[PATCH-OMAP3] (v2) Modified pinmux to enable HSUSB2 (EHCI) on Beagle.
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
I guess the v2 really should have gone into the brackets. Still getting used to this 'git' + mailing list stuff, but I like it. Let me know if I need to regenerate the patch again. Perhaps Sakoman needs to comment again, since this patch applies to a newer version of his tree.
board/omap3/beagle/beagle.h | 70 ++++++++++++++++++++++---------------------
1 files changed, 36 insertions(+), 34 deletions(-)
diff --git a/board/omap3/beagle/beagle.h b/board/omap3/beagle/beagle.h
index 33d0eab..fba949c 100644
--- a/board/omap3/beagle/beagle.h
+++ b/board/omap3/beagle/beagle.h
@@ -116,15 +116,13 @@ const omap3_sysinfo sysinfo = {
MUX_VAL(CP(GPMC_NCS1), (IDIS | PTU | EN | M0)) /*GPMC_nCS1*/\
MUX_VAL(CP(GPMC_NCS2), (IDIS | PTU | EN | M0)) /*GPMC_nCS2*/\
MUX_VAL(CP(GPMC_NCS3), (IDIS | PTU | EN | M0)) /*GPMC_nCS3*/\
- /* For Beagle Rev 2 boards*/\
- MUX_VAL(CP(GPMC_NCS4), (IDIS | PTU | EN | M0))\
- MUX_VAL(CP(GPMC_NCS5), (IDIS | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_NCS6), (IEN | PTD | DIS | M1))\
- MUX_VAL(CP(GPMC_NCS7), (IEN | PTU | EN | M1))\
- MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0))\
- MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M0))\
- MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M0))\
- /* till here */\
+ MUX_VAL(CP(GPMC_NCS4), (IDIS | PTU | EN | M0)) /*GPMC_nCS4*/\
+ MUX_VAL(CP(GPMC_NCS5), (IDIS | PTD | DIS | M0)) /*GPMC_nCS5*/\
+ MUX_VAL(CP(GPMC_NCS6), (IEN | PTD | DIS | M1)) /*GPMC_nCS6*/\
+ MUX_VAL(CP(GPMC_NCS7), (IEN | PTU | EN | M1)) /*GPMC_nCS7*/\
+ MUX_VAL(CP(GPMC_NBE1), (IEN | PTD | DIS | M0)) /*GPMC_nBE1*/\
+ MUX_VAL(CP(GPMC_WAIT2), (IEN | PTU | EN | M0)) /*GPMC_WAIT2*/\
+ MUX_VAL(CP(GPMC_WAIT3), (IEN | PTU | EN | M0)) /*GPMC_WAIT3*/\
MUX_VAL(CP(GPMC_CLK), (IDIS | PTD | DIS | M0)) /*GPMC_CLK*/\
MUX_VAL(CP(GPMC_NADV_ALE), (IDIS | PTD | DIS | M0)) /*GPMC_nADV_ALE*/\
MUX_VAL(CP(GPMC_NOE), (IDIS | PTD | DIS | M0)) /*GPMC_nOE*/\
@@ -223,7 +221,7 @@ const omap3_sysinfo sysinfo = {
MUX_VAL(CP(UART2_CTS), (IEN | PTU | EN | M0)) /*UART2_CTS*/\
MUX_VAL(CP(UART2_RTS), (IDIS | PTD | DIS | M0)) /*UART2_RTS*/\
MUX_VAL(CP(UART2_TX), (IDIS | PTD | DIS | M0)) /*UART2_TX*/\
- MUX_VAL(CP(UART2_RX), (IEN | PTD | DIS | M0)) /*UART2_RX*/\
+ MUX_VAL(CP(UART2_RX), (IDIS | PTD | DIS | M4)) /*GPIO_147*/\
/*Modem Interface */\
MUX_VAL(CP(UART1_TX), (IDIS | PTD | DIS | M0)) /*UART1_TX*/\
MUX_VAL(CP(UART1_RTS), (IDIS | PTD | DIS | M4)) /*GPIO_149*/ \
@@ -260,26 +258,32 @@ const omap3_sysinfo sysinfo = {
MUX_VAL(CP(HSUSB0_DATA7), (IEN | PTD | DIS | M0)) /*HSUSB0_DATA7*/\
MUX_VAL(CP(I2C1_SCL), (IEN | PTU | EN | M0)) /*I2C1_SCL*/\
MUX_VAL(CP(I2C1_SDA), (IEN | PTU | EN | M0)) /*I2C1_SDA*/\
- MUX_VAL(CP(I2C2_SCL), (IEN | PTU | EN | M4)) /*GPIO_168*/\
+ MUX_VAL(CP(I2C2_SCL), (IDIS | PTU | DIS | M4)) /*GPIO_168*/\
MUX_VAL(CP(I2C2_SDA), (IEN | PTU | EN | M4)) /*GPIO_183*/\
MUX_VAL(CP(I2C3_SCL), (IEN | PTU | EN | M0)) /*I2C3_SCL*/\
MUX_VAL(CP(I2C3_SDA), (IEN | PTU | EN | M0)) /*I2C3_SDA*/\
MUX_VAL(CP(I2C4_SCL), (IEN | PTU | EN | M0)) /*I2C4_SCL*/\
MUX_VAL(CP(I2C4_SDA), (IEN | PTU | EN | M0)) /*I2C4_SDA*/\
MUX_VAL(CP(HDQ_SIO), (IDIS | PTU | EN | M4)) /*GPIO_170*/\
- MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | DIS | M0)) /*McSPI1_CLK*/\
- MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | DIS | M0)) /*McSPI1_SIMO*/\
+ MUX_VAL(CP(MCSPI1_CLK), (IEN | PTD | EN | M4)) /*GPIO_171*/\
+ MUX_VAL(CP(MCSPI1_SIMO), (IEN | PTD | EN | M4)) /*GPIO_172*/\
MUX_VAL(CP(MCSPI1_SOMI), (IEN | PTD | DIS | M0)) /*McSPI1_SOMI*/\
MUX_VAL(CP(MCSPI1_CS0), (IEN | PTD | EN | M0)) /*McSPI1_CS0*/\
MUX_VAL(CP(MCSPI1_CS1), (IDIS | PTD | EN | M0)) /*McSPI1_CS1*/\
- MUX_VAL(CP(MCSPI1_CS2), (IDIS | PTD | DIS | M4)) /*GPIO_176*/\
- /* - NOR_DPD*/\
- MUX_VAL(CP(MCSPI1_CS3), (IEN | PTD | EN | M0)) /*McSPI1_CS3*/\
- MUX_VAL(CP(MCSPI2_CLK), (IEN | PTD | DIS | M0)) /*McSPI2_CLK*/\
- MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTD | DIS | M0)) /*McSPI2_SIMO*/\
- MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTD | DIS | M0)) /*McSPI2_SOMI*/\
- MUX_VAL(CP(MCSPI2_CS0), (IEN | PTD | EN | M0)) /*McSPI2_CS0*/\
- MUX_VAL(CP(MCSPI2_CS1), (IEN | PTD | EN | M0)) /*McSPI2_CS1*/\
+ MUX_VAL(CP(MCSPI1_CS2), (IDIS | PTU | DIS | M3)) /*MMC3_CLK*/\
+ /* USB EHCI (port 2) */\
+ MUX_VAL(CP(MCSPI1_CS3), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA2*/\
+ MUX_VAL(CP(MCSPI2_CLK), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA7*/\
+ MUX_VAL(CP(MCSPI2_SIMO), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA4*/\
+ MUX_VAL(CP(MCSPI2_SOMI), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA5*/\
+ MUX_VAL(CP(MCSPI2_CS0), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA6*/\
+ MUX_VAL(CP(MCSPI2_CS1), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA3*/\
+ MUX_VAL(CP(ETK_D10_ES2), (IDIS | PTU | DIS | M3)) /*HSUSB2_CLK*/\
+ MUX_VAL(CP(ETK_D11_ES2), (IDIS | PTU | DIS | M3)) /*HSUSB2_STP*/\
+ MUX_VAL(CP(ETK_D12_ES2), (IEN | PTU | DIS | M3)) /*HSUSB2_DIR*/\
+ MUX_VAL(CP(ETK_D13_ES2), (IEN | PTU | DIS | M3)) /*HSUSB2_NXT*/\
+ MUX_VAL(CP(ETK_D14_ES2), (IEN | PTU | DIS | M3)) /*HSUSB2_DATA0*/\
+ MUX_VAL(CP(ETK_D15_ES2), (IEN | PTU | EN | M3)) /*HSUSB2_DATA1*/\
Shouldn't the above line be DIS rather than EN?
Steve
- /* till here */\
Hard to see in this style. I used an other tool, this are only comment changes. ACK.
ACK
Hmm, why this change? GPIO 168 and 183 go both to expansion connector? Why then change GPIO 168? Why not have both pins configured the same way?
In my board detection patch I selected PTU for this. It's the job of the *external* pull down on rev C to pull this pin down? Else we would detect a low on rev A and B, too?
This conflicts with my Beagle revision detection patch, btw.
This isn't necessary for rev C. rev C is only detected by GPIO 171 low, 172 isn't used (or at least pull down doesn't work and pin is high, so this doesn't matter)
- /* - NOR_DPD*/\
Why this? MCSPI1_CS2 pin isn't connected?
I suggest you use GPIO_172. While not currently used, it could be used in the future. All I have to do is add it to the BOM and it is there. We may end up using this to, shall we say, indicate the next revsion of the Beagle.
On the expansion pins, please keep in mind that three signals change on the REV C2, requiring the mux to change as well.
