[PATCH v6 1/2] Add driver for Aptina (Micron) mt9p031 sensor.
Clock frequency of 57MHz used in previous version was wrong since
when VDD_IO is 1.8V it can only support 48MHz.
Two new platform flags have been added:
- vdd_io: indicates whether the chip is powered with 1.8 or 2.8 VDD_IO.
So that it can use the maximum allowed frequency.
- version: monochrome and color versions of the chip have exactly
the same ID, so the only way to select one of them is through
platform data.
Internal PLL is now used to generate PIXCLK depending on VDD_IO.
Signed-off-by: Javier Martin <javier.martin@vista-silicon.com>
New "version" and "vdd_io" flags have been added.
A subtle change now prevents camera from being registered
in the wrong platform.
I get a decent picture now with the following:
media-ctl -r -l '"mt9p031 2-0048":0->"OMAP3 ISP CCDC":0[1], "OMAP3 ISP CCDC":1->"OMAP3 ISP CCDC output":0[1]'
media-ctl -f '"mt9p031 2-0048":0[SGRBG12 320x240], "OMAP3 ISP CCDC":0[SGRBG8 320x240], "OMAP3 ISP CCDC":1[SGRBG8 320x240]'
yavta-nc --stdout -f SGRBG8 -s 320x240 -n 4 --capture=10000 --skip 3 -F $(media-ctl -e "OMAP3 ISP CCDC output") | mplayer-bayer - -demuxer rawvideo -rawvideo w=320:h=240:format=ba81:size=76800 -vo fbdev2 -vf ba81
720p also seems to work.
It is really, really dark though. Is this due to missing controls or due to the laneshifting?
regards,
Koen
Hi Koen,
No technical review this time. Relying fully on Laurent and others to take
care of that, just a couple of cosmetic points, which even checkpatch.pl
failed to warn about:(
platform data.
drivers/media/video/Kconfig | 7 +
drivers/media/video/Makefile | 1 +
drivers/media/video/mt9p031.c | 763 +++++++++++++++++++++++++++++++++++++++++
include/media/mt9p031.h | 23 ++
4 files changed, 794 insertions(+), 0 deletions(-)
create mode 100644 drivers/media/video/mt9p031.c
create mode 100644 include/media/mt9p031.h
diff --git a/drivers/media/video/Kconfig b/drivers/media/video/Kconfig
index 00f51dd..cb87e35 100644
--- a/drivers/media/video/Kconfig
+++ b/drivers/media/video/Kconfig
@@ -329,6 +329,13 @@ config VIDEO_OV7670
     OV7670 VGA camera. It currently only works with the M88ALP01
     controller.
+config VIDEO_MT9P031
+ tristate "Aptina MT9P031 support"
+ depends on I2C && VIDEO_V4L2
+ ---help---
+ This is a Video4Linux2 sensor-level driver for the Aptina
+ (Micron) mt9p031 5 Mpixel camera.
Please, use TABs, not spaces
config VIDEO_MT9V011
   tristate "Micron mt9v011 sensor support"
diff --git a/drivers/media/video/Makefile b/drivers/media/video/Makefile
index ace5d8b..912b29b 100644
--- a/drivers/media/video/Makefile
+++ b/drivers/media/video/Makefile
@@ -65,6 +65,7 @@ obj-$(CONFIG_VIDEO_UPD64083) += upd64083.o
obj-$(CONFIG_VIDEO_OV7670) += ov7670.o
obj-$(CONFIG_VIDEO_TCM825X) += tcm825x.o
obj-$(CONFIG_VIDEO_TVEEPROM) += tveeprom.o
+obj-$(CONFIG_VIDEO_MT9P031) += mt9p031.o
obj-$(CONFIG_VIDEO_MT9V011) += mt9v011.o
obj-$(CONFIG_VIDEO_SR030PC30) += sr030pc30.o
obj-$(CONFIG_VIDEO_NOON010PC30) += noon010pc30.o
diff --git a/drivers/media/video/mt9p031.c b/drivers/media/video/mt9p031.c
new file mode 100644
index 0000000..cd830b1
--- /dev/null
+++ b/drivers/media/video/mt9p031.c
@@ -0,0 +1,763 @@
+ * Driver for MT9P031 CMOS Image Sensor from Aptina
+ * Based on the MT9V032 driver and Bastian Hecht's code.
+ * This program is free software; you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License version 2 as
+ * published by the Free Software Foundation.
