There is a v2011.09 tag on the mainline, but I haven't seen a release
notice go out. It didn't make sense to me to try to carry-forward those
all patches since the release tag, so I simply picked the latest tag
in the maineline.
Patched and tested on BeagleBoard-xM revision C.
USB Ethernet was tested with:
setenv usbethaddr de:ad:be:ef:00:01
usb start
dhcp^C
setenv ipaddr 10.0.1.2
ping 10.0.1.1
USB Storage was tested with:
<above>
usb part
fatls usb 0
led command was tested with:
led all off
led all on
led 1 on
led 1 off
gpio command tested with:
gpio input 4
<hold USER button>
gpio input 4
<release USER button>
Also performed boot test.
Signed-off-by: Jason Kridner <jdk@ti.com>
Do all 3 needs to be off or only the d cache?
I don't have time to test that variation right now, I was just pulling
off of what Joel suggested. I can try to get to that later in the
week. Joel, do you know?
I think you had some concerns about the questions my PV choice would
make. I don't feel strongly about it. Do you want to fix it up or
shall I submit a v2?
Hi Jason, Koen,
in the maineline.
++/* TODO: WORK-AROUND for bug in BeagleBoard-specific USB */
++#define CONFIG_SYS_ICACHE_OFF
++#define CONFIG_SYS_DCACHE_OFF
++#define CONFIG_SYS_L2CACHE_OFF
Disabling only D-cache hangs U-boot. Disabling both I and D while
leaving L2 cache as is fixes it.
I'll resubmit Jason's meta-ti patch with only I and D cache disabled,
but I can't find a discussion about what the PV choice issue is? Let
me know and I'll make both these changes and resubmit.
Joel
Call the recipe uboot_2011.09.bb, remove the PV assignment inside, but keep the comment about being a few commits ahead of the tag.
regards,
Koen
Hi Jason, Koen,
in the maineline.
PV should be normal, without any trailing numbers.
I'm not sure why I didn't see Koen's comment earlier. I'm hopeful you
are following it:
Are you sure that's Uboot without the dash? I've kept the dash as
other u-boot recipes have it.
Joel
Thanks. It should be like the others. And it seems it is still an -rc.
