Hello, sorry for my English, is not my native language.
For the problem with Opencv and the cape camera Beaglebone can be solve with utilization of the library v4l2 " video for linux 2 ".
The call do by Opencv at v4l2 is wrong for the cape camera. You should put in your code :
static void xioctl(int fh, unsigned long int request, void *arg)
r_xioctl=100;
do {
r_xioctl = v4l2_ioctl(fh, request, arg);
} while (r_xioctl == -1 && ((errno == EINTR) || (errno == EAGAIN)));
if (r_xioctl == -1) {
fprintf(stderr, “error %d, %s\n”, errno, strerror(errno));
exit(EXIT_FAILURE);
// Next initialize capture
fd = v4l2_open(dev_name, O_RDWR | O_NONBLOCK, 0);
if (fd < 0) {
perror(“Cannot open device”);
exit(EXIT_FAILURE);
CLEAR(fmt);
fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
fmt.fmt.pix.width = width;
fmt.fmt.pix.height = height;
fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_RGB24;
fmt.fmt.pix.field = V4L2_FIELD_INTERLACED;
xioctl(fd, VIDIOC_S_FMT, &fmt);
if (fmt.fmt.pix.pixelformat != V4L2_PIX_FMT_RGB24) {
printf(“Libv4l didn’t accept RGB24 format. Can’t proceed.\n”);
exit(EXIT_FAILURE);
if ((fmt.fmt.pix.width != width) || (fmt.fmt.pix.height != height))
printf(“Warning: driver is sending image at %dx%d\n”,
fmt.fmt.pix.width, fmt.fmt.pix.height);
CLEAR(req);
req.count = 2;
req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
req.memory = V4L2_MEMORY_MMAP;
xioctl(fd, VIDIOC_REQBUFS, &req);
buff = (char*) calloc (1, sizeof (buffers));
buffers = (buffer) buff;
for (n_buffers = 0; n_buffers < req.count; ++n_buffers) {
CLEAR(buf);
buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
buf.memory = V4L2_MEMORY_MMAP;
buf.index = n_buffers;
xioctl(fd, VIDIOC_QUERYBUF, &buf);
buffers[n_buffers].length = buf.length;
buffers[n_buffers].start = v4l2_mmap(NULL, buf.length,
PROT_READ | PROT_WRITE, MAP_SHARED,
fd, buf.m.offset);
if (MAP_FAILED == buffers[n_buffers].start) {
perror(“mmap”);
exit(EXIT_FAILURE);
for (i = 0; i < n_buffers; ++i) {
CLEAR(buf);
buf.index = i;
xioctl(fd, VIDIOC_QBUF, &buf);
xioctl(fd, VIDIOC_STREAMON, &type);
imagemat = Mat(height, width, CV_8UC3, (void*)buffers[buf.index].start);
image = new IplImage(imagemat);
// next refresh the image
do {
FD_ZERO(&fds);
FD_SET(fd, &fds);
/* Timeout. /
tv.tv_sec = 0;
tv.tv_usec = 0;
r = select(fd + 1, &fds, NULL, NULL, &tv);
} while ((r == -1 && (errno = EINTR)));
if (r == -1) {
perror(“select”);
return errno;
CLEAR(buf);
xioctl(fd, VIDIOC_DQBUF, &buf);
imagemat = Mat(height, width, CV_8UC3, (void)buffers[buf.index].start);
