I am currently using OE to compile (a slightly modified em28xx-new webcam driver [1]). Based on others experiences with uvc (and USB related fixes in git), I am also using the linux-omap_git.bb kernel. The recipe I am using for building the em28xx module is pretty simple, basically just based on an inherit-module recipe. It builds fine but I am unsure against which kernel the module is building
For example, is the module building against the omap_git kernel module, or against the one included by default in the angstrom distribution. The em28xx driver has quite some conditional kernel defines, and I am curious.
Do I need to change the prefrred kernel provider somwhere, and if so how (i have a local overlay setup, so this would be a distribution change, correct?)
John
[1] http://mcentral.de/wiki/index.php5/
it builds against the kernel that is in STAGING_KERNEL_DIR, so if you
built linux-omap_git.bb, it should use that. It could be that it
doesn't build since kernel.bbclass needs to get updated for the arm
header move.
If you are building against linux-omap_git, you already have changed
conf/machine/beagleboard.conf, right?
, and if so how (i
correct?)
It's a machine change, not a distro change.
regards,
Koen
Ok thanks.
It could be that it
doesn’t build since kernel.bbclass needs to get updated for the arm
header move.
Im not sure I understand what you mean here.
Yes.
, and if so how (i
correct?)
It’s a machine change, not a distro change.
Ok thanks.
So to summarise, it builds against what is in KERNEL_STAGING_DIR, which is the last kernel that was build. This means as long as the preferred kernel provider is linux-omap (and not linux-omap2), the last kernel built, when making a new rootfs image containing the module, will be the one I am after.
However there is no way to express the dependency between a module and a specific kernel version directly?
John
