Hi! Would like to connect to serial debug header on the AI. Will this work? https://www.sparkfun.com/products/10373 pitch in that connection looks really small. If not, what would you recommend? And yes I do realize I can connect via HDMI+USB but I like the simplicity of serial. Thank you in advance.
That’s too big, it’s a jst connector… if you have the standard 5 pin ftdi USB serial, just use this adapter.
https://www.digikey.com/products/en?keywords=BBCAI-ND
