From 4c368789c76dc196bbf3436a5f35ccbd3fd00965 Mon Sep 17 00:00:00 2001
Date: Tue, 5 Jan 2010 20:42:17 +0530
Subject: [PATCH] Configure DSS to enable DVI-D and S-Video
Displays Color bar on S-video
Displays Orange background Color on DVI-D - No Framebuffer usedSigned-off-by: Syed Mohammed Khasim<khasim@ti.com>
board/ti/beagle/beagle.c | 101 ++++++++++++++++++++++++++++++++++++++++++++++
1 files changed, 101 insertions(+), 0 deletions(-)diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c
index d76df30..cc2079d 100644
--- a/board/ti/beagle/beagle.c
+++ b/board/ti/beagle/beagle.c
@@ -114,6 +114,103 @@ void beagle_identify(void)
+ * Configure DSS to display background color on DVI-D
+ * and color bar on S-video interface
+void dss_init(void)
+ writel(0xfefffedf, 0x48310034); /* GPIO_OE(1) */
+ writel(0x01000120, 0x48310094); /* GPIO_SETDATAOUT(1) */
+ writel(0x0001b00c, 0x48004D44); /* CM_CLKSEL2_PLL */
+ writel(0x00001006, 0x48004E40);
+ writel(0x00370037, 0x48004D00);
+ writel(0x00000002, 0x48050C00);
+ writel(0x0000001B, 0x48050C04);
+ writel(0x00000040, 0x48050C08);
+ writel(0x00000000, 0x48050C0C);
+ writel(0x00000000, 0x48050C10);
+ writel(0x00008000, 0x48050C14);
+ writel(0x00000000, 0x48050C18);
+ writel(0x00008359, 0x48050C1C);
+ writel(0x0000020C, 0x48050C20);
+ writel(0x00000000, 0x48050C24);
+ writel(0x043F2631, 0x48050C28);
+ writel(0x00000024, 0x48050C2C);
+ writel(0x00000130, 0x48050C30);
+ writel(0x00000198, 0x48050C34);
+ writel(0x000001C0, 0x48050C38);
+ writel(0x0000006A, 0x48050C3C);
+ writel(0x0000005C, 0x48050C40);
+ writel(0x00000000, 0x48050C44);
+ writel(0x00000001, 0x48050C48);
+ writel(0x0000003F, 0x48050C4C);
+ writel(0x21F07C1F, 0x48050C50);
+ writel(0x00000000, 0x48050C54);
+ writel(0x00000015, 0x48050C58);
+ writel(0x00001400, 0x48050C5C);
+ writel(0x00000000, 0x48050C60);
+ writel(0x069300F4, 0x48050C64);
+ writel(0x0016020C, 0x48050C68);
+ writel(0x00060107, 0x48050C6C);
+ writel(0x008D034E, 0x48050C70);
+ writel(0x000F0359, 0x48050C74);
+ writel(0x01A00000, 0x48050C78);
+ writel(0x020501A0, 0x48050C7C);
+ writel(0x01AC0024, 0x48050C80);
+ writel(0x020D01AC, 0x48050C84);
+ writel(0x00000006, 0x48050C88);
+ writel(0x00000000, 0x48050C8C);
+ writel(0x03480079, 0x48050C90);
+ writel(0x02040024, 0x48050C94);
+ writel(0x00000000, 0x48050C98);
+ writel(0x00000000, 0x48050C9C);
+ writel(0x0001008A, 0x48050CA0);
+ writel(0x01AC0106, 0x48050CA4);
+ writel(0x01060006, 0x48050CA8);
+ writel(0x00000000, 0x48050CAC);
+ writel(0x00140001, 0x48050CB0);
+ writel(0x00010001, 0x48050CB4);
+ writel(0x00FF0000, 0x48050CB8);
+ writel(0x00000000, 0x48050CBC);
+ writel(0x00000000, 0x48050CC0);
+ writel(0x0000000D, 0x48050CC4);
+ writel(0x00000000, 0x48050CC8);
+ writel(0x00000001, 0x48050010);
+ writel(0x00000078, 0x48050040);
+ writel(0x00000000, 0x48050044);
+ writel(0x00000000, 0x48050048);
+ writel(0x00000000, 0x48050050);
+ writel(0x00000000, 0x48050058);
+ writel(0x00002015, 0x48050410);
+ writel(0x00000001, 0x48050414);
+ writel(0x00000004, 0x48050444);
+ writel(0x00FF8000, 0x4805044c);
+ writel(0x00000000, 0x48050450);
+ writel(0x00000000, 0x48050454);
+ writel(0x00000000, 0x48050458);
+ writel(0x0ff03f31, 0x48050464);
+ writel(0x01400504, 0x48050468);
+ writel(0x00007028, 0x4805046c);
+ writel(0x00010002, 0x48050470);
+ writel(0x00ef027f, 0x48050478);
+ writel(0x02cf04ff, 0x4805047c);
+ writel(0x00000000, 0x48050488);
+ writel(0x02cf04ff, 0x4805048c);
+ writel(0x00000000, 0x480504a0);
+ writel(0x03fc03bc, 0x480504a4);
+ writel(0x00000400, 0x480504a8);
+ writel(0x00000001, 0x480504ac);
+ writel(0x00000001, 0x480504b0);
+ writel(0x00000000, 0x480504b4);
+ writel(0x807ff000, 0x480504b8);
+ writel(0x0001836b, 0x48050440);
I wonder if mainline will accept this at all. And what's their comment on all these hard coded values. Most probably, the comment will be "don't use hard coded values, convert to more obvious macros" and "access registers by structs". But let's see...
Why this?
* Routine: misc_init_r
* Description: Configure board specific parts
@@ -122,6 +219,7 @@ int misc_init_r(void)
struct gpio *gpio5_base = (struct gpio *)OMAP34XX_GPIO5_BASE;
struct gpio *gpio6_base = (struct gpio *)OMAP34XX_GPIO6_BASE;+ dss_init();
beagle_identify();twl4030_power_init();
@@ -144,6 +242,9 @@ int misc_init_r(void)
GPIO15 | GPIO14 | GPIO13 | GPIO12,&gpio5_base->setdataout);dieid_num_r();
+ /* Enable DSS */
Why isn't "Enable DSS" done in dss_init()? And why isn't it done immediately after dss_init()?
Best regards
Dirk
+}I wonder if mainline will accept this at all. And what's their comment on
Can you point me to some example on how to do similar stuff using
structures, I don't mind changing them. Values can be made as a single
macros.
+Why this?
Not sure ... will check this.
beagle_identify();twl4030\_power\_init\(\);
GPIO15 | GPIO14 | GPIO13 | GPIO12,&gpio5_base->setdataout);dieid\_num\_r\(\);
+ /* Enable DSS */
+ writel(0x0001836b, 0x48050440);Why isn't "Enable DSS" done in dss_init()? And why isn't it done immediately
after dss_init()?
Actually while using framebuffer an immediate write to enable DSS was
not working, but giving it after some always worked. That is the main
reason, didn't really spend time to understand why shadow registers
were not getting updated immediately.
Any way all these patches are independent, we can rework individually.
This time I want to get these upstream and avoid a fork on gitorious.
Khasim
See the patch itself
E.g.:
writel( value,&gpio5_base->setdataout);
Best regards
Dirk
