OE behind firewall
I try to run "bitbake linux-omap" behind a firewall, but:
NOTE: package linux-omap-2.6.27+2.6.28-rc7+r7+gitr014ba70469e889ebb74516052c43fd06a419b17b-r7:
task do_fetch: started
git.kernel.org[0: 130.239.17.7]: errno=No route to host
git.kernel.org[0: 199.6.1.166]: errno=No route to host
fatal: unable to connect a socket (No route to host)
NOTE: Task failed: Fetch failed: Fetch command export
PATH=/home/developer/oe/tmp/staging/i686-linux/usr/bin/beagleboard-angstrom-linux-gnueabi:/home/developer/oe/tmp/staging/i686-linux/usr/bin/armv7a-angstrom-linux-gnueabi:/home/developer/oe/tmp/staging/i686-linux/usr/sbin:/home/developer/oe/tmp/staging/i686-linux/usr/bin:/home/developer/oe/tmp/cross/armv7a/bin:/home/developer/oe/tmp/staging/i686-linux/sbin:/home/developer/oe/tmp/staging/i686-linux/bin:/home/developer/oe/opt/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/home/developer/oe/tmp/cross/armv7a/bin:/home/developer/oe/tmp/cross/armv7a/bin;
git fetch git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6.git
master failed with signal 128, output:
task do_fetch: failed
ERROR: TaskFailed event exception, aborting
I set
export CVS_TARBALL_STASH="http://oesources.org/sources/current/"
and pulled OE rom
git clone http://repo.or.cz/r/openembedded.git
How can I solve this problem?
Robert
I try to run "bitbake linux-omap" behind a firewall, but,
<snip>
I set
and pulled OE rom
Unset the CVS_TARBALL_STASH, angstroms default one has much more git snapshots.
regards,
Koen
Okay:
OE:beagleboard developer@big-ubuntu:~/oe/openembedded$ echo $CVS_TARBALL_STASH
OE:beagleboard developer@big-ubuntu:~/oe/openembedded$ cat
../beagleboard/beagleboard/profile.sh
export OE_HOME=$HOME/oe
export MY_OE_CONF="beagleboard"
export BBPATH=$OE_HOME/beagleboard/:$OE_HOME/beagleboard/$MY_OE_CONF:$OE_HOME/openembedded
export BBFILES="$OE_HOME/openembedded/packages/*/*.bb"
export PATH=$OE_HOME/opt/bitbake/bin:$PATH
if [ "$PS1" ]; then
   if [ "$BASH" ]; then
     export PS1="\[\033[01;32m\]OE:$MY_OE_CONF\[\033[00m\] ${PS1}"
   fi
fi
but the problem remains the same:
2.6.git master failed with signal 128, output:
Robert
I've been using as below with good results. If the variable is not set then this is probably the default that Koen noted. If so, then you might have a different problem. Still, try as below.
export CVS_TARBALL_STASH="http://www.angstrom-distribution.org/unstable/sources/"
I am getting the following error when executing "bitbake beagleboard-demo-image". I've run out of leads. Any ideas? Thanks.
user@ubuntu8041:~/oe$ bitbake beagleboard-demo-image
NOTE: Handling BitBake files: | (6291/6291) [100 %]
NOTE: Parsing finished. 6021 cached, 0 parsed, 270 skipped, 0 masked.
NOTE: Cache is clean, not saving.
NOTE: build 200812101136: started
OE Build Configuration:
BB_VERSION = "1.8.11"
METADATA_BRANCH = "org.openembedded.dev"
METADATA_REVISION = "41b3c72649443c24420704864095f2ca88348f31"
TARGET_ARCH = "arm"
TARGET_OS = "linux-gnueabi"
MACHINE = "beagleboard"
DISTRO = "angstrom"
DISTRO_VERSION = "2008.1-test-20081210"
TARGET_FPU = "hard"
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version git of u-boot not available (for item u-boot)
NOTE: Preparing runqueue
NOTE: Executing runqueue
NOTE: Running task 3665 of 6373 (ID: 331, /home/user/oe/openembedded/packages/angstrom/angstrom-version.bb, do_setscene)
NOTE: package angstrom-version-2008.1-test-20081210: started
NOTE: package angstrom-version-1_2008.1-test-20081210-r2: task do_setscene:
Configuring xserver-xorg
Configuring xserver-xorg-conf
Collected errors:
* ERROR: Cannot satisfy the following dependencies for task-beagleboard-demo:
       * kernel-2.6.28-rc7-omap1 *
NOTE: Task failed: /home/user/oe/system/angstrom/work/beagleboard-angstrom-linux-gnueabi/beagleboard-demo-image-1.0-r0/temp/log.do_rootfs.29923
NOTE: package beagleboard-demo-image-1.0-r0: task do_rootfs: failed
NOTE: package beagleboard-demo-image-1.0: failed
ERROR: Build of /home/user/oe/openembedded/packages/images/beagleboard-demo-image.bb do_rootfs failed
ERROR: Task 10 (/home/user/oe/openembedded/packages/images/beagleboard-demo-image.bb, do_rootfs) failed
NOTE: Tasks Summary: Attempted 6371 tasks of which 6358 didn't need to be rerun and 1 failed.
ERROR: '/home/user/oe/openembedded/packages/images/beagleboard-demo-image.bb' failed
NOTE: build 200812101118: completed
The problem was solved when reverting back to the original beagleboard-demo-image.bb prior to the comitt shown below. In other words, did away with the task-beagleboard.demo.bb file. I have obviously violated the purpose of the committ. Not sure exactly what the implications will be on the output.
