rdbirt
October 25, 2013, 12:42am
1
Trying to bring up Linux kernel 3.10.17 on a Beagleboard-xM. The Ethernet isn’t working as the phy isn’t being found; error is: “unable to find transceiver” when ehci is being initialized.
If I go back to a previous kernel, such as 3.8.0, then all is fine.
Does anyone have a solution to this?
Make sure the SW turns on the power to the HUB. It comes up off.
Build with
CONFIG_NOP_USB_XCEIV=M
as it's been broken sinc 6022671
rdbirt
October 25, 2013, 1:10am
4
That’s D14, correct? That’s on so I think the power is okay.
rdbirt
October 25, 2013, 4:52pm
6
I have CONFIG_NOP_USB_XCEIV=y, so it should be built in. Should I build it as a module?
Correct, build with
as "CONFIG_NOP_USB_XCEIV=y" been broken since 6022671
rdbirt
October 30, 2013, 3:54pm
8
Built the NOP driver as a module and put ‘modprobe phy-nop’ as the first line in the rcS file. Still have the same error:
[ 2.492553] unable to find transceiver
[ 2.496948] ehci-omap ehci-omap.0: Can’t get PHY device for port 1: -517
[ 2.504180] platform ehci-omap.0: Driver ehci-omap requests probe deferral
[ 2.595275] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts:
(null)
[ 2.604125] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 2.616333] devtmpfs: mounted
[ 2.619903] Freeing unused kernel memory: 176K (c0484000 - c04b0000)
[ 2.876312] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 3.039093] platform nop_usb_xceiv.2: Driver nop_usb_xceiv requests probe deferral
Starting logging: OK
Initializing random number generator… [ 3.245544] hub 1-0:1.0: Cannot enable por
t 1. Maybe the USB cable is bad?
done.
Starting system message bus: done
Starting network…
ifconfig: SIOCGIFFLAGS: No such device
ifconfig: SIOCSIFHWADDR: No such device
Starting dropbear sshd: Copying dropbear host key files
OK
[ 4.444000] hub 1-0:1.0: Cannot enable port 1. Maybe the USB cable is bad?
[ 5.643951] hub 1-0:1.0: Cannot enable port 1. Maybe the USB cable is bad?
Built the NOP driver as a module and put 'modprobe phy-nop' as the first
[ 2.496948] ehci-omap ehci-omap.0: Can't get PHY device for port 1: -517
deferral
mode. Opts:
(null)
deferral
Initializing random number generator... [ 3.245544] hub 1-0:1.0: Cannot
enable por
done.
Starting network...
OK
Okay, well here is my patchset:
It 'booted' last i tried, but i'm running v3.12-rc7 now days using
device tree's so i haven't tested in a while.. So dig thru it..
bad?
bad?
Also, because of that dmesg noise, test with this enabled/disabled..
rdbirt
October 31, 2013, 12:31am
10
Okay, thanks, Robert. I will dig into it and let you know what I find.
hvn052
March 4, 2014, 8:42am
11
I’m trying to get 3.10.18 running, and with this option already set as indicated I get “unable to find transceiver” and “can’t get PHY device” in syslog, both with ehci. So is there any news on this ?
hvn