+#include <linux/delay.h>
+#include <linux/device.h>
+#include <linux/i2c.h>
+#include <linux/log2.h>
+#include <linux/pm.h>
+#include <linux/slab.h>
+#include <media/v4l2-subdev.h>
+#include <linux/videodev2.h>
+#include <media/mt9p031.h>
+#include <media/v4l2-chip-ident.h>
+#include <media/v4l2-device.h>
+#define MT9P031_EXTCLK_FREQ 20000000
+#define MT9P031_CHIP_VERSION 0x00
+#define MT9P031_CHIP_VERSION_VALUE 0x1801
+#define MT9P031_ROW_START 0x01
+#define MT9P031_ROW_START_MIN 1
+#define MT9P031_ROW_START_MAX 2004
+#define MT9P031_ROW_START_DEF 54
+#define MT9P031_COLUMN_START 0x02
+#define MT9P031_COLUMN_START_MIN 1
+#define MT9P031_COLUMN_START_MAX 2750
+#define MT9P031_COLUMN_START_DEF 16
+#define MT9P031_WINDOW_HEIGHT 0x03
+#define MT9P031_WINDOW_HEIGHT_MIN 2
+#define MT9P031_WINDOW_HEIGHT_MAX 2003
+#define MT9P031_WINDOW_HEIGHT_DEF 2003
+#define MT9P031_WINDOW_WIDTH 0x04
+#define MT9P031_WINDOW_WIDTH_MIN 18
+#define MT9P031_WINDOW_WIDTH_MAX 2751
+#define MT9P031_WINDOW_WIDTH_DEF 2751
+#define MT9P031_H_BLANKING 0x05
+#define MT9P031_H_BLANKING_VALUE 0
+#define MT9P031_V_BLANKING 0x06
+#define MT9P031_V_BLANKING_VALUE 25
+#define MT9P031_OUTPUT_CONTROL 0x07
+#define MT9P031_OUTPUT_CONTROL_CEN 2
+#define MT9P031_OUTPUT_CONTROL_SYN 1
+#define MT9P031_SHUTTER_WIDTH_UPPER 0x08
+#define MT9P031_SHUTTER_WIDTH 0x09
+#define MT9P031_PLL_CONTROL 0x10
+#define MT9P031_PLL_CONTROL_PWROFF 0x0050
+#define MT9P031_PLL_CONTROL_PWRON 0x0051
+#define MT9P031_PLL_CONTROL_USEPLL 0x0052
+#define MT9P031_PLL_CONFIG_1 0x11
+#define MT9P031_PLL_CONFIG_1_M_48MHZ 0x5000
+#define MT9P031_PLL_CONFIG_1_N_48MHZ 0x05
+#define MT9P031_PLL_CONFIG_1_M_96MHZ 0x3600
+#define MT9P031_PLL_CONFIG_1_N_96MHZ 0x05
+#define MT9P031_PLL_CONFIG_2 0x12
+#define MT9P031_PLL_CONFIG_2_P1_48MHZ 5
+#define MT9P031_PLL_CONFIG_2_P1_96MHZ 2
+#define MT9P031_PIXEL_CLOCK_CONTROL 0x0a
+#define MT9P031_FRAME_RESTART 0x0b
+#define MT9P031_SHUTTER_DELAY 0x0c
+#define MT9P031_RST 0x0d
+#define MT9P031_RST_ENABLE 1
+#define MT9P031_RST_DISABLE 0
+#define MT9P031_READ_MODE_1 0x1e
+#define MT9P031_READ_MODE_2 0x20
+#define MT9P031_READ_MODE_2_ROW_MIR 0x8000
+#define MT9P031_READ_MODE_2_COL_MIR 0x4000
+#define MT9P031_ROW_ADDRESS_MODE 0x22
+#define MT9P031_COLUMN_ADDRESS_MODE 0x23
+#define MT9P031_GLOBAL_GAIN 0x35
+struct mt9p031 {
+ struct v4l2_subdev subdev;
+ struct media_pad pad;
+ struct v4l2_rect rect; /* Sensor window */
+ struct v4l2_mbus_framefmt format;
+ struct mt9p031_platform_data *pdata;
+ struct mutex power_lock; /* lock to protect power_count */
+ int power_count;
+ u16 xskip;
+ u16 yskip;
+ /* cache register values */
+ u16 output_control;
+static struct mt9p031 *to_mt9p031(const struct i2c_client *client)
+ return container_of(i2c_get_clientdata(client), struct mt9p031, subdev);
+static int reg_read(struct i2c_client *client, const u8 reg)
+ s32 data = i2c_smbus_read_word_data(client, reg);
+ return data < 0 ? data : swab16(data);
+static int reg_write(struct i2c_client *client, const u8 reg,
+ const u16 data)
+ return i2c_smbus_write_word_data(client, reg, swab16(data));
+static int mt9p031_set_output_control(struct mt9p031 *mt9p031, u16 clear,
+ u16 set)
+ struct i2c_client *client = v4l2_get_subdevdata(&mt9p031->subdev);
+ u16 value = (mt9p031->output_control & ~clear) | set;
+ int ret;
