I’m trying to decode a video using omapfbplay, after building ti-x11-demo-image, and the system is actually complaining about libstdc++.so.6 not being found.
root@beagleboard:~# omapfbplay
omapfbplay: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: No such file or directory
What package, once installed, would provide that C++ runtime dependency?
I'm trying to decode a video using omapfbplay, after building
omapfbplay does not use C++, nor do any of the libraries it uses
(ffmpeg). Something is badly messed up in your build or your system.
Well I actually expected that such a fundamental runtime library would be installed systematically (maybe as a part of GCC’s runtime) and to me, omapfbplay referencing such a library when in reality it doesn’t use it at all is a secondary thought.
Would cross-compiling and installing a package such as Qt Embedded, rsolve the issue (having libstdc++.so.6 installed)?
