Please Help! install_kernel not working on newly setup sd card.
First - I’d like to say the work done by Robert C Nelson, and others in this group is fantastic.
I created an SD card from Roberts site that looks something like this:
Linux arm 3.14.22-ti-r31 #1 SMP PREEMPT Fri Oct 24 20:50:46 UTC 2014 armv7l GNU/Linux
Is that PREEMPT_RT patched by default? Excellent.
The problem I’m having, is that I want to build a new kernel (3.14.4-bone4) from Robert’s git repo.
GitHub - RobertCNelson/linux-dev at 3.14.4-bone4
I followed the instructions to get it, build it, modify system.sh, and install it to the SD card I’ve got.
It looks like it’s all working… here’s the output:
Trying: [/dev/sdb1]
Partition: [/dev/sdb1] trying: [vfat], [ext4]
Partition: [extX]
Installing 3.14.4-bone4 to /dev/sdb1
/home/mike/linux-dev-3.14.4-bone4/deploy/3.14.4-bone4.zImage' -> /home/mike/linux-dev-3.14.4-bone4/deploy/disk/boot/zImage’
Installing 3.14.4-bone4-dtbs.tar.gz to /dev/sdb1
Installing 3.14.4-bone4-modules.tar.gz to /dev/sdb1
Installing 3.14.4-bone4-firmware.tar.gz to /dev/sdb1
/home/mike/linux-dev-3.14.4-bone4/deploy/config-3.14.4-bone4' -> /home/mike/linux-dev-3.14.4-bone4/deploy/disk/boot/config-3.14.4-bone4’
This script has finished…
For verification, always test this media with your end device…
But, when I put the card in and boot holding down the button, it still boots with the original kernel on the card.
Anybody got a guess at why?
I mounted the SD Card on my #! machine and the file system isn’t what I expected.
I expected:
/dev/sdb1 ← some small vfat with boot/uboot
/dev/sdb2 ← everything else
It looks like it’s all on /dev/sdb1 as ext4.
and inside /boot, I see the zImage file that was copied over by install_kernel.sh, but there’s also a vmlinuz file.
I’m guessing the “install_me.sh” for the 3.x.x-ti kernel types sets up a different boot structure, and that’s why zImage is getting ignored.
Can somebody please clarify?
Wrong repo/branch... (the "3.14-bone" is eol..)
https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/ti-linux-3.14.y
I don't advertise it because it's in a solid state of re-basing
against ti's 3.14 tree..
It's best to just use:
https://github.com/beagleboard/linux/tree/3.14
Thanks Robert!
Those scripts in your EOLd repo are so promising/helpful.
Due to some CAN bugs, I think I’m going to either have to patch 3.14.something, or go for a new kernel like 3.17.x
I noticed you’ve got 3.17 stuff here:
http://rcn-ee.net/deb/wheezy-armhf/v3.17.2-bone5/
But if I needed to get the source to patch/rebuild, how would you recommend I go about doing that?
So can on omap is getting a big push for v3.19-rc (as v3.18.0 should
be tagged this sunday) it'll still be a couple weeks before v3.19-rc0
will be bootable..
either use: v3.14.x
or, v3.18-rc:
https://github.com/RobertCNelson/bb-kernel/tree/am33x-v3.18
Excellent - thank you, Robert.
You mentioned OMAP… I’m still trying to figure out how to tell what commits end up in a given release.
For example:
https://git.kernel.org/cgit/linux/kernel/git/tmlind/linux-omap.git/log/drivers/net/can/c_can/c_can_platform.c
Latest Commit:
https://git.kernel.org/cgit/linux/kernel/git/tmlind/linux-omap.git/commit/drivers/net/can/c_can/c_can_platform.c?id=a7380db5f0d6dd94981e73da08d8fa863ee72235
Is that part of what’s getting pushed for v3.19-rc?
How do I look that up?
https://git.kernel.org/cgit/linux/kernel/git/next/linux-next.git/log/?id=refs%2Ftags%2Fnext-20141205&qt=grep&q=dcan
Robert,
Thank you for your help so far.
I see that you have 3.18-bone1 in your repo… I was able to cross compile it and put it on the beagle thanks to your scripts.
It looks like PREEMPT_RT is not patched?
Do you have recommendations on how to patch it?
Mike
PREEMPT_RT has funding issues, and right now they only go up to v3.14.x
https://www.kernel.org/pub/linux/kernel/projects/rt/
But you know, we have Xenomai for v3.14.x:
sudo apt-get update
sudo apt-get install linux-image-3.14.26-ti-xenomai-r41
Hah, it’s never easy is it? If I go down to 3.14 I’ll have a fun time patching the CAN changes from 3.19-rc0.
I’ll give that a shot… perhaps I’ll setup a few different cards.
  • 3.18-bone1
  • 3.14 with preempt_rt
  • 3.14 with xeniomai (I’ll need the source to recompile with CAN changes)
Thanks for the tips.
  • 3.18-bone1
We should have all the can changes TI made to v3.19 in our 3.14-ti… :wink:
Excellent. I believe we’ve just come full circle…
So -
https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/3.14.26-ti-r41
Has the CAN changes, doesn’t have RT or Xenomai (ipipe) patches
https://github.com/RobertCNelson/ti-linux-kernel-dev/tree/3.14.26-ti-xenomai-r41
Has the CAN changes, and Xenomai
https://github.com/beagleboard/linux/tree/3.14.26-ti-r41
TI’s kernel tree - doesn’t have your wrapper scripts/tools.
Sound about right?
Pretty much:
This is ti's git tree i'm using as a base:
http://git.ti.com/gitweb/?p=ti-linux-kernel/ti-linux-kernel.git;a=shortlog;h=refs/heads/ti-linux-3.14.y
The https://github.com/beagleboard/linux/ branch has that plus all
the local cape changes.
