Hello there,
Does anybody knows how to use the omapfbplay utility in the beagleboard. What are the command lines switches?
Terry
Hello there,
Terry
Quoting Pedro Cruz <pcruz@libertypr.net>:
Not knowing omapfbplayer I took a short look at the repository:
The argument interpretation runs after the following code:
while ((opt = getopt(argc, argv, "b:d:fFM:P:st:T:v:")) != -1) {
switch (opt) {
case 'b':
bufsize = strtol(optarg, NULL, 0) * 1048576;
break;
case 'd':
dispdrv = optarg;
break;
case 'F':
noaspect = 1;
case 'f':
flags |= OFBP_FULLSCREEN;
break;
case 'M':
memman_drv = optarg;
break;
case 'P':
pixconv_drv = optarg;
break;
case 's':
flags &= ~OFBP_DOUBLE_BUF;
break;
case 't':
test_param = optarg;
break;
case 'T':
timer_drv = optarg;
break;
case 'v':
codec_drv = optarg;
break;
b seems to be the framebuffer size in MB
d name of the display driver
F disable aspect ratio
f Enable Fullscreen playback
M name of the Memory manager driver
I'll bet, you'll find out the rest yourself by chasing the variables and their usage
Hope that helps
Ueli
