Onewire DTS file
Hi all,
Does anyone out there actually understand what the
gpios = <&gpio2 13 0>; line does in the onewire DTS file. Somebody somewhere must have designed this function but I can find no reference to it anywhere. It seems that the general consensus is to take a similar dts file and modify it for what you want it to do.
I really want to have 4 x onewire lines active for a mass of temperature sensors but I’ve been unable to get it to work.
Any help would be really appreciated.
Cheers
Dave
Okay so that should read gpios = <&gpio2 13 0>; was expecting html reactions
I also want two ore more 1-wire lines!
I tried different things but nothing helps.
Even 2 DTS-Modules does not work for me. The first you load works and the second is ignored :frowning:
Robert