+ ret = reg_write(client, MT9P031_OUTPUT_CONTROL, value);
+ if (ret < 0)
+ return ret;
+ mt9p031->output_control = value;
+ return 0;
+static int mt9p031_reset(struct i2c_client *client)
+ struct mt9p031 *mt9p031 = to_mt9p031(client);
+ int ret;
+ /* Disable chip output, synchronous option update */
+ ret = reg_write(client, MT9P031_RST, MT9P031_RST_ENABLE);
+ if (ret < 0)
+ return ret;
+ ret = reg_write(client, MT9P031_RST, MT9P031_RST_DISABLE);
+ if (ret < 0)
+ return ret;
+ return mt9p031_set_output_control(mt9p031,
+ MT9P031_OUTPUT_CONTROL_CEN, 0);
+static int mt9p031_power_on(struct mt9p031 *mt9p031)
+ int ret;
+ /* Ensure RESET_BAR is low */
+ if (mt9p031->pdata->reset) {
+ mt9p031->pdata->reset(&mt9p031->subdev, 1);
+ msleep(1);
+ /* Emable clock */
+ if (mt9p031->pdata->set_xclk)
+ mt9p031->pdata->set_xclk(&mt9p031->subdev, MT9P031_EXTCLK_FREQ);
+ /* Now RESET_BAR must be high */
+ mt9p031->pdata->reset(&mt9p031->subdev, 0);
+ msleep(1);
+ /* soft reset */
+ ret = mt9p031_reset(client);
+ if (ret < 0) {
+ dev_err(&client->dev, "Failed to reset the camera\n");
+ return ret;
+ return 0;
+static void mt9p031_power_off(struct mt9p031 *mt9p031)
+ msleep(1);
+ mt9p031->pdata->set_xclk(&mt9p031->subdev, 0);
+static int mt9p031_enum_mbus_code(struct v4l2_subdev *sd,
+ struct v4l2_subdev_fh *fh,
+ struct v4l2_subdev_mbus_code_enum *code)
+ struct mt9p031 *mt9p031 = container_of(sd, struct mt9p031, subdev);
+ if (code->pad || code->index)
+ return -EINVAL;
+ code->code = mt9p031->format.code;
+ return 0;
+static struct v4l2_mbus_framefmt *mt9p031_get_pad_format(
+ struct mt9p031 *mt9p031,
+ unsigned int pad, u32 which)
+ switch (which) {
+ case V4L2_SUBDEV_FORMAT_TRY:
+ return v4l2_subdev_get_try_format(fh, pad);
+ case V4L2_SUBDEV_FORMAT_ACTIVE:
+ return &mt9p031->format;
+ default:
+ return NULL;
+static struct v4l2_rect *mt9p031_get_pad_crop(struct mt9p031 *mt9p031,
+ struct v4l2_subdev_fh *fh, unsigned int pad, u32 which)
+ switch (which) {
+ return v4l2_subdev_get_try_crop(fh, pad);
+ return &mt9p031->rect;
+ default:
+ return NULL;
+static int mt9p031_get_crop(struct v4l2_subdev *sd,
+ struct v4l2_subdev_crop *crop)
+ struct v4l2_rect *rect = mt9p031_get_pad_crop(mt9p031, fh, crop->pad,
+ crop->which);
+ if (!rect)
+ return -EINVAL;
+ crop->rect = *rect;
+ return 0;
+static u16 mt9p031_skip_for_crop(s32 source, s32 *target, s32 max_skip)
+ unsigned int skip;
+ if (source - source / 4 < *target) {
+ *target = source;
+ return 1;
+ skip = DIV_ROUND_CLOSEST(source, *target);
+ if (skip > max_skip)
+ skip = max_skip;
+ *target = 2 * DIV_ROUND_UP(source, 2 * skip);
+ return skip;
+static int mt9p031_set_params(struct i2c_client *client,
+ struct v4l2_rect *rect, u16 xskip, u16 yskip)
+ int ret;
+ u16 xbin, ybin;
+ const u16 hblank = MT9P031_H_BLANKING_VALUE,
+ vblank = MT9P031_V_BLANKING_VALUE;
+ __s32 left;
+ * TODO: Attention! When implementing horizontal flipping, adjust
+ * alignment according to R2 "Column Start" description in the datasheet
This is not the correct multi-line comment style. Please, double-check
with Documentation/CodingStyle. Please, fix all accurrances.
+ if (xskip & 1) {
+ xbin = 1;
+ left = rect->left & (~3);
+ } else if (xskip & 2) {
+ xbin = 2;
+ left = rect->left & (~7);
+ } else {
+ xbin = 4;
+ left = rect->left & (~15);
Superfluous parenthesis in all three cases above.
