I tried to migrant my build environment from Fedora to Ubuntu. Since I still want to use my classic openembedded (see http://www.openembedded.org/wiki/Getting_started_with_OE-Classic) with bitbake 1.12.
I found the build fails at
bitbake console-image
NOTE: angstrom DOES NOT support xcursor-watchonly-theme because xcursor-transparent-theme is good enough | ETA: 00:02:38
NOTE: angstrom DOES NOT support ffmpeg because libav is the preferred multimedia library | ETA: 00:02:42
NOTE: angstrom DOES NOT support libiconv because the glibc builtin iconv replacement is used | ETA: 00:02:40
NOTE: angstrom DOES NOT support libiconv because the glibc builtin iconv replacement is used | ETA: 00:02:23
NOTE: angstrom DOES NOT support bluez-libs because bluez-libs 3.x has been replaced by bluez4 | ETA: 00:02:27
NOTE: angstrom DOES NOT support libiconv because the glibc builtin iconv replacement is used | ETA: 00:01:52
NOTE: angstrom DOES NOT support hotplug-ng because hotplug functionality is provided by udev
NOTE: angstrom DOES NOT support hotplug2 because hotplug functionality is provided by udev | ETA: 00:01:22
NOTE: angstrom DOES NOT support bluez-utils because bluez-utils 3.x has been replaced by bluez4 | ETA: 00:01:16
NOTE: angstrom DOES NOT support linux-hotplug because hotplug functionality is provided by udev | ETA: 00:01:06
NOTE: angstrom DOES NOT support ffmpeg because libav is the preferred multimedia library | ETA: 00:00:57
NOTE: angstrom DOES NOT support hotplug-ng because hotplug functionality is provided by udev | ETA: 00:00:56
NOTE: angstrom DOES NOT support fso-apm because regular apmd is good enough########### | ETA: 00:00:54
NOTE: angstrom DOES NOT support bash-noemu because doesn’t work on the target########## | ETA: 00:00:53
NOTE: angstrom DOES NOT support bluez-utils because bluez-utils 3.x has been replaced by bluez4 | ETA: 00:00:51
NOTE: angstrom DOES NOT support ipkg because ipkg has been superseded by opkg############# | ETA: 00:00:49
NOTE: angstrom DOES NOT support linux-hotplug because hotplug functionality is provided by udev######## | ETA: 00:00:33
NOTE: angstrom DOES NOT support bluez-libs because bluez-libs 3.x has been replaced by bluez4########### | ETA: 00:00:31
NOTE: angstrom DOES NOT support bluez-libs because bluez-libs 3.x has been replaced by bluez4############################### | ETA: 00:00:08
Parsing recipes: 100% |############################################################################################################| Time: 00:02:08
Parsing of 7226 .bb files complete (0 cached, 7226 parsed). 7906 targets, 310 skipped, 0 masked, 0 errors.
Build Configuration:
BB_VERSION = “1.12.0”
METADATA_BRANCH = “master”
METADATA_REVISION = “038d832”
TARGET_ARCH = “arm”
TARGET_OS = “linux-gnueabi”
MACHINE = “beagleboard”
DISTRO = “angstrom”
DISTRO_VERSION = “v2014.03”
TARGET_FPU = “hard”
NOTE: Resolving any missing task queue dependencies
NOTE: Preparing runqueue
NOTE: Executing RunQueue Tasks
NOTE: Running task 1 of 4034 (ID: 763, /home/kaijuntang/Projects/OE/openembedded/recipes/quilt/quilt-native_0.48.bb, do_setscene)
NOTE: Running task 2 of 4034 (ID: 1086, virtual:native:/home/kaijuntang/Projects/OE/openembedded/recipes/unifdef/unifdef_2.6.bb, do_setscene)
NOTE: package quilt-native-0.48-r7.1: task do_setscene: Started
NOTE: package unifdef-native-2.6-0: task do_setscene: Started
NOTE: package quilt-native-0.48-r7.1: task do_setscene: Succeeded
NOTE: package unifdef-native-2.6-0: task do_setscene: Succeeded
NOTE: Running task 3 of 4034 (ID: 762, /home/kaijuntang/Projects/OE/openembedded/recipes/quilt/quilt-native_0.48.bb, do_fetch)
NOTE: Running task 4 of 4034 (ID: 1085, virtual:native:/home/kaijuntang/Projects/OE/openembedded/recipes/unifdef/unifdef_2.6.bb, do_fetch)
NOTE: package quilt-native-0.48-r7.1: task do_fetch: Started
NOTE: package quilt-native-0.48-r7.1: task do_fetch: Succeeded
NOTE: Running task 5 of 4034 (ID: 755, /home/kaijuntang/Projects/OE/openembedded/recipes/quilt/quilt-native_0.48.bb, do_unpack)
NOTE: package unifdef-native-2.6-0: task do_fetch: Started
NOTE: package unifdef-native-2.6-0: task do_fetch: Succeeded
NOTE: Running task 6 of 4034 (ID: 1078, virtual:native:/home/kaijuntang/Projects/OE/openembedded/recipes/unifdef/unifdef_2.6.bb, do_unpack)
NOTE: package quilt-native-0.48-r7.1: task do_unpack: Started
NOTE: package quilt-native-0.48-r7.1: task do_unpack: Succeeded
NOTE: package unifdef-native-2.6-0: task do_unpack: Started
NOTE: Running task 7 of 4034 (ID: 756, /home/kaijuntang/Projects/OE/openembedded/recipes/quilt/quilt-native_0.48.bb, do_patch)
NOTE: package unifdef-native-2.6-0: task do_unpack: Succeeded
NOTE: Running task 8 of 4034 (ID: 1079, virtual:native:/home/kaijuntang/Projects/OE/openembedded/recipes/unifdef/unifdef_2.6.bb, do_patch)
NOTE: package quilt-native-0.48-r7.1: task do_patch: Started
NOTE: package unifdef-native-2.6-0: task do_patch: Started
NOTE: package unifdef-native-2.6-0: task do_patch: Succeeded
NOTE: Running task 9 of 4034 (ID: 1087, virtual:native:/home/kaijuntang/Projects/OE/openembedded/recipes/unifdef/unifdef_2.6.bb, do_configure)
NOTE: package quilt-native-0.48-r7.1: task do_patch: Succeeded
NOTE: Running task 10 of 4034 (ID: 764, /home/kaijuntang/Projects/OE/openembedded/recipes/quilt/quilt-native_0.48.bb, do_configure)
NOTE: package unifdef-native-2.6-0: task do_configure: Started
NOTE: package unifdef-native-2.6-0: task do_configure: Succeeded
NOTE: package quilt-native-0.48-r7.1: task do_configure: Started
NOTE: Running task 11 of 4034 (ID: 679, virtual:native:/home/kaijuntang/Projects/OE/openembedded/recipes/linux-libc-headers/linux-libc-headers_2.6.37.bb, do_setscene)
NOTE: package linux-libc-headers-native-2.6.37-r0: task do_setscene: Started
ERROR: Logfile of failure stored in: /dev/null
Log data follows:
NOTE: package linux-libc-headers-native-2.6.37-r0: task staging_helper: Failed
ERROR: Function ‘staging_helper’ failed (see /dev/null for further information)
ERROR: Task 679 (virtual:native:/home/kaijuntang/Projects/OE/openembedded/recipes/linux-libc-headers/linux-libc-headers_2.6.37.bb, do_setscene) failed with exit code ‘1’
Waiting for 1 active tasks to finish:
Do you have any idea?
Thanks!
Kai
