[PATCH] To get NAND BB working on Latest u-boot
Patch to get NAND Bad Block Management working for both SW and HW ecc
Signed-off-by: Syed Mohammed Khasim <khasim@beagleboard.org>
hand applied and checked against zoom:
OMAP3 Zoom1# nand bad
Device 0 bad blocks:
  00160000
  02980000
  029a0000
  02da0000
  04b40000
  058e0000
  05c40000
  08120000
  08300000
  085c0000
  08a00000
  090c0000
  0bc00000
  0cd60000
  0d380000
  0d3a0000
  0df80000
OMAP3 Zoom1# nandecc hw
HW ECC selected
OMAP3 Zoom1# nand erase 0 80000
NAND erase: device 0 offset 0x0, size 0x80000
Erasing at 0x0 -- 25% complete.
NAND 256MiB 1,8V 16-bit: MTD Erase failure: -5
OK
OMAP3 Zoom1# nandecc sw
SW ECC selected
OMAP3 Zoom1# nand unlock
device 0 whole chip
OK
HW ECC selected
OK
OMAP3 Zoom1#
It just did not work for me.. I suppose I do need unlock here.. will
test against beagle at home..
Nishanth Menon
For Beagle, you don't need an unlock
The below patch should be good, as it avoids the memory leak and works
for both hw and sw ecc
Signed-off-by: Syed Mohammed Khasim <khasim@ti.com>
Khasim,
Syed Mohammed, Khasim wrote:
From: Nishanth Menon [mailto:menon.nishanth@gmail.com]
Sent: Wednesday, December 10, 2008 10:03 PM
To: Syed Mohammed, Khasim
Cc: Dirk Behme; Steve Sakoman; Jason Kridner; Pandita, Vikram; Menon, Nishanth
Subject: Re: [PATCH] To get NAND BB working on Latest u-boot
Nishanth Menon said the following on 12/10/2008 05:42 PM:
<snip>
--- u-boot-arm/drivers/mtd/nand/omap_gpmc.c 2008-12-08
11:06:46.000000000 +0530
+++ u-boot-bb/drivers/mtd/nand/omap_gpmc.c 2008-12-11
16:50:35.000000000 +0530
@@ -249,11 +249,7 @@ void omap_nand_switch_ecc(int32_t hardwa
        mtd = &nand_info[nand_curr_device];
        nand = mtd->priv;
- /* clean up allocated buffers */
- nand_release(mtd);
- /* Switch back to the original value, mark me unscanned */
- nand->options = NAND_NO_PADDING | NAND_CACHEPRG | NAND_NO_AUTOINCR |
- NAND_NO_AUTOINCR;
+ nand->options = NAND_OWN_BUFFERS | NAND_BBT_SCANNED;
        /* Reset ecc interface */
        nand->ecc.read_page = NULL;
First thanks for finding the root cause of the issues!
Do you like to test slightly reworked patch in attachment?
Ideas in this patch:
- board_nand_init() sets initial nand->options. Seems we used NAND_NO_AUTOINCR twice :frowning:
- In omap_nand_switch_ecc() don't set the same options (with same wrong NAND_NO_AUTOINCR done twice) again. I.e. remove them.
- Don't touch initial options, set NAND_OWN_BUFFERS | NAND_BBT_SCANNED *additionally* ("|=")
=> To be tested with some printf debugging: Is NAND_BBT_SCANNED already set here, so we don't have to touch it here?
- Before omap_nand_switch_ecc() exit, un-set NAND_OWN_BUFFERS again to be on the safe side. In case somebody later intentionally calls nand_release(), we want to free the buffer.
=> To be tested with some printf debugging: Does nand_scan_tail() modifiy NAND_BBT_SCANNED? I.e. how is NAND_BBT_SCANNED set if we set/don't set it manually above, before calling nand_scan_tail().
Best regards
Dirk
0001_nandbb.txt (1.4 KB)
Dirk Behme wrote:
Khasim,
<snip>
        nand = mtd->priv;
- NAND_NO_AUTOINCR;
Updated, final, tested patch in attachment.
Steve: If you like, please apply.
Best regards
Dirk
Btw: For the archives log of final testing:
http://www.beagleboard.org/irclogs/index.php?date=2008-12-12#T15:29:21
0001_nandbb.txt (2.23 KB)
