Oprofile in Angstrom
I am not able to make this work. Any ideas ?
I have used Oprofile (0.9.3) in 2.6.22 kernel by following similar steps (http://oprofile.sourceforge.net/docs/) . I have experienced problems mentioned (http://markmail.org/message/d3zlmmro55ciywww#query:beagleboard%20oprofile+page:1+mid:iyukqyfvstn66xmd+state:results) then.
But now, so far I tried 10 times in Angstrom, always got " error: No sample file found", irrespective of doing opcontrol --dump. Is there anything missing - I have attached console log below.
I am using Angstrom 2009.X-test-20090212 (METADATA_REVISION = "93a71b759a3474760cbe1cf1f51de710b22d709f")
root@omap3evm:~# opcontrol --init
root@omap3evm:~# opcontrol --vmlinux=/boot/vmlinux-2.6.29-rc2-omap1
root@omap3evm:~# opcontrol -V --start
Using default event: CPU_CYCLES:100000:0:1:1
executing oprofiled --session-dir=/var/lib/oprofile --separate-lib=0 --separate-kernel=0 --separate-thread=0 --separate-cpu=0 --events=CPU_CYCLES:255:0:10000
0:0:1:1, --vmlinux=/boot/vmlinux-2.6.29-rc2-omap1 --kernel-range=c0030000,c0479000 --verbose=all
Events: CPU_CYCLES:255:0:100000:0:1:1,
Using 2.6+ OProfile kernel interface.
kernel_start = c0030000, kernel_end = c0479000
Reading module info.
module omaplfb start bf063000 end bf065188
module pvrsrvkm start bf042000 end bf05dd5c
module ipv6 start bf000000 end bf03c1fc
Using log file /var/lib/oprofile/samples/oprofiled.log
Daemon started.
Profiler running.
<Did ls -lR /usr from X-terminal>
root@omap3evm:~# opcontrol --dump
root@omap3evm:~# opreport
opreport error: No sample file found: try running opcontrol --dump
or specify a session containing sample files
root@omap3evm:~# opreport --session-dir=/var/lib/oprofile
root@omap3evm:~# uname -a
Linux omap3evm 2.6.29-rc2-omap1 #1 PREEMPT Fri Feb 13 05:17:59 IST 2009 armv7l unknown unknown GNU/Linux
root@omap3evm:~#
Pratheesh
You can tweak kernel to use a standard timer instead of Cortex-A8
performance monitoring unit in oprofile driver. An immediate drawback
is a rather low samples collection frequency (~100Hz) which may
require to run your tests longer to get relevant profiling results.
Alternatively it is possible to use a timer with higher resolution in
oprofile driver.
Best regards,
Siarhei Siamashka
