Hello folks!
I'v been using the Beagleboard xM for about 3 months now. I'm using a
pre-built Angstrom image that boots perfectly well. I got the image
from http://www.angstrom-distribution.org/demo/beagleboard/archive/ ,
the 275MB image.
I use VNC to operate the xM through my laptop. It works pretty well,
except for the Shift key issue.
I intend to use OpenCV for image and video processing purposes on the
xM. After going through (almost) all the posts here, I tried getting
OpenCV on the board using opkg, and then doing on-board compiling.
This method started throwing up error after error, and since I was
working to a deadline (it's for a project at college), I used a
different approach.
I cross-compiled for the xM on my Ubuntu machine, and moved the binary
to the board, and ran the program, say for example edge detection.
This is the error that I get when OpenCV tries to open a window on the
xM:
./facedetect
OpenCV Error: Unspecified error (The function is not implemented.
Rebuild the library with Windows, GTK+ 2.x or Carbon support. If you
are on Ubuntu or Debian, install libgtk2.0-dev and pkg-config, then re-
run cmake or configure script) in cvNamedWindow, file highgui/
window.cpp, line 100
terminate called after throwing an instance of 'cv::Exception'
Aborted
The binaries work perfectly - I ran a modified version of a facedetect
program such that it would work on an image stored on the SD card, and
save the output image (of a detected face with a circle around it) as
a new image next to the original image. It works, so do all such
programs, where I save the results as new images.
My real issue is with getting the windows to open so that I can do
proper video processing, while viewing results at the same time.
Thanks!
