Adding support for OMAP3 Beagle Board
Signed-off-by: Syed Mohammed Khasim <khasim@ti.com>
I just discovered the beagle board and I 'm really happy
I was wondering if you know a nice tutorial that explain How to start
a kernel modif for a new embedded board with ARM? Any suggestion?
That explain why you add stuff in Kconfig, board-omap3beagle.c, board-
omap3beagle.h and hardware.h
arch/arm/mach-omap2/Kconfig | 4 +
arch/arm/mach-omap2/Makefile | 1
arch/arm/mach-omap2/board-omap3beagle.c | 79 +++++++++++++++++
I think a good starting point is the book “Embedded Linux Primer” by Christopher Halinan, especially chapter 4 in this case.
Matthieu.
AVM Audiovisuelles Marketing und Computersysteme GmbH
Alt-Moabit 95, 10559 Berlin
HRB 23075 AG Charlottenburg
Geschäftsführer: Johannes Nill
kapare kevyn.alexandre.pare@gmail.com
Gesendet von: beagleboard@googlegroups.com
03.06.2008 21:19
Bitte antworten an
Kopie:
Thema: [beagleboard] Re: Adding OMAP3 beagle support
I just discovered the beagle board and I 'm really happy ;)
include/asm-arm/arch-omap/board-omap3beagle.h | 53 ++++++++++++++++
include/asm-arm/arch-omap/hardware.h
I'm curious to understand more about kernel and ARM.
Otherwise thx
kap
> Signed-off-by: Syed Mohammed Khasim <kha...@ti.com>
> arch/arm/mach-omap2/board-omap3beagle.c | 79 ++++++++++++++++++++++++++
> include/asm-arm/arch-omap/board-omap3beagle.h | 53 +++++++++++++++++
> include/asm-arm/arch-omap/hardware.h | 4 +
> 5 files changed, 141 insertions(+)
> Index: my_branch/arch/arm/mach-omap2/Kconfig
> --- my_branch.orig/arch/arm/mach-omap2/Kconfig 2008-04-19 07:50:28.000000000 +0530
> +++ my_branch/arch/arm/mach-omap2/Kconfig 2008-04-19 07:50:28.000000000 +0530
> @@ -109,3 +109,7 @@
> config MACH_OMAP3EVM
> bool "OMAP 3530 EVM board"
> depends on ARCH_OMAP3 && ARCH_OMAP34XX
> +config MACH_OMAP3_BEAGLE
> + bool "OMAP3 BEAGLE board"
> + depends on ARCH_OMAP3 && ARCH_OMAP34XX
> Index: my_branch/arch/arm/mach-omap2/Makefile
> --- my_branch.orig/arch/arm/mach-omap2/Makefile 2008-04-19 07:50:28.000000000 +0530
> +++ my_branch/arch/arm/mach-omap2/Makefile 2008-04-19 07:50:28.000000000 +0530
> @@ -35,6 +35,7 @@
> board-3430sdp-usb.o \
> board-3430sdp-flash.o
> obj-$(CONFIG_MACH_OMAP3EVM) += board-omap3evm.o
> +obj-$(CONFIG_MACH_OMAP3_BEAGLE) += board-omap3beagle.o
> obj-$(CONFIG_MACH_OMAP_APOLLON) += board-apollon.o \
> board-apollon-mmc.o \
> board-apollon-keys.o
> Index: my_branch/arch/arm/mach-omap2/board-omap3beagle.c
> --- /dev/null 1970-01-01 00:00:00.000000000 +0000
> +++ my_branch/arch/arm/mach-omap2/board-omap3beagle.c 2008-04-19 07:52:27.000000000 +0530
> @@ -0,0 +1,79 @@
> + * linux/arch/arm/mach-omap2/board-omap3beagle.c
> + * Copyright (C) 2008 Texas Instruments
> + * Modified from mach-omap2/board-3430sdp.c
> + * Initial code: Syed Mohammed Khasim
> + * This program is free software; you can redistribute it and/or modify
> + * it under the terms of the GNU General Public License version 2 as
> + * published by the Free Software Foundation.
