I am getting the following error while building console-image with gst-openmax
please help me regarding this issue
Thanks & Regards
padmarao
NOTE: Running task 1033 of 2444 (ID: 879, /home/gvrao/stuff/openembedded/packages/ffmpeg/[ffmpeg_git.bb](http://ffmpeg_git.bb), do_setscene)
NOTE: package ffmpeg-0.4.9+r35+gitrafb98868e19e63cbca6c9f0ed9e6cfa48d40277d: started
NOTE: package ffmpeg-1_0.4.9+r35+gitrafb98868e19e63cbca6c9f0ed9e6cfa48d40277d-r35: task do_setscene: started
NOTE: Checking if staging package installed
NOTE: No. Manually removing any installed files
NOTE: package ffmpeg-1_0.4.9+r35+gitrafb98868e19e63cbca6c9f0ed9e6cfa48d40277d-r35: task do_setscene: completed
NOTE: package ffmpeg-0.4.9+r35+gitrafb98868e19e63cbca6c9f0ed9e6cfa48d40277d: completed
NOTE: Running task 1034 of 2444 (ID: 880, /home/gvrao/stuff/openembedded/packages/ffmpeg/[ffmpeg_git.bb](http://ffmpeg_git.bb), do_fetch)
NOTE: package ffmpeg-1_0.4.9+r35+gitrafb98868e19e63cbca6c9f0ed9e6cfa48d40277d-r35: task do_fetch: started
Removing unused objects 100%...
Done.
NOTE: Creating tarball of git repository
fatal: failed to unpack tree object afb98868e19e63cbca6c9f0ed9e6cfa48d40277d
NOTE: Task failed: Fetch failed: Fetch command export PATH=/home/gvrao/stuff/tmp/staging/x86_64-linux/usr/bin/armv7a-angstrom-linux-gnueabi:/home/gvrao/stuff/tmp/staging/x86_64-linux/usr/bin/armv7a-angstrom-linux-gnueabi:/home/gvrao/stuff/tmp/staging/x86_64-linux/usr/sbin:/home/gvrao/stuff/tmp/staging/x86_64-linux/usr/bin:/home/gvrao/stuff/tmp/cross/armv7a/bin:/home/gvrao/stuff/tmp/staging/x86_64-linux/sbin:/home/gvrao/stuff/tmp/staging/x86_64-linux/bin:/home/gvrao/stuff/bitbake/bin:/home/gvrao/stuff/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games; git read-tree afb98868e19e63cbca6c9f0ed9e6cfa48d40277d failed with signal 128, output:
NOTE: package ffmpeg-1_0.4.9+r35+gitrafb98868e19e63cbca6c9f0ed9e6cfa48d40277d-r35: task do_fetch: failed
ERROR: TaskFailed event exception, aborting
NOTE: package ffmpeg-0.4.9+r35+gitrafb98868e19e63cbca6c9f0ed9e6cfa48d40277d: failed
ERROR: Build of /home/gvrao/stuff/openembedded/packages/ffmpeg/[ffmpeg_git.bb](http://ffmpeg_git.bb) do_fetch failed
ERROR: Task 880 (/home/gvrao/stuff/openembedded/packages/ffmpeg/[ffmpeg_git.bb](http://ffmpeg_git.bb), do_fetch) failed
NOTE: Tasks Summary: Attempted 1033 tasks of which 1032 didn't need to be rerun and 1 failed.
ERROR: '/home/gvrao/stuff/openembedded/packages/ffmpeg/[ffmpeg_git.bb](http://ffmpeg_git.bb)' failed
NOTE: build 200901121545: completed
Try bitbake 1.8.12
Op 12 jan 2009 om 11:36 heeft padmarao edapalapati <padmarao.i@gmail.com> het volgende geschreven:\
