Not getting login prompt
Hi All,
When I am running angstrom demo file system from mmc card I am not
able to get the angstrom login prompt. It hangs at
Starting GPE display manager: gpe-dm
Detail logs :
Starting Dropbear SSH server: modprobe: FATAL: Could not load /lib/
modules/2.6.32-rc5/modules.dep: No such file or directory
modprobe: FATAL: Could not load /lib/modules/2.6.32-rc5/modules.dep:
dropbear.
Starting advanced power management daemon: No APM support in kernel
(failed.)
Starting system message bus: dbus.
Starting Hardware abstraction layer hald
FATAL: Could not load /lib/modules/2.6.32-rc5/modules.dep: No such
file or directory
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
[ ok ]
Starting Connection Manager
Running ntpdate to synchronize clockError : Temporary failure in name
resolution
Kindly let me know if you people have any suggestions or input.
Regards
Nilly
I also had some problems caused by combining the board evaluation
uImage.bin file (which is supposed to work with ramdisk.gz) with the
Angstrom 2010.3 filesystem tar.bz2 file. Following a suggestion on
this list I extracted the uImage file from /boot inside that tarball
and put that in the boot partition of the SD card as uimage.bin. This
worked much better. The two kernels are only partially compatible. You
may have something similar.
Actually I am using angstrom build file system on different board than
beagle board but same omap3530 board.
any idea what is causing this stop?
Niral
