pins conflict?
I use custom hat board with my old BBB on P9 headers.
I would like use the same hat board with my new BBGW.
However i see in the dmesg pins conflict:
[ 2.131373] pinctrl-single 44e10800.pinmux: pin PIN109 already requested by 44e10800.pinmux; cannot claim for ocp:P9_41_pinmux
[ 2.714948] pinctrl-single 44e10800.pinmux: pin PIN86 already requested by ocp:P9_18_pinmux; cannot claim for 4802a000.i2c
[ 63.810571] pinctrl-single 44e10800.pinmux: pin PIN106 already requested by ocp:P9_91_pinmux; cannot claim for 48038000.mcasp
[ 67.662623] pinctrl-single 44e10800.pinmux: pin PIN18 already requested by ocp:P9_14_pinmux; cannot claim for sound
It seems like BBB and BBGW pinout is not compatible. I suspect that maybe two Grove connectors (I2C and UART) occupy the old pins?
If so how could I switch off these Grove connectors so BBGW pinout would be the same as BBB?
Today all images boot with cape-univeral enabled, so if your overlay
needs specific pins, you need to tell it to disable them..
Or jsut disable:
enable_uboot_cape_universal=1
in /boot/uEnv.txt
If that still doesn't fix your problem, please run this script and
report it's output so we can help debug..
Thanks for prompt replay.
I’ve commented out the line ‘enable_uboot_cape_universal=1’ in /boot/uEnv.txt
and after reboot the old hat board works with BBGW.
However on-board wifi stops working.
How to enable wifi?
see details (dmesg and output of script):
https://paste.ubuntu.com/p/c7DHbwphDC/
W dniu środa, 24 czerwca 2020 22:23:23 UTC+2 użytkownik RobertCNelson napisał:
Is there any way to enable BBGW’s onboard wifi with disable uboot cape universal (with commented line ‘#enable_uboot_cape_universal=1’ in /boot/uEnv.txt )?
