parse error in /etc/sudoers near line
i am trying to enable P9_22 as a PWM Output, and i try to pass two seperate overlays to the cape manager:
/lib/fimrware$ sudo sh -c “echo bone_pwm_P9_22 > $SLOTS”
/lib/fimrware$ sudo sh -c “echo am33xx_pwm > $SLOTS”
/lib/fimrware$ cat $SLOTS
but after the first line i always get the error message:
sudo: parse error in /etc/sudoers near line 11
sudo: no valid sudoers sources found, quitting
sudo: unable to initialize policy plugin
and i dont know how to fix it.
/lib/firmware$ ls looks like this:
ADAFRUIT-SPI0-00A0.dtbo RTL8192SU cape-bone-dvi-00A1.dtbo
ADAFRUIT-SPI1-00A0.dtbo TT3201-001-01.dtbo cape-bone-dvi-00A2.dtbo
ADAFRUIT-UART1-00A0.dtbo am335x-pm-firmware.bin cape-bone-exptest-00A0.dtbo
ADAFRUIT-UART2-00A0.dtbo am33xx_pwm-00A0.dtbo cape-bone-geiger-00A0.dtbo
ADAFRUIT-UART4-00A0.dtbo atmel_at76c502-wpa.bin cape-bone-hexy-00A0.dtbo
ADAFRUIT-UART5-00A0.dtbo atmel_at76c502.bin cape-bone-ibb-00A0.dtbo
BB-ADC-00A0.dtbo atmel_at76c502_3com-wpa.bin cape-bone-iio-00A0.dtbo
BB-BONE-AUDI-01-00A0.dtbo atmel_at76c502_3com.bin cape-bone-lcd3-00A0.dtbo
BB-BONE-BACON-00A0.dtbo atmel_at76c502d-wpa.bin cape-bone-lcd3-00A2.dtbo
BB-BONE-BACONE-00A0.dtbo atmel_at76c502d.bin cape-bone-mrf24j40-00A0.dtbo
BB-BONE-BACONE2-00A0.dtbo atmel_at76c502e-wpa.bin cape-bone-nixie-00A0.dtbo
BB-BONE-CAM-VVDN-00A0.dtbo atmel_at76c502e.bin cape-bone-pinmux-test-00A0.dtbo
BB-BONE-CAM3-01-00A2.dtbo atmel_at76c503-i3861.bin cape-bone-proto-00A0.dtbo
BB-BONE-CRYPTO-00A0.dtbo atmel_at76c503-i3863.bin cape-bone-replicape-00A2.dtbo
BB-BONE-GPEVT-00A0.dtbo atmel_at76c503-rfmd-0.90.2-140.bin cape-bone-replicape-00A3.dtbo
BB-BONE-GPS-00A0.dtbo atmel_at76c503-rfmd-acc.bin cape-bone-tester-00A0.dtbo
BB-BONE-LCD4-01-00A0.dtbo atmel_at76c503-rfmd.bin cape-bone-weather-00A0.dtbo
BB-BONE-LCD4-01-00A1.dtbo atmel_at76c504.bin cape-bone-weather-00B0.dtbo
BB-BONE-LCD7-01-00A2.dtbo atmel_at76c504_2958-wpa.bin cape-boneblack-hdmi-00A0.dtbo
BB-BONE-LCD7-01-00A3.dtbo atmel_at76c504a_2958-wpa.bin cape-boneblack-hdmin-00A0.dtbo
BB-BONE-LCD7-01-00A4.dtbo atmel_at76c504c-wpa.bin cape-univ-emmc-00A0.dtbo
BB-BONE-PRU-01-00A0.dtbo atmel_at76c505-rfmd.bin cape-universal-00A0.dtbo
BB-BONE-PRU-02-00A0.dtbo atmel_at76c505-rfmd2958.bin cape-universaln-00A0.dtbo
