Demo Image- These demonstration images contain a custom Mainline based kernel with experimental enhancements to the boards supported. They are usually updated about once a month, as new features/enhancements get added by the community. Currently, this image ships with two kernels “armv7” which is for mainline omap3+ devices (BeagleBoard/PandaBoard) and the “bone” which is specifically for the BeagleBone. The kernel is stress-tested by a farm of Panda/Beagles running 24/7 under a heavy load (building gcc trunk/mainline kernel).
git clone [https://github.com/RobertCNelson/armv7-multiplatform.git](https://github.com/RobertCNelson/armv7-multiplatform.git)
cd armv7-multiplatform
git checkout origin/v3.14.x -b tmp
./build_kernel.sh
git clone [https://github.com/RobertCNelson/bb-kernel.git](https://github.com/RobertCNelson/bb-kernel.git)
cd bb-kernel
git checkout origin/am33x-v3.8 -b tmp
./build_kernel.sh
Advanced Users only: Userspace, used in these demo images:
[https://github.com/RobertCNelson/omap-image-builder](https://github.com/RobertCNelson/omap-image-builder)
Trusty 14.04
Image Updated:
- 2014-06-05
- Beagle/Beagle xM: v3.14.5-armv7-x8 kernel
- BeagleBone/BeagleBone Black: v3.8.13-bone56 kernel
- OMAP5432 uEVM: v3.15.0-rc8-armv7-lpae-x4 kernel
- 2014-05-06
- Beagle/Beagle xM: v3.14.2-armv7-x5 kernel
- BeagleBone/BeagleBone Black: v3.8.13-bone49 kernel
- 2014-04-18
- Beagle/Beagle xM: v3.13.10-armv7-x11 kernel
- BeagleBone/BeagleBone Black: v3.8.13-bone47 kernel
Services Active:
Note: Depending on your internal network these may work out of the box
Apache, Port 80: [http://arm.local/](http://arm.local/) (Bone: via usb) [http://192.168.7.2](http://192.168.7.2)
SSH, Port 22: ssh ubuntu@arm.local (Bone: via usb) ubuntu@192.168.7.2
Getty, Serial Port
Default user: ubuntu pass: temppwd
Get prebuilt image:
wget [https://rcn-ee.net/deb/rootfs/trusty/ubuntu-14.04-console-armhf-2014-06-05.tar.xz](https://rcn-ee.net/deb/rootfs/trusty/ubuntu-14.04-console-armhf-2014-06-05.tar.xz)
Verify Image with:
md5sum ubuntu-14.04-console-armhf-2014-06-05.tar.xz
15f0237edd0f552e4fd65c0e5935ffdc ubuntu-14.04-console-armhf-2014-06-05.tar.xz
Unpack Image:
tar xf ubuntu-14.04-console-armhf-2014-06-05.tar.xz
cd ubuntu-14.04-console-armhf-2014-06-05
If you don’t know the location of your SD card:
sudo ./setup_sdcard.sh --probe-mmc
You should see something like:
Are you sure? I don't see [/dev/idontknow], here is what I do see...
fdisk -l:
Disk /dev/sda: 500.1 GB, 500107862016 bytes **<- x86 Root Drive**
Disk /dev/sdd: 3957 MB, 3957325824 bytes **<- MMC/SD card**
lsblk:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 0 465.8G 0 disk
├─sda1 8:1 0 446.9G 0 part / **<- x86 Root Partition**
├─sda2 8:2 0 1K 0 part
└─sda5 8:5 0 18.9G 0 part [SWAP]
sdd 8:48 1 3.7G 0 disk
├─sdd1 8:49 1 64M 0 part
└─sdd2 8:50 1 3.6G 0 part
- In this example, we can see via mount, /dev/sda1 is the x86 rootfs, therefore /dev/sdd is the other drive in the system, which is the MMC/SD card that was inserted and should be used by ./setup_sdcard.sh…
Install Image:
Quick install script for [board]
sudo ./setup_sdcard.sh --mmc /dev/sdX --dtb board
board options:
- BeagleBoard Ax/Bx/Cx/Dx - omap3-beagle
- BeagleBoard xM - omap3-beagle-xm
- BeagleBone/Black - beaglebone
- OMAP5432 uEVM - omap5-uevm
So for the BeagleBoard xM:
sudo ./setup_sdcard.sh --mmc /dev/sdX --dtb omap3-beagle-xm
Advanced: Build Image:
Built with a fork of project-rootstock (ARM native mode, runs directly on BeagleBoard), using a script from omap-image-builder:
git clone [https://github.com/RobertCNelson/omap-image-builder.git](https://github.com/RobertCNelson/omap-image-builder.git)
cd omap-image-builder
git checkout v2014.06 -b tmp
Stable:
./RootStock-NG.sh -c rcn-ee_console_ubuntu_stable_armhf
Testing:
./RootStock-NG.sh -c rcn-ee_console_ubuntu_testing_armhf
Enjoy...
MON@ROBOTONET.ORG
เมื่อ วันศุกร์ที่ 27 มิถุนายน ค.ศ. 2014, 11 นาฬิกา 53 นาที 08 วินาที UTC+7, Chaitra MohanKumar เขียนว่า:
