I was trying an opkg update by providing the following:
root@beaglebone:~# opkg update
I get the following error:
-bash: opkg: command not found
What did I do wrong?
opkg is the package manager used on Angstrom, on Debian (now the default BeagleBone distro) the package manager is apt. You can for the most part replace ‘opkg’ with ‘apt-get’.
See http://www.debian.org/doc/manuals/apt-howto/ch-apt-get.en.html
I wonder if I should just symlink "opkg -> apt-get" to hide this for
users following old directions.
The install/remove/update/upgrade are the same syntax:
http://botbrew.com/man-opkg.htm
replace ‘opkg’ with ‘apt-get’.See http://www.debian.org/doc/manuals/apt-howto/ch-apt-get.en.html
root@beaglebone:~# opkg updateI get the following error:
-bash: opkg: command not foundWhat did I do wrong?
I wonder if I should just symlink “opkg → apt-get” to hide this for
I don’t think there’s an ‘apt-get list’ though, which would make ‘apt-cache search’ seem random and more confusing. I think new documentation should take care of this in time. Or maybe symlink opkg to a script that tells them to use apt-get instead and points to some docs.
Thanks a lot Alexander, ‘apt-get’ worked perfectly fine.
Regards
Ajit K Talluri
