* Decrease bootdelay to 3, use VGA for default resolution
* Add CONFIG_SYS_MEMTEST_SCRATCH to point to a scratch memory area.
* Enable LEDs
Added LED driver using status_led. USR0 is set to monitor the boot
status. USR1 is set to be the GREEN LED.
* Remove omapfb.debug=y from default env
* Add camera to default bootargs
* Move ramdisk parameters. This will make it easier to reprogram the ramdisk size.
* Improved boot env var setting
* Enabled evaluation of expressions with 'setexpr'
* Made room for a 64MB ramdisk by moving from 0x81600000 to 0x81000000
* Removed expression from 'ramroot' that wouldn't be evaluated
* Doubled console I/O buffer size from 256 to 512
* Doubled maximum command arguments size from 16 to 32
* Enable multibus support for I2C
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
