Omapfbplay guide
Hi All,
Omapfbplay! Fantastic!
Just wondering if there are instructions as to the command line
options I can use?
I have searched the net and not found anything.
Currently running:
-f for full screen.
What other command line parameters are available?
Really want to be able to get it to loop play and play unindexed
files.
Cheers,
Chris
Any Omapfbplay experts about?
Tried looking at the source? e.g http://git.mansr.com/?p=omapfbplay;a=blob;f=omapfbplay.c;h=84912a4a6a3f614f0c4bd98d91c3edac3aa72507;hb=HEAD#l506
Chris <carlighting@yahoo.co.nz> writes:
Most of the options are pretty clear from the source code.
Thanks - I did have a look at the source before posting, thanks for
pointing out the correct spot.
Is it possible to get omapfbplay to loop play a video file?
Has anyone done this yet?
Cheers,
CJ
don't think so, patches welcome I guess.
Also, a tiny shell script around it
to make it loop should be trivial
Thanks, for the info.
At this stage patching is above my current ability.
A basic shell script is fine but there is a short delay while the
video reloads.
I will continue to work on it.
Cheers.
CJ
video reloads.
yes, omapfbplay buffers a number of frames before it starts playing,
so a short delay while doing that is expected. There should be a
command line option for the number of frames it buffers iirc.
