Patch RevC SPI3,SPI4,UART2
I am trying to figure out how to make the SPI3, SPI4 and UART2 work on
the expension port of the RevC3 BeagleBoard. I made a patch file based
on the work of Philip Balister <philip@balister.org> for the RevB7,
0001-Changes-to-make-MCSPI3-work-on-the-Beagle-Board-expa.patch. I am
using OE and the patch file I created works if I split it but when
putted together I got an error.
Thank you for any help you could give me.
IATRIDES Clément
PATCH_SPI_OE.patch (8.77 KB)
Please keep in mind that some of the signal changed on the expansion connector between rev B7 and Rev C2. Make sure you check these changes in the System Reference Manual. http://beagleboard.org/static/BBSRM_latest.pdf
No signals were removed, but the mux settings and pins did change on three signals,
2009/6/4 Clément IATRIDES <clement.iatrides@gmail.com>
I made teh modification on the pin mux for the revC according to the
new System Reference Manual (but they might be sommes errors). My
problem is mostly getting the patch file patch correctly.
"patching file recipes/linux/linux-omap-2.6.29/beagleboard/spi-test.patch
patch: **** malformed patch at line 210:"
Clement IATRIDES
I made the modification on the pin mux for the revC according to the
IATRIDES Clément
