[PATCH 3/4] Adding support for OMAP3 Beagle Board
Signed-off-by: Syed Mohammed Khasim <khasim@ti.com>
arch/arm/mach-omap2/Kconfig | 4 +
arch/arm/mach-omap2/Makefile | 1
arch/arm/mach-omap2/board-omap3beagle.c | 79 ++++++++++++++++++++++++++
include/asm-arm/arch-omap/board-omap3beagle.h | 53 +++++++++++++++++
include/asm-arm/arch-omap/hardware.h | 4 +
5 files changed, 141 insertions(+)
Index: my_branch/arch/arm/mach-omap2/Kconfig
--- my_branch.orig/arch/arm/mach-omap2/Kconfig 2008-04-16 14:41:28.000000000 +0530
+++ my_branch/arch/arm/mach-omap2/Kconfig 2008-04-16 14:45:38.000000000 +0530
@@ -109,3 +109,7 @@
config MACH_OMAP3EVM
   bool "OMAP 3530 EVM board"
   depends on ARCH_OMAP3 && ARCH_OMAP34XX
+config MACH_OMAP3_BEAGLE
+ bool "OMAP3 BEAGLE board"
+ depends on ARCH_OMAP3 && ARCH_OMAP34XX
Index: my_branch/arch/arm/mach-omap2/Makefile
--- my_branch.orig/arch/arm/mach-omap2/Makefile 2008-04-16 14:41:28.000000000 +0530
+++ my_branch/arch/arm/mach-omap2/Makefile 2008-04-16 14:45:38.000000000 +0530
@@ -35,6 +35,7 @@
              board-3430sdp-usb.o \
              board-3430sdp-flash.o
obj-$(CONFIG_MACH_OMAP3EVM) += board-omap3evm.o
+obj-$(CONFIG_MACH_OMAP3_BEAGLE) += board-omap3beagle.o
obj-$(CONFIG_MACH_OMAP_APOLLON) += board-apollon.o \
              board-apollon-mmc.o \
              board-apollon-keys.o
Index: my_branch/arch/arm/mach-omap2/board-omap3beagle.c
--- /dev/null 1970-01-01 00:00:00.000000000 +0000
+++ my_branch/arch/arm/mach-omap2/board-omap3beagle.c 2008-04-16 14:45:52.000000000 +0530
@@ -0,0 +1,79 @@
+ * linux/arch/arm/mach-omap2/board-omap3beagle.c
+ * Copyright (C) 2008 Texas Instruments
+ * Modified from mach-omap2/board-3430sdp.c
+ * Initial code: Syed Mohammed Khasim
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License version 2 as
+ * published by the Free Software Foundation.
+#include <linux/kernel.h>
+#include <linux/init.h>
+#include <linux/platform_device.h>
+#include <linux/delay.h>
+#include <linux/err.h>
+#include <linux/clk.h>
+#include <linux/io.h>
+#include <asm/hardware.h>
+#include <asm/mach-types.h>
+#include <asm/mach/arch.h>
+#include <asm/mach/map.h>
+#include <asm/arch/gpio.h>
+#include <asm/arch/board.h>
+#include <asm/arch/common.h>
+static struct omap_uart_config omap3_beagle_uart_config __initdata = {
+ .enabled_uarts = ((1 << 0) | (1 << 1) | (1 << 2)),
+static int __init omap3_beagle_i2c_init(void)
+ omap_register_i2c_bus(1, 2600, NULL, 0);
+ omap_register_i2c_bus(2, 400, NULL, 0);
+ omap_register_i2c_bus(3, 400, NULL, 0);
+ return 0;
+static void __init omap3_beagle_init_irq(void)
+ omap2_init_common_hw();
+ omap_init_irq();
+ omap_gpio_init();
+static struct omap_board_config_kernel omap3_beagle_config[] __initdata = {
+ {OMAP_TAG_UART, &omap3_beagle_uart_config },
+static void __init omap3_beagle_init(void)
+ omap_board_config = omap3_beagle_config;
+ omap_board_config_size = ARRAY_SIZE(omap3_beagle_config);
+ omap_serial_init();
Do you like to add here MMC and USB init like recently proposed by Koen Kooi?
If I understand correctly, these patches currently won't boot on BeagleBoard if MMC and USB are missing?
Many thanks
Dirk
Hi Dirk,
Koen Kooi?
They are any ways adding new functionality we can bring them in as new patches. Just trying to avoid another round of testing :slight_smile:
I have tried with Ramdisk. Kernel boots on Beagle with out USB and MMC.
Khasim
Hi Dirk,
Koen Kooi?
Yes, okay, with below hint this makes sense.
