Patch series to add OMAP3 EVM support to Sakoman's u-boot Tree
Sent this fix, too. And got immediately a response pointing to a larger
patch for this. I didn't follow this autostart discussion, but seems that
there is something additional broken. E.g. apollon build stops with
bootm.c: In function 'do_bootm_linux':
bootm.c:140: error: 'bootm_headers_t' has no member named 'autostart'
bootm.c:160: error: 'bootm_headers_t' has no member named 'autostart'
Let us see which solution Wolfgang will take.
Yes, I got the same error on overo and beagle. At that point I
decided to let Wolfgang fix it :slight_smile:
Steve
Dirk Behme wrote:
Steve,
Steve Sakoman wrote:
Dirk,
I see the patch has already be accepted upstream. Good work!
You might also want to consider submitting this one:
http://www.sakoman.net/cgi-bin/gitweb.cgi?p=u-boot-omap3.git;a=commit;h=8406a19891788a3d86f6d20d6c3fa64e6db71616
Done.
Applied:
I merged with upstream -- sadly one of the upstream commits (actually
a revert) broke the build. It introduces an extra #endif.
I'm testing a patch to fix this.
Sent this fix, too. And got immediately a response pointing to a larger patch for this. I didn't follow this autostart discussion, but seems that there is something additional broken. E.g. apollon build stops with
Kumar Gala's "Fix fallout from autostart revert" patch is applied, too. Have to check if recent git compiles now.
Dirk