+ ybin = min(yskip, (u16)4);
+ /* Disable register update, reconfigure atomically */
+ ret = mt9p031_set_output_control(mt9p031, 0,
+ MT9P031_OUTPUT_CONTROL_SYN);
+ if (ret < 0)
+ return ret;
+ dev_dbg(&client->dev, "skip %u:%u, rect %ux%u@%u:%u\n",
+ xskip, yskip, rect->width, rect->height, rect->left, rect->top);
+ /* Blanking and start values - default... */
+ ret = reg_write(client, MT9P031_H_BLANKING, hblank);
+ if (ret < 0)
+ return ret;
+ ret = reg_write(client, MT9P031_V_BLANKING, vblank);
+ if (ret < 0)
+ return ret;
+ ret = reg_write(client, MT9P031_COLUMN_ADDRESS_MODE,
+ ((xbin - 1) << 4) | (xskip - 1));
+ if (ret < 0)
+ return ret;
+ ret = reg_write(client, MT9P031_ROW_ADDRESS_MODE,
+ ((ybin - 1) << 4) | (yskip - 1));
+ if (ret < 0)
+ return ret;
+ dev_dbg(&client->dev, "new physical left %u, top %u\n",
+ rect->left, rect->top);
+ ret = reg_write(client, MT9P031_COLUMN_START,
+ rect->left);
+ if (ret < 0)
+ return ret;
+ ret = reg_write(client, MT9P031_ROW_START,
+ rect->top);
+ if (ret < 0)
+ return ret;
+ ret = reg_write(client, MT9P031_WINDOW_WIDTH,
+ rect->width - 1);
+ if (ret < 0)
+ return ret;
+ ret = reg_write(client, MT9P031_WINDOW_HEIGHT,
+ rect->height - 1);
+ if (ret < 0)
+ return ret;
+ /* Re-enable register update, commit all changes */
+ MT9P031_OUTPUT_CONTROL_SYN, 0);
+ if (ret < 0)
+ return ret;
+ mt9p031->xskip = xskip;
+ mt9p031->yskip = yskip;
+ return ret;
+static int mt9p031_set_crop(struct v4l2_subdev *sd,
+ struct v4l2_mbus_framefmt *f;
+ struct v4l2_rect *c;
+ u16 xskip, yskip;
+ s32 width, height;
+ dev_dbg(mt9p031->subdev.v4l2_dev->dev, "%s(%ux%u@%u:%u : %u)\n",
+ __func__, crop->rect.width, crop->rect.height,
+ crop->rect.left, crop->rect.top, crop->which);
+ * Clamp the crop rectangle boundaries and align them to a multiple of 2
+ * pixels.
+ rect.width = ALIGN(clamp(crop->rect.width,
+ MT9P031_WINDOW_WIDTH_MIN,
+ MT9P031_WINDOW_WIDTH_MAX), 2);
+ rect.height = ALIGN(clamp(crop->rect.height,
+ MT9P031_WINDOW_HEIGHT_MIN,
+ MT9P031_WINDOW_HEIGHT_MAX), 2);
+ rect.left = ALIGN(clamp(crop->rect.left,
+ MT9P031_COLUMN_START_MIN,
+ MT9P031_COLUMN_START_MAX), 2);
+ rect.top = ALIGN(clamp(crop->rect.top,
+ MT9P031_ROW_START_MIN,
+ MT9P031_ROW_START_MAX), 2);
+ c = mt9p031_get_pad_crop(mt9p031, fh, crop->pad, crop->which);
+ if (rect.width != c->width || rect.height != c->height) {
+ * Reset the output image size if the crop rectangle size has
+ * been modified.
+ f = mt9p031_get_pad_format(mt9p031, fh, crop->pad,
+ crop->which);
+ width = f->width;
+ height = f->height;
+ xskip = mt9p031_skip_for_crop(rect.width, &width, 7);
+ yskip = mt9p031_skip_for_crop(rect.height, &height, 8);
+ } else {
+ xskip = mt9p031->xskip;
+ yskip = mt9p031->yskip;
+ f = NULL;
+ if (f) {
+ f->width = width;
+ f->height = height;
+ *c = rect;
+ crop->rect = rect;
+ mt9p031->rect = *c;
+ return 0;
+static int mt9p031_get_format(struct v4l2_subdev *sd,
+ struct v4l2_subdev_format *fmt)
+ fmt->format =
+ *mt9p031_get_pad_format(mt9p031, fh, fmt->pad, fmt->which);
+ return 0;
+static u16 mt9p031_skip_for_scale(s32 *source, s32 target,
+ s32 max_skip, s32 max)
+ if (*source - *source / 4 < target) {
+ *source = target;
+ return 1;
+ skip = min(max, *source + target / 2) / target;
+ skip = max_skip;
+ *source = target * skip;
+ return skip;
+static int mt9p031_set_format(struct v4l2_subdev *sd,
+ struct v4l2_subdev_format *format)
+ struct v4l2_mbus_framefmt *__format;
+ struct v4l2_rect *__crop, rect;