> +#include <linux/kernel.h>
> +#include <linux/init.h>
> +#include <linux/platform_device.h>
> +#include <linux/delay.h>
> +#include <linux/err.h>
> +#include <linux/clk.h>
> +#include <linux/io.h>
> +#include <asm/hardware.h>
> +#include <asm/mach-types.h>
> +#include <asm/mach/arch.h>
> +#include <asm/mach/map.h>
> +#include <asm/arch/gpio.h>
> +#include <asm/arch/board.h>
> +#include <asm/arch/common.h>
> +static struct omap_uart_config omap3_beagle_uart_config __initdata = {
> + .enabled_uarts = ((1 << 0) | (1 << 1) | (1 << 2)),
> +static int __init omap3_beagle_i2c_init(void)
> + omap_register_i2c_bus(1, 2600, NULL, 0);
> + omap_register_i2c_bus(2, 400, NULL, 0);
> + omap_register_i2c_bus(3, 400, NULL, 0);
> + return 0;
> +static void __init omap3_beagle_init_irq(void)
> + omap2_init_common_hw();
> + omap_init_irq();
> + omap_gpio_init();
> +static struct omap_board_config_kernel omap3_beagle_config[] __initdata = {
> + { OMAP_TAG_UART, &omap3_beagle_uart_config },
> +static void __init omap3_beagle_init(void)
> + omap_board_config = omap3_beagle_config;
> + omap_board_config_size = ARRAY_SIZE(omap3_beagle_config);
> + omap_serial_init();
> +arch_initcall(omap3_beagle_i2c_init);
> +static void __init omap3_beagle_map_io(void)
> + omap2_set_globals_343x();
> + omap2_map_common_io();
> +MACHINE_START(OMAP3_BEAGLE, "OMAP3 Beagle Board")
> + /* Maintainer: Syed Mohammed Khasim -http://beagleboard.org*/
> + .phys_io = 0x48000000,
> + .io_pg_offst = ((0xd8000000) >> 18) & 0xfffc,
> + .boot_params = 0x80000100,
> + .map_io = omap3_beagle_map_io,
> + .init_irq = omap3_beagle_init_irq,
> + .init_machine = omap3_beagle_init,
> + .timer = &omap_timer,
> +MACHINE_END
> Index: my_branch/include/asm-arm/arch-omap/board-omap3beagle.h
> +++ my_branch/include/asm-arm/arch-omap/board-omap3beagle.h 2008-04-19 07:53:04.000000000 +0530
> @@ -0,0 +1,53 @@
> + * linux/include/asm-arm/arch-omap/board-omap3beagle.h
> + * Hardware definitions for TI OMAP3 BEAGLE.
> + * Initial creation by Syed Mohammed Khasim <kha...@ti.com>
> + * This program is free software; you can redistribute it and/or modify it
> + * under the terms of the GNU General Public License as published by the
> + * Free Software Foundation; either version 2 of the License, or (at your
> + * option) any later version.
> + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
> + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
> + * NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
> + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
> + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
> + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
> + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
> + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
> + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> + * You should have received a copy of the GNU General Public License along
> + * with this program; if not, write to the Free Software Foundation, Inc.,
> + * 675 Mass Ave, Cambridge, MA 02139, USA.
> +#ifndef __ASM_ARCH_OMAP3_BEAGLE_H
> +#define __ASM_ARCH_OMAP3_BEAGLE_H
> +#ifdef CONFIG_TWL4030_CORE
> +#define TWL4030_IRQNUM INT_34XX_SYS_NIRQ
> +/* TWL4030 Primary Interrupt Handler (PIH) interrupts */
> +#define IH_TWL4030_BASE IH_BOARD_BASE
> +#define IH_TWL4030_END (IH_TWL4030_BASE+8)
> +#define IH_TWL4030_PWRBASE (IH_TWL4030_END)
> +#define IH_TWL4030_PWRBASE_END (IH_TWL4030_PWRBASE+8)
> +#ifdef CONFIG_TWL4030_GPIO
> +/* TWL4030 GPIO Interrupts */
> +#define IH_TWL4030_GPIO_BASE (IH_TWL4030_PWRBASE_END)
> +#define IH_TWL4030_GPIO_END (IH_TWL4030_GPIO_BASE+18)
> +#define NR_IRQS (IH_TWL4030_GPIO_END)
> +#else
> +#define NR_IRQS (IH_TWL4030_PWRBASE_END)
> +#endif /* CONFIG_I2C_TWL4030_GPIO */
> +#endif /* End of support for TWL4030 */
> +#endif /* __ASM_ARCH_OMAP3_BEAGLE_H */
> Index: my_branch/include/asm-arm/arch-omap/hardware.h
> --- my_branch.orig/include/asm-arm/arch-omap/hardware.h 2008-04-19 07:50:28.000000000 +0530
> +++ my_branch/include/asm-arm/arch-omap/hardware.h 2008-04-19 07:50:28.000000000 +0530
> @@ -339,6 +339,10 @@
> #include "board-omap3evm.h"
> #endif
> +#ifdef CONFIG_MACH_OMAP3_BEAGLE
> +#include "board-omap3beagle.h"
> +#endif
> #ifdef CONFIG_MACH_OMAP_APOLLON
> #include "board-apollon.h"
> #endif
I think a good starting point is the book "Embedded Linux Primer" by
Christopher Hallinan, in this case the fourth chapter.
Matthieu.