Ah, maybe I missed this hint. Yes, with ramdisk it will work. I think Koen's issue yesterday was to mount MMC card and this confused me :wink:
Thanks for clarification,
Dirk
* Felipe Balbi <me@felipebalbi.com> [080417 04:40]:
> +0530
> @@ -109,3 +109,7 @@
> +0530
> @@ -35,6 +35,7 @@
> @@ -0,0 +1,79 @@
> + return 0;
> + omap_init_irq();
> + omap_gpio_init();
> +arch_initcall(omap3_beagle_i2c_init);
> +static void __init omap3_beagle_map_io(void)
> + omap2_set_globals_343x();
> + omap2_map_common_io();
> +MACHINE_START(OMAP3_BEAGLE, "OMAP3 Beagle Board")
> + /* Maintainer: Syed Mohammed Khasim - http://beagleboard.org */
> + .phys_io = 0x48000000,
> + .io_pg_offst = ((0xd8000000) >> 18) & 0xfffc,
> + .boot_params = 0x80000100,
> + .map_io = omap3_beagle_map_io,
> + .init_irq = omap3_beagle_init_irq,
> + .init_machine = omap3_beagle_init,
> + .timer = &omap_timer,
> +MACHINE_END
> Index: my_branch/include/asm-arm/arch-omap/board-omap3beagle.h
> +++ my_branch/include/asm-arm/arch-omap/board-omap3beagle.h 2008-04-16
> 14:47:14.000000000 +0530
> @@ -0,0 +1,53 @@
> + * linux/include/asm-arm/arch-omap/board-omap3beagle.h
> + * Hardware definitions for TI OMAP3 BEAGLE.
> + * Initial creation by Syed Mohammed Khasim <khasim@ti.com>
> it
> + * under the terms of the GNU General Public License as published by the
> + * Free Software Foundation; either version 2 of the License, or (at
your
> + * option) any later version.
> + * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED
> + * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
> + * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
> IN
> + * NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
> + * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
> BUT
> + * NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
> + * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
ON
> + * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR
> TORT
> + * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
> OF
> + * THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
> + * You should have received a copy of the GNU General Public License
> along
> + * with this program; if not, write to the Free Software Foundation,
> Inc.,
> + * 675 Mass Ave, Cambridge, MA 02139, USA.
> +#ifndef __ASM_ARCH_OMAP3_BEAGLE_H
> +#define __ASM_ARCH_OMAP3_BEAGLE_H
> +#ifdef CONFIG_TWL4030_CORE
> +#define TWL4030_IRQNUM INT_34XX_SYS_NIRQ
> +/* TWL4030 Primary Interrupt Handler (PIH) interrupts */
> +#define IH_TWL4030_BASE IH_BOARD_BASE
> +#define IH_TWL4030_END (IH_TWL4030_BASE+8)
> +#define IH_TWL4030_PWRBASE (IH_TWL4030_END)
> +#define IH_TWL4030_PWRBASE_END (IH_TWL4030_PWRBASE+8)
> +#ifdef CONFIG_TWL4030_GPIO
> +/* TWL4030 GPIO Interrupts */
> +#define IH_TWL4030_GPIO_BASE (IH_TWL4030_PWRBASE_END)
> +#define IH_TWL4030_GPIO_END (IH_TWL4030_GPIO_BASE+18)
> +#define NR_IRQS (IH_TWL4030_GPIO_END)
> +#else
> +#define NR_IRQS (IH_TWL4030_PWRBASE_END)
> +#endif /* CONFIG_I2C_TWL4030_GPIO */
shouldn't you consider the power base as the other boards ?
Felipe, can you clarify what you mean here?
* Syed Mohammed, Khasim <khasim@ti.com> [080416 19:12]:
@@ -109,3 +109,7 @@
@@ -35,6 +35,7 @@
@@ -0,0 +1,79 @@
+ return 0;
+ omap_init_irq();
+ omap_gpio_init();
+MACHINE_END
+++ my_branch/include/asm-arm/arch-omap/board-omap3beagle.h 2008-04-16 14:47:14.000000000 +0530
@@ -0,0 +1,53 @@
+ * This program is free software; you can redistribute it and/or modify it
+ * Free Software Foundation; either version 2 of the License, or (at your
+ * MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
+ * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON
+ * ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
+ * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
+ * You should have received a copy of the GNU General Public License along
+ * with this program; if not, write to the Free Software Foundation, Inc.,
+#else
+#endif /* End of support for TWL4030 */
+#endif /* __ASM_ARCH_OMAP3_BEAGLE_H */
Extra space here too.
> > +#else
Just check board-3430sdp.h
#else
#endif /* __ASM_ARCH_OMAP_3430SDP_H */
if there are no such defines for power base, it will break compilation
of twl4030-pwrirq.c which is always built whenever we enable twl4030
support.
At present I have enabled TWL4030 support in both EVM and beagle patches and it is tested booting on both beagle and evm boards, "with out these defines".
So, these defines are not required now. They will be added when necessary along with relevant functionality. I could have added but then your comment might have been, why to add these defines when they are not used :slight_smile:
Thanks for the review.
Thanks & Regards,
Khasim
I can't see how can you possibly build twl4030 support without those
defines. Looking at
drivers/i2c/chips/twl4030-pwrirq.c:twl4030_pwrirq_enableint():
static void twl4030_pwrirq_enableint(unsigned int irq)
  twl4030_pwrirq_pending_unmask |= 1 << (irq - IH_TWL4030_PWRBASE);
  if (twl4030_pwrirq_unmask_thread &&
    twl4030_pwrirq_unmask_thread->state != TASK_RUNNING)
    wake_up_process(twl4030_pwrirq_unmask_thread);
I clearly see the use of IH_TWL4030_PWRBASE and looking at
drivers/i2c/chips/Makefile:
obj-$(CONFIG_TWL4030_CORE) += twl4030-core.o twl4030-pwrirq.o
I also clearly see that compilation it will always fail whenever you enable
CONFIG_TWL4030_CORE.
But you already put such defines anyway :-p
* Felipe Balbi <me@felipebalbi.com> [080419 13:12]:
