opkg environment with host toolchain
Hi guys,
I'm attempting to set-up a host toolchain to cross-compile for the
BeagleBone.
I have ran bitbake meta-toolchain successfully but the generated
environment set-up script does not include the code for configuring
opkg aliases etc.
Is there a step that I'm missing or another recipe I must run?
Here's the setup script that's generated for me:
export PATH=/usr/local/angstrom-eglibc-i686-armv7a/sysroots/i686-
angstromsdk-linux/usr/bin:/usr/local/angstrom-eglibc-i686-armv7a/
sysroots/i686-angstromsdk-linux/usr/bin/armv7a-angstrom-linux-gnueabi:
$PATH
export PKG_CONFIG_SYSROOT_DIR=/usr/local/angstrom-eglibc-i686-armv7a/
sysroots/armv7a-angstrom-linux-gnueabi
export PKG_CONFIG_PATH=/usr/local/angstrom-eglibc-i686-armv7a/sysroots/
armv7a-angstrom-linux-gnueabi/usr/lib/pkgconfig
export CONFIG_SITE=/usr/local/angstrom-eglibc-i686-armv7a/site-config-
export CC=arm-angstrom-linux-gnueabi-gcc
export CXX=arm-angstrom-linux-gnueabi-g++
export GDB=arm-angstrom-linux-gnueabi-gdb
export TARGET_PREFIX=arm-angstrom-linux-gnueabi-
export CONFIGURE_FLAGS="--target=arm-angstrom-linux-gnueabi --host=arm-
angstrom-linux-gnueabi --build=i686-linux --with-libtool-sysroot=/usr/
local/angstrom-eglibc-i686-armv7a/sysroots/armv7a-angstrom-linux-
gnueabi"
export CFLAGS=" -march=armv7-a -fno-tree-vectorize -mthumb-
interwork -mfloat-abi=softfp -mfpu=neon -mtune=cortex-a8 -mthumb-
interwork -mno-thumb --sysroot=/usr/local/angstrom-eglibc-i686-armv7a/
sysroots/armv7a-angstrom-linux-gnueabi"
export CXXFLAGS=" -march=armv7-a -fno-tree-vectorize -mthumb-
export LDFLAGS=" --sysroot=/usr/local/angstrom-eglibc-i686-armv7a/
export CPPFLAGS=" -march=armv7-a -fno-tree-vectorize -mthumb-
export OECORE_NATIVE_SYSROOT="/usr/local/angstrom-eglibc-i686-armv7a/
sysroots/i686-angstromsdk-linux"
export OECORE_TARGET_SYSROOT="/usr/local/angstrom-eglibc-i686-armv7a/
export OECORE_ACLOCAL_OPTS="-I /usr/local/angstrom-eglibc-i686-armv7a/
sysroots/i686-angstromsdk-linux/usr/share/aclocal"
export OECORE_DISTRO_VERSION="v2011.12-core"
export OECORE_SDK_VERSION="oe-core.0"
Was also expecting something like:
alias opkg="LD_LIBRARY_PATH=$SDK_PATH/lib $SDK_PATH/bin/opkg-cl -f
$SDK_PATH/${sysconfdir}/opkg-sdk.conf -o $SDK_PATH"'
'alias opkg-target="LD_LIBRARY_PATH=$SDK_PATH/lib $SDK_PATH/bin/opkg-
cl
- -f $SDK_PATH/$TARGET_SYS${sysconfdir}/opkg.conf -o $SDK_PATH/
$TARGET_SYS"
Many thanks for any help.