BB-BONE-PRU-03-00A0.dtbo atmel_at76c505a-rfmd2958.bin carl9170-1.fw
BB-BONE-PRU-04-00A0.dtbo atmel_at76c506-wpa.bin duty
BB-BONE-PWMT-00A0.dtbo atmel_at76c506.bin htc_9271.fw
BB-BONE-RS232-00A0.dtbo bone_pwm_P8_13-00A0.dtbo lbtf_usb.bin
BB-BONE-RST-00A0.dtbo bone_pwm_P8_19-00A0.dtbo libertas
BB-BONE-RST2-00A0.dtbo bone_pwm_P8_34-00A0.dtbo libertas_cs.fw
BB-BONE-RTC-00A0.dtbo bone_pwm_P8_36-00A0.dtbo libertas_cs_helper.fw
BB-BONE-SERL-01-00A1.dtbo bone_pwm_P8_45-00A0.dtbo mwl8k
BB-BONE-SERL-03-00A1.dtbo bone_pwm_P8_46-00A0.dtbo period
BB-BONE-eMMC1-01-00A0.dtbo bone_pwm_P9_14-00A0.dtbo rt2561.bin
BB-BONELT-BT-00A0.dtbo bone_pwm_P9_16-00A0.dtbo rt2561s.bin
BB-GPIOHELP-00A0.dtbo bone_pwm_P9_21-00A0.dtbo rt2661.bin
BB-I2C1-00A0.dtbo bone_pwm_P9_22-00A0.dtbo rt2860.bin
BB-I2C1A1-00A0.dtbo bone_pwm_P9_28-00A0.dtbo rt2870.bin
BB-SPIDEV0-00A0.dtbo bone_pwm_P9_29-00A0.dtbo rt3070.bin
BB-SPIDEV1-00A0.dtbo bone_pwm_P9_31-00A0.dtbo rt3071.bin
BB-SPIDEV1A1-00A0.dtbo bone_pwm_P9_42-00A0.dtbo rt3090.bin
BB-UART1-00A0.dtbo brcm rt73.bin
BB-UART2-00A0.dtbo bspm_P9_14_f-00A0.dtbo rtl_nic
BB-UART2-RTSCTS-00A0.dtbo bspm_P9_14_f-00A0.dts rtlwifi
BB-UART4-00A0.dtbo bspwm_P9_14_e-00A0.dtbo run
BB-UART4-RTSCTS-00A0.dtbo bspwm_P9_14_e-00A0.dts sd8385.bin
BB-UART5-00A0.dtbo cape-CBB-Serial-r01.dtbo sd8385_helper.bin
DNIL-AMPCAPE-1-00R1.dtbo cape-bebopr-R2.dtbo sd8686.bin
EBB-GPIO-Example-00A0.dtbo cape-bebopr-brdg-R2.dtbo sd8686_helper.bin
LICENCE.atheros_firmware cape-bebopr-ena-R2.dtbo sd8688.bin
LICENCE.broadcom_bcm43xx cape-bone-2g-emmc1.dtbo sd8688_helper.bin
LICENCE.rtlwifi_firmware.txt cape-bone-adafruit-lcd-00A0.dtbo ti-connectivity
LICENCE.ti-connectivity cape-bone-argus-00A0.dtbo usb8388.bin
RTL8192E cape-bone-dvi-00A0.dtbo zd1211
Pls help me.
Regards
zoro
hey
I am also getting he same error.Were you able to solve it?
On Wed, 27 Dec 2017 10:40:29 -0800 (PST), Pankhuri Vanjani
<16uec069@lnmiit.ac.in> declaimed the following:
hey
  You are responding to a nearly three year old post -- the original
poster may not even be following this anymore.
/lib/fimrware$ sudo sh -c "echo bone_pwm_P9_22 > $SLOTS"
/lib/fimrware$ sudo sh -c "echo am33xx_pwm > $SLOTS"
  Have you examined the sudoers file mentioned in the error message --
and compare the contents with documentation?
man sudoers