+ unsigned int width;
+ unsigned int height;
+ u16 xskip, yskip;
+ __crop = mt9p031_get_pad_crop(mt9p031, fh, format->pad, format->which);
+ width = clamp_t(int, ALIGN(format->format.width, 2), 2,
+ MT9P031_WINDOW_WIDTH_MAX);
+ height = clamp_t(int, ALIGN(format->format.height, 2), 2,
+ MT9P031_WINDOW_HEIGHT_MAX);
+ rect.width = __crop->width;
+ rect.height = __crop->height;
+ xskip = mt9p031_skip_for_scale(&rect.width, width, 7,
+ if (rect.width + __crop->left > MT9P031_WINDOW_WIDTH_MAX)
+ rect.left = (MT9P031_WINDOW_WIDTH_MAX - rect.width) / 2;
+ else
+ rect.left = __crop->left;
+ yskip = mt9p031_skip_for_scale(&rect.height, height, 8,
+ if (rect.height + __crop->top > MT9P031_WINDOW_HEIGHT_MAX)
+ rect.top = (MT9P031_WINDOW_HEIGHT_MAX - rect.height) / 2;
+ else
+ rect.top = __crop->top;
+ dev_dbg(mt9p031->subdev.v4l2_dev->dev, "%s(%ux%u : %u)\n", __func__,
+ width, height, format->which);
+ if (__crop)
+ *__crop = rect;
+ __format = mt9p031_get_pad_format(mt9p031, fh, format->pad,
+ format->which);
+ __format->width = width;
+ __format->height = height;
+ format->format = *__format;
+ mt9p031->rect = *__crop;
+ return 0;
+static int mt9p031_pll_enable(struct i2c_client *client)
+ int ret;
+ ret = reg_write(client, MT9P031_PLL_CONTROL, MT9P031_PLL_CONTROL_PWRON);
+ if (ret < 0)
+ return ret;
+ /* Always set the maximum frequency allowed by VDD_IO */
+ if (mt9p031->pdata->vdd_io == MT9P031_VDD_IO_2V8) {
+ ret = reg_write(client, MT9P031_PLL_CONFIG_1,
+ MT9P031_PLL_CONFIG_1_M_96MHZ |
+ MT9P031_PLL_CONFIG_1_N_96MHZ);
+ if (ret < 0)
+ return ret;
+ ret = reg_write(client, MT9P031_PLL_CONFIG_2,
+ MT9P031_PLL_CONFIG_2_P1_96MHZ);
+ if (ret < 0)
+ return ret;
+ } else {
+ MT9P031_PLL_CONFIG_1_M_48MHZ |
+ MT9P031_PLL_CONFIG_1_N_48MHZ);
+ if (ret < 0)
+ return ret;
+ MT9P031_PLL_CONFIG_2_P1_48MHZ);
+ if (ret < 0)
+ return ret;
+ mdelay(1);
+ MT9P031_PLL_CONTROL_PWRON |
+ MT9P031_PLL_CONTROL_USEPLL);
+ mdelay(1);
+ return ret;
+static inline int mt9p031_pll_disable(struct i2c_client *client)
+ return reg_write(client, MT9P031_PLL_CONTROL,
+ MT9P031_PLL_CONTROL_PWROFF);
+static int mt9p031_s_stream(struct v4l2_subdev *sd, int enable)
+ struct v4l2_rect rect = mt9p031->rect;
+ u16 xskip = mt9p031->xskip;
+ u16 yskip = mt9p031->yskip;
+ int ret;
+ if (enable) {
+ ret = mt9p031_set_params(client, &rect, xskip, yskip);
+ if (ret < 0)
+ return ret;
+ /* Switch to master "normal" mode */
+ MT9P031_OUTPUT_CONTROL_CEN);
+ if (ret < 0)
+ return ret;
+ ret = mt9p031_pll_enable(client);
+ } else {
+ /* Stop sensor readout */
+ if (ret < 0)
+ return ret;
+ ret = mt9p031_pll_disable(client);
+ return ret;
+static int mt9p031_video_probe(struct i2c_client *client)
+ s32 data;
+ /* Read out the chip version register */
+ data = reg_read(client, MT9P031_CHIP_VERSION);
+ if (data != MT9P031_CHIP_VERSION_VALUE) {
+ "No MT9P031 chip detected, register read %x\n", data);
+ return -ENODEV;
+ dev_info(&client->dev, "Detected a MT9P031 chip ID %x\n", data);
+ return 0;
+static int mt9p031_set_power(struct v4l2_subdev *sd, int on)
+ int ret = 0;
+ mutex_lock(&mt9p031->power_lock);
+ * If the power count is modified from 0 to != 0 or from != 0 to 0,
+ * update the power state.
+ if (mt9p031->power_count == !on) {
+ if (on) {
+ ret = mt9p031_power_on(mt9p031);
+ if (ret) {
+ dev_err(mt9p031->subdev.v4l2_dev->dev,
+ "Failed to power on: %d\n", ret);
Please, indent the line continuation deeper, don't worry about 80
characters.
