[PATCH v6] OMAP3: beagle: add support for beagleboard xM revision C
The USB enable GPIO has been in beagleboard xM revision C
The USER button has been moved since beagleboard xM
Also, board specific initialization has been moved to beagle_config struct
and initialized in omap3_beagle_init_rev. Default values in struct are for xMC.
Signed-off-by: Joel A Fernandes <joelagnel@ti.com>
Signed-off-by: Koen Kooi <koen@dominion.thruhere.net>
Texas Instruments Limited, 800 Pavilion Drive, Northampton, NN4 7YL. Registered in England & Wales under company number 00574102
arch/arm/mach-omap2/board-omap3beagle.c | 70 ++++++++++++++++++++-----------
1 files changed, 46 insertions(+), 24 deletions(-)
diff --git a/arch/arm/mach-omap2/board-omap3beagle.c
b/arch/arm/mach-omap2/board-omap3beagle.c
index 7f21d24..261fb53 100644
--- a/arch/arm/mach-omap2/board-omap3beagle.c
+++ b/arch/arm/mach-omap2/board-omap3beagle.c
@@ -61,7 +61,8 @@
* AXBX = GPIO173, GPIO172, GPIO171: 1 1 1
* C1_3 = GPIO173, GPIO172, GPIO171: 1 1 0
* C4 = GPIO173, GPIO172, GPIO171: 1 0 1
- * XM = GPIO173, GPIO172, GPIO171: 0 0 0
+ * XMA/XMB = GPIO173, GPIO172, GPIO171: 0 0 0
+ * XMC = GPIO173, GPIO172, GPIO171: 0 1 0
enum {
OMAP3BEAGLE_BOARD_UNKN = 0,
@@ -69,14 +70,26 @@ enum {
OMAP3BEAGLE_BOARD_C1_3,
OMAP3BEAGLE_BOARD_C4,
OMAP3BEAGLE_BOARD_XM,
+ OMAP3BEAGLE_BOARD_XMC,
static u8 omap3_beagle_version;
-static u8 omap3_beagle_get_rev(void)
- return omap3_beagle_version;
+ * Board-specific configuration
+ * Defaults to BeagleBoard-xMC
+static struct {
+ int mmc1_gpio_wp;
+ int usb_pwr_level;
+ int reset_gpio;
+ int usr_button_gpio;
+} beagle_config = {
+ .mmc1_gpio_wp = -EINVAL,
+ .usb_pwr_level = GPIOF_OUT_INIT_LOW,
+ .reset_gpio = 129,
+ .usr_button_gpio = 4,
static struct gpio omap3_beagle_rev_gpios[] __initdata = {
{ 171, GPIOF_IN, "rev_id_0" },
@@ -111,18 +124,32 @@ static void __init omap3_beagle_init_rev(void)
case 7:
printk(KERN_INFO "OMAP3 Beagle Rev: Ax/Bx\n");
omap3_beagle_version = OMAP3BEAGLE_BOARD_AXBX;
+ beagle_config.mmc1_gpio_wp = 29;
+ beagle_config.reset_gpio = 170;
+ beagle_config.usr_button_gpio = 7;
break;
case 6:
printk(KERN_INFO "OMAP3 Beagle Rev: C1/C2/C3\n");
omap3_beagle_version = OMAP3BEAGLE_BOARD_C1_3;
+ beagle_config.mmc1_gpio_wp = 23;
break;
case 5:
printk(KERN_INFO "OMAP3 Beagle Rev: C4\n");
omap3_beagle_version = OMAP3BEAGLE_BOARD_C4;
break;
case 0:
printk(KERN_INFO "OMAP3 Beagle Rev: xM\n");
Since it sounds like there is already another revision coming, update
the text above to:
                printk(KERN_INFO "OMAP3 Beagle Rev: xM Ax/Bx\n");
________________________________________
Sent: 03 June 2011 23:56
To: linux-omap@vger.kernel.org
Cc: beagle@list.ti.com - Ultra-low cost OMAP3 board (May contain non-TIers); beagleboard@googlegroups.com; Maupin, Chase
Subject: [beagle] [PATCH v6] OMAP3: beagle: add support for beagleboard xM revision C
@@ -276,9 +297,7 @@ static int beagle_twl_gpio_setup(struct device *dev,
* high / others active low)
* DVI reset GPIO is different between beagle revisions
- if (omap3_beagle_get_rev() == OMAP3BEAGLE_BOARD_XM) {
- usb_pwr_level = GPIOF_OUT_INIT_HIGH;
- beagle_dvi_device.reset_gpio = 129;
+ if (cpu_is_omap3630()) {
PLease add a comment like "valid for all xM versions" to the above.
@@ -526,7 +545,7 @@ static void __init beagle_opp_init(void)
   /\* Custom OPP enabled for XM \*/
same
@@ -566,6 +585,9 @@ static void __init omap3_beagle_init(void)
omap3_mux_init(board_mux, OMAP_PACKAGE_CBB);
omap3_beagle_init_rev();
omap3_beagle_i2c_init();
+ gpio_buttons[0].gpio = beagle_config.usr_button_gpio;
And please move that into
static struct gpio_keys_button gpio_buttons[] = {
.code = BTN_EXTRA,
.gpio = 7, <- there
I don't follow. The other assignment is dynamic, following the
detection of the board revision and, hopefully, before the
initialization of the GPIO button. I don't see how it can be moved
here. Perhaps it might be better to set it to -EINVAL to indicate it
will be assigned later?
That would work, I think we should be consistent in all the assignments and if possible only set/assign them once.
regards,
Koen
