples/neopixelStatic.pru1_1.o /tmp/cloud9-examples/neopixelRpmsg.pru1_1.o /tmp/cloud9-examples/blinkR30.pru1_1.o /tmp/cloud9-examples/blinkExternalLED.pru1_1.o /tmp/cloud9-examples/bitflip.pru2_1.o /tmp/cloud9-examples/inputR31.pru1_1.out /tmp/cloud9-examples/bitflip.pru1_1.out /tmp/cloud9-examples/bitflip.arm.out /tmp/cloud9-examples/neopixelStatic.pru1_1.out /tmp/cloud9-examples/neopixelRpmsg.pru1_1.out /tmp/cloud9-examples/blinkR30.pru1_1.out /tmp/cloud9-examples/blinkExternalLED.pru1_1.out /tmp/cloud9-examples/bitflip.pru2_1.out
every things is fine and start blinking Internal LED.also /sys/class/remotproc/remotproc1/state is “running” and
/sys/class/remotproc/remotproc1/firmware is “am57xx-pru1_1-fw
but
after reboot and run previous commands to make blinkInternalLED.pru1_1.c ,make is complete but internalLED not blinking and
/sys/class/remotproc/remotproc1/state is “suspended” also /sys/class/remotproc/remotproc1/firmware is "dra7-ipu1-fw.xem4" :|
/var/lib/cloud9/common/Makefile:28: MODEL=BeagleBoard.org_BeagleBone_AI,TARGET=blinkInternalLED.pru1_1,COMMON=/var/lib/cloud9/common
/var/lib/cloud9/common/Makefile:147: GEN_DIR=/tmp/cloud9-examples,CHIP=am57xx,PROC=pru,PRUN=1_1,PRU_DIR=/sys/class/remoteproc/remoteproc1,EXE=.out
/var/lib/cloud9/common/Makefile:225: warning: ignoring old recipe for target ‘clean’
- Stopping PRU 1_1
LD /tmp/cloud9-examples/blinkInternalLED.pru1_1.o - copying firmware file /tmp/cloud9-examples/blinkInternalLED.pru1_1.out to /lib/firmware/am57xx-pru1_1-fw
write_init_pins.sh
MODEL = BeagleBoard.org_BeagleBone_AI
PROC = pru
PRUN = 1_1
rm /tmp/cloud9-examples/blinkInternalLED.pru1_1.o
root@beaglebone:/var/lib/cloud9/BeagleBone/AI/pru# cat /sys/class/remoteproc/remoteproc0/state
suspended
root@beaglebone:/var/lib/cloud9/BeagleBone/AI/pru# cat /sys/class/remoteproc/remoteproc0/firmware
dra7-ipu1-fw.xem4
Why is this happening? However, this is not the case for BeagleBone Black with the same image??
Thanks for any suggestions,
Best regards,
Farzad