+ goto out;
+ } else {
+ mt9p031_power_off(mt9p031);
+ /* Update the power count. */
+ mt9p031->power_count += on ? 1 : -1;
+ WARN_ON(mt9p031->power_count < 0);
+out:
+ mutex_unlock(&mt9p031->power_lock);
+ return ret;
+static int mt9p031_registered(struct v4l2_subdev *sd)
+ int ret;
+ ret = mt9p031_set_power(&mt9p031->subdev, 1);
+ if (ret) {
+ "Failed to power on device: %d\n", ret);
+ return ret;
+ ret = mt9p031_video_probe(client);
+ mt9p031_set_power(&mt9p031->subdev, 0);
+ return ret;
+static int mt9p031_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
+ struct mt9p031 *mt9p031;
+ mt9p031 = container_of(sd, struct mt9p031, subdev);
+ mt9p031->rect.width = MT9P031_WINDOW_WIDTH_DEF;
+ mt9p031->rect.height = MT9P031_WINDOW_HEIGHT_DEF;
+ mt9p031->rect.left = MT9P031_COLUMN_START_DEF;
+ mt9p031->rect.top = MT9P031_ROW_START_DEF;
+ if (mt9p031->pdata->version == MT9P031_MONOCHROME_VERSION)
+ mt9p031->format.code = V4L2_MBUS_FMT_Y12_1X12;
+ else
+ mt9p031->format.code = V4L2_MBUS_FMT_SGRBG12_1X12;
+ mt9p031->format.width = MT9P031_WINDOW_WIDTH_DEF;
+ mt9p031->format.height = MT9P031_WINDOW_HEIGHT_DEF;
+ mt9p031->format.field = V4L2_FIELD_NONE;
+ mt9p031->format.colorspace = V4L2_COLORSPACE_SRGB;
+ mt9p031->xskip = 1;
+ mt9p031->yskip = 1;
+ return mt9p031_set_power(sd, 1);
+static int mt9p031_close(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
+ return mt9p031_set_power(sd, 0);
+static struct v4l2_subdev_core_ops mt9p031_subdev_core_ops = {
+ .s_power = mt9p031_set_power,
+static struct v4l2_subdev_video_ops mt9p031_subdev_video_ops = {
+ .s_stream = mt9p031_s_stream,
+static struct v4l2_subdev_pad_ops mt9p031_subdev_pad_ops = {
+ .enum_mbus_code = mt9p031_enum_mbus_code,
+ .get_fmt = mt9p031_get_format,
+ .set_fmt = mt9p031_set_format,
+ .get_crop = mt9p031_get_crop,
+ .set_crop = mt9p031_set_crop,
+static struct v4l2_subdev_ops mt9p031_subdev_ops = {
+ .core = &mt9p031_subdev_core_ops,
+ .video = &mt9p031_subdev_video_ops,
+ .pad = &mt9p031_subdev_pad_ops,
+static const struct v4l2_subdev_internal_ops mt9p031_subdev_internal_ops = {
+ .registered = mt9p031_registered,
+ .open = mt9p031_open,
+ .close = mt9p031_close,
+static int mt9p031_probe(struct i2c_client *client,
+ const struct i2c_device_id *did)
+ int ret;
+ struct mt9p031_platform_data *pdata = client->dev.platform_data;
+ struct i2c_adapter *adapter = to_i2c_adapter(client->dev.parent);
+ if (!i2c_check_functionality(adapter, I2C_FUNC_SMBUS_WORD_DATA)) {
+ dev_warn(&adapter->dev,
+ "I2C-Adapter doesn't support I2C_FUNC_SMBUS_WORD\n");
+ return -EIO;
+ mt9p031 = kzalloc(sizeof(struct mt9p031), GFP_KERNEL);
+ if (!mt9p031)
+ return -ENOMEM;
+ mutex_init(&mt9p031->power_lock);
+ v4l2_i2c_subdev_init(&mt9p031->subdev, client, &mt9p031_subdev_ops);
+ mt9p031->subdev.internal_ops = &mt9p031_subdev_internal_ops;
+ mt9p031->pdata = pdata;
+ mt9p031->pad.flags = MEDIA_PAD_FL_SOURCE;
+ ret = media_entity_init(&mt9p031->subdev.entity, 1, &mt9p031->pad, 0);
+ if (ret)
+ return ret;
+ mt9p031->subdev.flags |= V4L2_SUBDEV_FL_HAS_DEVNODE;
+ return 0;
+static int mt9p031_remove(struct i2c_client *client)
+ struct v4l2_subdev *sd = i2c_get_clientdata(client);
+ v4l2_device_unregister_subdev(sd);
+ media_entity_cleanup(&sd->entity);
+ kfree(mt9p031);
+ return 0;
+static const struct i2c_device_id mt9p031_id = {
+ { "mt9p031", 0 },
+MODULE_DEVICE_TABLE(i2c, mt9p031_id);
+static struct i2c_driver mt9p031_i2c_driver = {
+ .driver = {
+ .name = "mt9p031",
+ .probe = mt9p031_probe,
+ .remove = mt9p031_remove,
+ .id_table = mt9p031_id,
+static int __init mt9p031_mod_init(void)
+ return i2c_add_driver(&mt9p031_i2c_driver);
+static void __exit mt9p031_mod_exit(void)
+ i2c_del_driver(&mt9p031_i2c_driver);
+module_init(mt9p031_mod_init);
+module_exit(mt9p031_mod_exit);
+MODULE_DESCRIPTION("Aptina MT9P031 Camera driver");
+MODULE_AUTHOR("Bastian Hecht <hechtb@gmail.com>");
+MODULE_LICENSE("GPL v2");
diff --git a/include/media/mt9p031.h b/include/media/mt9p031.h
index 0000000..27b4c75
--- /dev/null
+++ b/include/media/mt9p031.h
@@ -0,0 +1,23 @@
+#ifndef MT9P031_H
+#define MT9P031_H
+struct v4l2_subdev;
+enum {
+ MT9P031_COLOR_VERSION = 0,
+ MT9P031_MONOCHROME_VERSION = 1,
Do you really need explicit number assignments?
