I’ve taken my first concrete steps towards trying to get an OSTree managed Beaglebone image, but there are definitely many pieces I don’t fully understand so it’s difficult to make progress. I’m hoping to not have to dig too deeply into U-Boot, the kernel or ostree source code, but we’ll see how that goes. Any info anyone has is appreciated!
I’ve hobbled together a script that takes a Beaglebone console image, conditions the rootfs into a structure that it can be checked into an ostree repository, then creates a new rootfs with an OSTree structure for managing the full system using that repository. Some things are hardcoded that shouldn’t and other shortcuts were taken, with the goal of getting to a bootable image as soon as possible. Improvements can be made later. I’ve gotten to a point that I have an image that can be flashed to a microSD card, but it fails to boot during the initramfs.
I put together a Docker image so it should be easy to try for anyone who wants to give it a go (you could also build the docker image yourself using this Dockerfile as a starting point):
docker pull pocketnc/build-bbb-ostree-console
docker run --rm --privileged -v /tmp:/host pocketnc/build-bbb-ostree-console
# Outputs /tmp/bone-debian-10.9-console-2021-07-23-4gb.img
# If you want to run the script manually/make edits/debug
# The script is /tmp/bbb-ostree-helper-scripts/ostree_prep_rootfs.sh
docker run -ti --entrypoint /bin/bash --privileged -v /tmp:/host pocketnc/build-bbb-ostree-console
Here is the output from the boot process:
U-Boot SPL 2019.04-00002-gbb4af0f50f (Jul 08 2019 - 11:44:39 -0500)
Trying to boot from MMC2
Loading Environment from EXT4... ** File not found /boot/uboot.env **
** Unable to read "/boot/uboot.env" from mmc0:1 **
U-Boot 2019.04-00002-gbb4af0f50f (Jul 08 2019 - 11:44:39 -0500), Build: jenkins-github_Bootloader-Builder-128
CPU : AM335X-GP rev 2.1
I2C: ready
DRAM: 512 MiB
No match for driver 'omap_hsmmc'
Some drivers were not found
RTC 32KCLK Source: External.
Board: BeagleBone Black
<ethaddr> not set. Validating first E-fuse MAC
BeagleBone Black:
BeagleBone: cape eeprom: i2c_probe: 0x54:
BeagleBone: cape eeprom: i2c_probe: 0x55:
BeagleBone: cape eeprom: i2c_probe: 0x56:
BeagleBone: cape eeprom: i2c_probe: 0x57:
Net: eth0: MII MODE
cpsw, usb_ether
Press SPACE to abort autoboot in 2 seconds
board_name=[A335BNLT] ...
board_rev=[000C] ...
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
starting USB...
USB0: Port not available.
Checking for: /boot/uEnv.txt ...
Checking for: /uEnv.txt ...
Checking for: /boot.scr ...
Checking for: /boot/boot.scr ...
2158 bytes read in 42 ms (49.8 KiB/s)
Checking if uname_r is set in /boot/uEnv.txt...
Running uname_boot ...
loading /boot/vmlinuz-4.19.94-ti-r62 ...
10166784 bytes read in 770 ms (12.6 MiB/s)
debug: [enable_uboot_overlays=1] ...
debug: [enable_uboot_cape_universal=1] ...
debug: [uboot_base_dtb_univ=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: [uboot_base_dtb=am335x-boneblack-uboot-univ.dtb] ...
uboot_overlays: Switching too: dtb=am335x-boneblack-uboot-univ.dtb ...
loading /boot/dtbs/4.19.94-ti-r62/am335x-boneblack-uboot-univ.dtb ...
164234 bytes read in 179 ms (895.5 KiB/s)
uboot_overlays: [fdt_buffer=0x60000] ...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-BONE-eMMC1-01-00A0.dtbo]...
uboot_overlays: uboot loading of [/lib/firmware/BB-HDMI-TDA998x-00A0.dtbo] disabled by /boot/uEnv.txt [disable_uboot_overlay_video=1]...
uboot_overlays: unable to find [mmc 0:1 /lib/firmware/BB-ADC-00A0.dtbo]...
uboot_overlays: unable to find [mmc 0:1 AM335X-PRU-UIO-00A0.dtbo]...
loading /boot/initrd.img-4.19.94-ti-r62 ...
7433990 bytes read in 599 ms (11.8 MiB/s)
debug: [console=ttyO0,115200n8 bone_capemgr.uboot_capemgr_enabled=1 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait coherent_pool=1M net.ifnames=0 lpj=1990656 rng_core.default_quality=100 quiet ostree=/ostree/deploy/debian/deploy/170d5ee24c41d63c7bbe595352cdb2404d258ba890ad5e655742248e8e09c829.0] ...
debug: [bootz 0x82000000 0x88080000:716f06 0x88000000] ...
## Flattened Device Tree blob at 88000000
Loading Ramdisk to 8f8e9000, end 8fffff06 ... OK
Loading Device Tree to 8f8bd000, end 8f8e8189 ... OK
Starting kernel ...
[ 0.002165] timer_probe: no matching timers found
[ 0.188179] l4_wkup_cm:clk:0010:0: failed to disable
[ 1.524570] omap_voltage_late_init: Voltage driver support not added
run-init: can't execute '/sbin/init': No such file or directory
Target filesystem doesn't have requested /sbin/init.
run-init: can't execute '/etc/init': No such file or directory
run-init: can't execute '/bin/init': No such file or directory
run-init: can't execute '/bin/sh': No such file or directory
run-init: can't execute '': No such file or directory
No init found. Try passing init= bootarg.
BusyBox v1.30.1 (Debian 1:1.30.1-4) built-in shell (ash)
Enter 'help' for a list of built-in commands.
(initramfs)
It looks like it has problems locating overlays in /lib as well as the init script as that information is buried in the /ostree deployment. I was under the impression that ostree is supposed to chroot to that deployment in the kernel, but that doesn’t seem to be happening (or perhaps hasn’t happened yet). If anyone has any knowledge about ostree details or Beaglebone U-boot or kernel details, please let me know!
