P9_42 as a standard gpio pin
I would like to use pin P9_42 as a standard gpio pin to control a device. However, it seems I am getting a repeating 17 pulses over 4 seconds with a 1 second pause on P9-42. Using “config-pin -a P9.42 in” the pulses stop, but I cannot use this pin as gpio. As soon as I set it to out the pulses start up again.
gpio-7 (ECAP0_IN_PWM0_OUT |P9_42 ) out lo
gpio-114 (MCASP0_ACLKR |P9_92 ) in lo
Not sure how to stop the pulses. Any ideas out there?
On Fri, 3 Aug 2018 07:55:00 -0700 (PDT),
gemlrm1@gmail.com declaimed the following:
1 second pause on P9-42. Using "config-pin -a P9.42 in" the pulses stop,
start up again.
I don't recognize your listing there, but what (immediately after a reboot,
before any use of config-pin to set things) does
debian@beaglebone:~$ config-pin -q p9_42
P9_42 Mode: default Direction: in Value: 0
debian@beaglebone:~$ config-pin -a p9_42 out
P9_42 Mode: gpio Direction: out Value: 0
display.
  A stream of pulses makes one think something is overriding and running
the pin as PWM, SPI1 Clk, or UART3 TX.
This is the output at boot:
The output is listing is from the PINS file.
On Fri, 3 Aug 2018 11:00:36 -0700 (PDT),
# config-pin -a p9_42 out
  Well, nothing blatantly obvious there. I was hoping it might show
something different. The only other thing I'd investigate is to make sure
one does not have something running that might be doing things in the
background.
  Sorry.
My thought as well - but not idea what from the normal OS.
P9_42 (such as P9_41) is a double pin. It’s connected to two CPU balls. The tool config-pins doen’t handle that correctly.
Make sure that both CPU balls get proper configuration:
config-pin -a p9_92 in
Note: you can damage the CPU when both CPU balls are in output mode at different levels!