+enum {
+ MT9P031_VDD_IO_1V8 = 0,
+ MT9P031_VDD_IO_2V8 = 1,
ditto
+struct mt9p031_platform_data {
+ int (*set_xclk)(struct v4l2_subdev *subdev, int hz);
+ int (*reset)(struct v4l2_subdev *subdev, int active);
+ int vdd_io; /* MT9P031_VDD_IO_1V8 or MT9P031_VDD_IO_2V8 */
+ int version; /* MT9P031_COLOR_VERSION or MT9P031_MONOCHROME_VERSION */
+#endif
1.7.0.4
Guennadi
Cosmetics again:)
arch/arm/mach-omap2/Makefile | 1 +
arch/arm/mach-omap2/board-omap3beagle-camera.c | 95 ++++++++++++++++++++++++
arch/arm/mach-omap2/board-omap3beagle.c | 55 ++++++++++++++
3 files changed, 151 insertions(+), 0 deletions(-)
create mode 100644 arch/arm/mach-omap2/board-omap3beagle-camera.c
diff --git a/arch/arm/mach-omap2/Makefile b/arch/arm/mach-omap2/Makefile
index 512b152..05cd983 100644
--- a/arch/arm/mach-omap2/Makefile
+++ b/arch/arm/mach-omap2/Makefile
@@ -179,6 +179,7 @@ obj-$(CONFIG_MACH_OMAP_2430SDP) += board-2430sdp.o \
              hsmmc.o
obj-$(CONFIG_MACH_OMAP_APOLLON) += board-apollon.o
obj-$(CONFIG_MACH_OMAP3_BEAGLE) += board-omap3beagle.o \
+ board-omap3beagle-camera.o \
              hsmmc.o
obj-$(CONFIG_MACH_DEVKIT8000) += board-devkit8000.o \
                                            hsmmc.o
diff --git a/arch/arm/mach-omap2/board-omap3beagle-camera.c b/arch/arm/mach-omap2/board-omap3beagle-camera.c
index 0000000..2632557
--- /dev/null
+++ b/arch/arm/mach-omap2/board-omap3beagle-camera.c
@@ -0,0 +1,95 @@
+#include <linux/gpio.h>
+#include <linux/regulator/machine.h>
+#include <plat/i2c.h>
+#include <asm/mach-types.h>
+#include "devices.h"
+#include "../../../drivers/media/video/omap3isp/isp.h"
+#define MT9P031_RESET_GPIO 98
+#define MT9P031_XCLK ISP_XCLK_A
+static struct regulator *reg_1v8, *reg_2v8;
+static int beagle_cam_set_xclk(struct v4l2_subdev *subdev, int hz)
+ struct isp_device *isp = v4l2_dev_to_isp_device(subdev->v4l2_dev);
+ int ret;
+ ret = isp->platform_cb.set_xclk(isp, hz, MT9P031_XCLK);
+ return 0;
Why do you need "ret" if you always return 0?
+static int beagle_cam_reset(struct v4l2_subdev *subdev, int active)
+ /* Set RESET_BAR to !active */
+ gpio_set_value(MT9P031_RESET_GPIO, !active);
+ return 0;
+static struct mt9p031_platform_data beagle_mt9p031_platform_data = {
+ .set_xclk = beagle_cam_set_xclk,
+ .reset = beagle_cam_reset,
+ .vdd_io = MT9P031_VDD_IO_1V8,
+ .version = MT9P031_COLOR_VERSION,
You could as well remove one TAB before "="
+static struct i2c_board_info mt9p031_camera_i2c_device = {
+ I2C_BOARD_INFO("mt9p031", 0x48),
+ .platform_data = &beagle_mt9p031_platform_data,
+static struct isp_subdev_i2c_board_info mt9p031_camera_subdevs = {
+ .board_info = &mt9p031_camera_i2c_device,
+ .i2c_adapter_id = 2,
+ { NULL, 0, },
+static struct isp_v4l2_subdevs_group beagle_camera_subdevs = {
+ .subdevs = mt9p031_camera_subdevs,
+ .interface = ISP_INTERFACE_PARALLEL,
+ .bus = {
+ .parallel = {
+ .data_lane_shift = 0,
+ .clk_pol = 1,
+ .bridge = ISPCTRL_PAR_BRIDGE_DISABLE,
Too deep indentation
+static struct isp_platform_data beagle_isp_platform_data = {
+ .subdevs = beagle_camera_subdevs,
+static int __init beagle_camera_init(void)
+ if (!machine_is_omap3_beagle() || !cpu_is_omap3630())
+ return 0;
+ reg_1v8 = regulator_get(NULL, "cam_1v8");
+ if (IS_ERR(reg_1v8))
+ pr_err("%s: cannot get cam_1v8 regulator\n", __func__);
+ else
+ regulator_enable(reg_1v8);
+ reg_2v8 = regulator_get(NULL, "cam_2v8");
+ if (IS_ERR(reg_2v8))
+ pr_err("%s: cannot get cam_2v8 regulator\n", __func__);
+ else
+ regulator_enable(reg_2v8);
+ omap_register_i2c_bus(2, 100, NULL, 0);
+ gpio_request(MT9P031_RESET_GPIO, "cam_rst");
+ gpio_direction_output(MT9P031_RESET_GPIO, 0);
+ omap3_init_camera(&beagle_isp_platform_data);
+ return 0;
+late_initcall(beagle_camera_init);
diff --git a/arch/arm/mach-omap2/board-omap3beagle.c b/arch/arm/mach-omap2/board-omap3beagle.c
index 33007fd..c18d21c 100644
--- a/arch/arm/mach-omap2/board-omap3beagle.c
+++ b/arch/arm/mach-omap2/board-omap3beagle.c
@@ -24,12 +24,16 @@
#include <linux/input.h>
#include <linux/gpio_keys.h>
#include <linux/opp.h>
+#include <linux/mm.h>
Don't see why you need to add these 3 headers with this patch.
