[PATCH] BeagleBoard: Added LED driver
Added LED driver using status_led. USR0 is set to monitor the boot
status. USR1 is set to be the green LED.
(cherry picked from commit 048b526fd7cc0c642f27c674b3e235321c880b66)
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
[mailto:u-boot-bounces@lists.denx.de] On Behalf Of Jason Kridner
Sent: Friday, November 05, 2010 11:23 AM
To: u-boot@lists.denx.de; beagleboard@googlegroups.com
Subject: [U-Boot] [PATCH] BeagleBoard: Added LED driver
board/ti/beagle/Makefile | 4 ++-
board/ti/beagle/beagle.c | 7 ++++
board/ti/beagle/led.c | 91
3 files changed, 101 insertions(+), 1 deletions(-)
create mode 100644 board/ti/beagle/led.c
diff --git a/board/ti/beagle/Makefile b/board/ti/beagle/Makefile
index f797112..4cc675c 100644
--- a/board/ti/beagle/Makefile
+++ b/board/ti/beagle/Makefile
@@ -25,8 +25,10 @@ include $(TOPDIR)/config.mk
LIB = $(obj)lib$(BOARD).a
-COBJS := beagle.o
+COBJS-y := $(BOARD).o
+COBJS-$(CONFIG_STATUS_LED) += led.o
+COBJS := $(sort $(COBJS-y))
SRCS := $(COBJS:.o=.c)
OBJS := $(addprefix $(obj),$(COBJS))
diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c
index 93c452e..dd7b6b5 100644
--- a/board/ti/beagle/beagle.c
+++ b/board/ti/beagle/beagle.c
@@ -30,6 +30,9 @@
  * MA 02111-1307 USA
#include <common.h>
+#ifdef CONFIG_STATUS_LED
+#include <status_led.h>
+#endif
#include <twl4030.h>
#include <asm/io.h>
#include <asm/arch/mmc_host_def.h>
@@ -78,6 +81,10 @@ int board_init(void)
   /* boot param addr */
   gd->bd->bi_boot_params = (OMAP34XX_SDRC_CS0 + 0x100);
+#if defined(CONFIG_STATUS_LED) && defined(STATUS_LED_BOOT)
+ status_led_set (STATUS_LED_BOOT, STATUS_LED_ON);
+#endif
   return 0;
diff --git a/board/ti/beagle/led.c b/board/ti/beagle/led.c
new file mode 100644
index 0000000..df26552
--- /dev/null
+++ b/board/ti/beagle/led.c
@@ -0,0 +1,91 @@
+ * Copyright (c) 2010 Texas Instruments, Inc.
+ * Jason Kridner <jkridner@beagleboard.org>
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License as
+ * published by the Free Software Foundation; either version 2 of
+ * the License, or (at your option) any later version.
+ * This program is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with this program; if not, write to the Free Software
+ * Foundation, Inc., 59 Temple Place, Suite 330, Boston,
+ * MA 02111-1307 USA
+#include <common.h>
+#include <asm/arch/cpu.h>
+#include <asm/io.h>
+#include <asm/arch/sys_proto.h>
+#include <asm/arch/gpio.h>
+static unsigned int saved_state[2] = {STATUS_LED_OFF,
STATUS_LED_OFF};
+/* GPIO pins for the LEDs */
+#define BEAGLE_LED_USR0 149
+#define BEAGLE_LED_USR1 150
+#ifdef STATUS_LED_GREEN
+void green_LED_off (void)
+ __led_set (STATUS_LED_GREEN, 0);
+void green_LED_on (void)
+ __led_set (STATUS_LED_GREEN, 1);
+#endif
+void __led_init (led_id_t mask, int state)
+ __led_set (mask, state);
+void __led_toggle (led_id_t mask)
+#ifdef STATUS_LED_BIT
+ if (STATUS_LED_BIT & mask) {
+ if (STATUS_LED_ON == saved_state[0])
+ __led_set(STATUS_LED_BIT, 0);
+ else
+ __led_set(STATUS_LED_BIT, 1);
+#endif
+#ifdef STATUS_LED_BIT1
+ if (STATUS_LED_BIT1 & mask) {
+ if (STATUS_LED_ON == saved_state[1])
+ __led_set(STATUS_LED_BIT1, 0);
+ else
+ __led_set(STATUS_LED_BIT1, 1);
+#endif
+void __led_set (led_id_t mask, int state)
+ if (!omap_request_gpio(BEAGLE_LED_USR0)) {
+ omap_set_gpio_direction(BEAGLE_LED_USR0, 0);
+ omap_set_gpio_dataout(BEAGLE_LED_USR0, state);
+ saved_state[0] = state;
+#endif
+ if (!omap_request_gpio(BEAGLE_LED_USR1)) {
+ omap_set_gpio_direction(BEAGLE_LED_USR1, 0);
+ omap_set_gpio_dataout(BEAGLE_LED_USR1, state);
+ saved_state[1] = state;
+#endif
[sp] I see too many ifdef blocks in the code above. The also seems to be
     repetitive.
     Is user really expected to change the u-boot config for each LED bit/color?
     Can this be simplified by one function that takes an argument?
     Should reduce code and ifdefs - if at all - get confined to one function.
~sanjeev
-COBJS := beagle.o
@@ -30,6 +30,9 @@
* MA 02111-1307 USA
#include <common.h>
+#endif
#include <asm/io.h>
+#endif
return 0;
--- /dev/null
@@ -0,0 +1,91 @@
STATUS_LED_OFF};
+#endif
+ else
+#endif
+ else
+#endif
+#endif
+#endif
repetitive.
Is user really expected to change the u\-boot config for each LED bit/color?
This is the existing architecture in status_led.h. I want to make
sure this code compiles no matter which of the defines have been set.
Do you mean set vs. toggle? I think that would be great too, but
again following an existing definition.
Should reduce code and ifdefs \- if at all \- get confined to one function\.
Do you have any proposal on how to do so? Personally, I'd be inclined
to eliminate the colors all together and have 2 values that can be
ignored/rejected by the functions if not supported: LED # (an ID) and
an integral value (could be brightness or color). Also, I'd be happy
with simply having a set value function and having the rest of the
system monitor the state (rather than having a toggle method).
Thoughts?
Dear Jason Kridner,
