I’m trying to make an SD card with the latest Jessie img. I downloaded “bone-debian-8.7-iot-armhf-2017-03-19-4gb.img.xz” to my mac and checked the shasum. I decompressed it and used “dd if=bone-debian-8.7-iot-armhf-2017-03-19-4gb.img of=/dev/diskX bs=1m” to write to it.
Here’s the BBB boot console output:
U-Boot SPL 2013.04-dirty (Jul 10 2013 - 14:02:53)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jul 10 2013 - 14:02:53)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
** File not found uEnv.txt **
** Invalid partition 2 **
What’s going on? I’ve written the SD several times with both the “IOT” and “LXQT” versions of jessie.
Thanks.