#include <linux/mtd/mtd.h>
#include <linux/mtd/partitions.h>
#include <linux/mtd/nand.h>
#include <linux/mmc/host.h>
#include <linux/i2c/twl.h>
@@ -47,6 +51,7 @@
#include <plat/nand.h>
#include <plat/usb.h>
#include <plat/omap_device.h>
ditto
#include "mux.h"
#include "hsmmc.h"
@@ -273,6 +278,44 @@ static struct regulator_consumer_supply beagle_vsim_supply = {
static struct gpio_led gpio_leds;
+static struct regulator_consumer_supply beagle_vaux3_supply = {
+ .supply = "cam_1v8",
+static struct regulator_consumer_supply beagle_vaux4_supply = {
+ .supply = "cam_2v8",
+/* VAUX3 for CAM_1V8 */
+static struct regulator_init_data beagle_vaux3 = {
+ .constraints = {
+ .min_uV = 1800000,
+ .max_uV = 1800000,
+ .apply_uV = true,
+ .valid_modes_mask = REGULATOR_MODE_NORMAL
+ | REGULATOR_MODE_STANDBY,
+ .valid_ops_mask = REGULATOR_CHANGE_MODE
+ | REGULATOR_CHANGE_STATUS,
+ .num_consumer_supplies = 1,
+ .consumer_supplies = &beagle_vaux3_supply,
+/* VAUX4 for CAM_2V8 */
+static struct regulator_init_data beagle_vaux4 = {
+ .constraints = {
+ .apply_uV = true,
+ .consumer_supplies = &beagle_vaux4_supply,
static int beagle_twl_gpio_setup(struct device *dev,
     unsigned gpio, unsigned ngpio)
@@ -309,6 +352,15 @@ static int beagle_twl_gpio_setup(struct device *dev,
       pr_err("%s: unable to configure EHCI_nOC\n", __func__);
+ if (omap3_beagle_get_rev() == OMAP3BEAGLE_BOARD_XM) {
+ * Power on camera interface - only on pre-production, not
+ * needed on production boards
+ gpio_request(gpio + 2, "CAM_EN");
+ gpio_direction_output(gpio + 2, 1);
    * TWL4030_GPIO_MAX + 0 == ledA, EHCI nEN_USB_PWR (out, XM active
    * high / others active low)
@@ -451,6 +503,8 @@ static struct twl4030_platform_data beagle_twldata = {
   .vsim = &beagle_vsim,
   .vdac = &beagle_vdac,
   .vpll2 = &beagle_vpll2,
+ .vaux3 = &beagle_vaux3,
+ .vaux4 = &beagle_vaux4,
static struct i2c_board_info __initdata beagle_i2c_boardinfo = {
@@ -658,6 +712,7 @@ static void __init omap3_beagle_init(void)
   omap3_mux_init(board_mux, OMAP_PACKAGE_CBB);
   omap3_beagle_init_rev();
   omap3_beagle_i2c_init();
   platform_add_devices(omap3_beagle_devices,
       ARRAY_SIZE(omap3_beagle_devices));
This hunk doesn't seem to belong here;)
1.7.0.4
Guennadi
So mplayer-bayer is a bad test :slight_smile: So what other tool(chain) can I use to display images captured with this driver? Ideally I would use mediactl to point the CCDC output to the v4l2 overlay, but I guess that would need some extra code in the ISP and omapvout drivers.
I heard it's really sunny in Texas where they will be testing this, so the mplayer darkness might be OK for there.
regards,
Koen
OK Guennadi,
I'll fix those cosmetics issues in my next version where I will add
VFLIP and HFLIP control support (which I removed previously to make
the code less complex).
Now we talk about controls I have a question regarding controls
defined in video subdevices like mt9p031 or mt9v032:
What device node should I use to set these controls through an ioctl() ?
For instance, with mt9p031 + Beagleboard xM we have:
./media-ctl -r -l '"mt9p031 2-0048":0->"OMAP3 ISP CCDC":0[1], "OMAP3
./media-ctl -f '"mt9p031 2-0048":0[SGRBG12 320x240], "OMAP3 ISP
./yavta --stdout -f SGRBG8 -s 320x240 -n 4 --capture=100 --skip 3 -F
`./media-ctl -e "OMAP3 ISP CCDC output"` | nc 192.168.0.42 3000
Where
root@beagleboard:~# ./media-ctl -e "OMAP3 ISP CCDC output"
/dev/video2
However, if I try to set sensor controls using /dev/video2 I get an
error (invalid argument).
OK Guennadi,
Please, don't. Let's first get the simple version of your driver in the
mainline, then it can be extended. Just, please, make sure to address all
remaining issues without changing anything else:)
Guennadi
Ok, thanks.
