I’m trying to run a simple led blink example like here:
I’m running a Ubuntu image on my beaglebone black with node 0.8.x. I get a permission problem that looks like some form of failure to have access to the pins. I added my user to the dialout group and that didn’t work. Then I added my user to every group I could find and that didn’t work either. The only way I can get the code to run and do the blinking is if I run it as root. My question is, how do I give my user access to whatever is needed to reach the pins running as non-root. The permission problem looks like the following:
fs.js:338
return binding.open(pathModule._makeLong(path), stringToFlags(flags), mode);
Error: EACCES, permission denied ‘/sys/class/leds/beaglebone:green:usr0/trigger’
at Object.fs.openSync (fs.js:338:18)
at Object.fs.writeFileSync (fs.js:756:15)
at Object.f.pinMode (/home/ubuntu/projects/hello_express/node_modules/bonescript/index.js:132:20)
at Object. (/home/ubuntu/projects/hello_express/hello_express.js:31:3)
at Module._compile (module.js:449:26)
at Object.Module._extensions…js (module.js:467:10)
at Module.load (module.js:356:32)
at Function.Module._load (module.js:312:12)
at Module.runMain (module.js:492:10)
Thanks for any help in advance. I’m pretty excited to get this running.
- Samuel
