Pin mux configuration required for using mcbsp3?
I would like to know about the mcbsp3
Is it enabled by default or some pin mux configuration is required?
Search for thread subject: MCSPI3 working, both ways
You should find what you're looking for in the patch from the thread.
-Keith
Ernesto Torres wrote:
That thread is only for the SPI Port, but the McBSP3 is for I2S communication
Any info on I2S?
I don’t recall any previously longer ongoing discussing with respect to McBSP3…
With respect to pin-muxing, I think the easiest way forward is to check the value of the mux-registers for the given pins in order to figure out how the pins are currently configured…
Best regards – Good luck
Søren
