[PATCH v2] BeagleBoard: Remove userbutton command and use gpio command instead
Remove userbutton command and do the detection in board config file using the gpio command
Signed-off-by: Joel A Fernandes <agnel.joel@gmail.com>
Signed-off-by: Jason Kridner <jkridner@beagleboard.org>
Can you split these into two or three patches? I'm not sure what is
normal, but I suspect that this is one of those things where you
should remove a feature in one patch then add a replacement with
another, rather than doing both in one patch. In general, I would add
the replacement functionality before removing the old command.
More comments below...
This addresses the suggestions at: http://patchwork.ozlabs.org/patch/110123/
Also, with the removal of the userbutton command, all checkpatch errors are automatically fixed.
v2 changes:
Corrected comment about userbutton
board/ti/beagle/beagle.c | 55 ----------------------------------------
include/configs/omap3_beagle.h | 11 ++++++-
2 files changed, 9 insertions(+), 57 deletions(-)
diff --git a/board/ti/beagle/beagle.c b/board/ti/beagle/beagle.c
index 8cdceaf..9ce8aeb 100644
--- a/board/ti/beagle/beagle.c
+++ b/board/ti/beagle/beagle.c
@@ -479,58 +479,3 @@ int ehci_hcd_init(void)
#endif /* CONFIG_USB_EHCI */
- * This command returns the status of the user button on beagle xM
- * Input - none
- * Returns - 1 if button is held down
- * 0 if button is not held down
-int do_userbutton (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[])
- int button = 0;
- int gpio;
- * pass address parameter as argv[0] (aka command name),
- * and all remaining args
- switch (get_board_revision()) {
- case REVISION_AXBX:
- case REVISION_CX:
- case REVISION_C4:
- gpio = 7;
- break;
- case REVISION_XM_A:
- case REVISION_XM_B:
- case REVISION_XM_C:
- default:
- gpio = 4;
- break;
- gpio_request(gpio, "");
- gpio_direction_input(gpio);
- printf("The user button is currently ");
- if (gpio_get_value(gpio))
- button = 1;
- printf("PRESSED.\n");
- else
- button = 0;
- printf("NOT pressed.\n");
- gpio_free(gpio);
- return !button;
-U_BOOT_CMD(
- userbutton, CONFIG_SYS_MAXARGS, 1, do_userbutton,
- "Return the status of the BeagleBoard USER button",
diff --git a/include/configs/omap3_beagle.h b/include/configs/omap3_beagle.h
index 1369c89..0cf81a6 100644
--- a/include/configs/omap3_beagle.h
+++ b/include/configs/omap3_beagle.h
@@ -164,6 +164,7 @@
#define CONFIG_CMD_PING
#define CONFIG_CMD_DHCP
#define CONFIG_CMD_SETEXPR /* Evaluate expressions */
+#define CONFIG_CMD_GPIO /* Enable gpio command */
#undef CONFIG_CMD_FLASH /* flinfo, erase, protect */
#undef CONFIG_CMD_FPGA /* FPGA configuration Support */
@@ -277,10 +278,16 @@
"ramboot=echo Booting from ramdisk ...; " \
"run ramargs; " \
"bootm ${loadaddr}\0" \
+ "userbutton=if gpio input 173; then run userbutton_xm; " \
+ "else run userbutton_nonxm; fi;\0" \
There is an environment variable called 'beaglerev'. Is there an easy
way to use it?
Hi Jason,
Sure
way to use it?
Something like [1] would work? I'll try it out. Thanks
Joel
[1] http://lists.linuxtogo.org/pipermail/openembedded-commits/2010-June/047925.html
I’m interested in understanding what this patch does.
Is it making it so that the user button will no longer provide a keyboard like event in the linux kernel?
I’m also interested in knowing the details of the items I see with the [PATCH] subject. Are they part of the general ARM port for the linux kernel and may show up in future releases from the kernel.org kernel release?
Thanks for any clarification.
Wim.
This is a different project called U-boot, it is a boot loader
