Added LED driver using status_led. USR0 is set to monitor the boot
status. USR1 is set to be the green LED.
Included adding configuration and command to the default configuration.
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Hi jason,
status. USR1 is set to be the green LED.Included adding configuration and command to the default configuration.
Pushed to u-boot-ti
Dear Jason Kridner,
+#ifdef STATUS_LED_GREEN
+void green_LED_off (void)
+void green_LED_on (void)
We doin't allow CamelCase identifiers.
+ if (!omap_request_gpio(BEAGLE_LED_USR0)) {
+ omap_set_gpio_direction(BEAGLE_LED_USR0, 0);
+ omap_set_gpio_dataout(BEAGLE_LED_USR0, state);
Should you not set dataout _before_ direction? As is, you may drive
the wrong output value for a short time.
+ if (!omap_request_gpio(BEAGLE_LED_USR1)) {
+ omap_set_gpio_direction(BEAGLE_LED_USR1, 0);
+ omap_set_gpio_dataout(BEAGLE_LED_USR1, state);
Ditto.
