omapfbplay snapshot version 20090711 - howto compile and more questions
Hi !
I'm working on the omapfbplay snapshot version.
Does someone has an arm.mk example file, there isn't any on the git
and I did not manage to create the right one. ( I did not try it
hard :wink: ).
Mans added an interesting 'driver' stuff that let extend omapfbplay.
However in files timer.h and display.h there are variables declared
extern and not implemented anywhere, is missing a C file or not ?
extern const struct timer *ofb_timer_start[], *ofb_timer_end[];
extern const struct display *ofb_display_start[], *ofb_display_end[];
For now I'm using my own makefile and compiled omapfbplay statically
initializing the driver list.
note : The MACRO that register driver does not affect the list.
==> EDIT : it surely because I'm not compiling magic-head & magic-tail
assembly files in my makefile. I'll add them soonly and report. Can
someone explain how do theses macro works to add drivers ?
What is netsync for ?
Could someone explain why a jpeg file does not display with omapfbplay
(libavcodec recognize the format) ?
Is this because of XV output ? Or the way that we manage the decoded
frames ?
Selso.
where to get the omapfbplay source.
Thanks and Regards,
HarishKumar.V
http://git.mansr.com/
hi,
i downloaded the snapshot version of omapfbplay.
in the makefile,
“include $(or $(CONFIG),$(ARCH),$(shell uname -m)).mk”
where to find the arch.mk files.
Any hints, how to create arch.mk for omapfbplay and what are the dependencies for the compiling.
Thanks and Regards,
HarishKumar.V
