I have read the README.
I have succesfully built the kernel with the build_kernel.sh script.
I have installed the kernel with the tools/load_uImage.sh script.
But after inserting the card in my BeagleBone A4 it hangs up booting.
I’m a student working on a group to write a basic tutorial for the BB xM rev C.
And after some troubles with cross compilation finaly solved, i got still some questions.
We are currently working on Angstrom, is there a compiler provided with that distribution?
Concerning source files, how can we transfer it from computer to the BB using serial cable?
Yes, that solved the problem indeed and I have a 3.2 kernel.
I have couple of questions that is more Linux related. I hope I can find answers.
1- From where can I get the Ubuntu filesystem that this kernel would work with? Should I just download any Ubuntu 11.10 for ARM?
2- As far as I know, when building Linux kernel, you would need to generate libc to go with the new kernel. Am I wrong here? If not, where is the new libc?
libc?
News to me, i know "make deb-pkg" generates one, but i've never used it.
I realize this is an old thread, but I have a quick question that is somewhat related:
I have been closely following the steps at http://eewiki.net/display/linuxonarm/BeagleBone to build an image for the BeagleBone (with the only exception that I am using the install_image.sh or install_kernel.sh script in place of the “Setup micro SD card” steps). For right now, I am not making any modifications to the kernel, but will soon be trying out some minor application-specific changes.
After spending a day or two of scratching my head at u-boot errors (“ERROR: Did not find a cmdline Flattened Device Tree” or "mmc_send_cmd : timeout: No status update; Card did not respond to voltage select! "), I finally tried a different micro SD card (the one that shipped with the board), and found that it worked flawlessly!
The micro SD card I was using with less success was a PNY 16GB card. My question is: Are there any micro SD card requirements for the “RobertCNelson” Ubuntu scripts for BeagleBone? I searched around the Wiki, but could not find any mention of micro SD card requirements. If not–is there anything I should do to get my 16 GB card working? (It has worked before in the past with the setup_sdcard.sh auto-build script, though very sporadically.) I have already tried writing zeros to the card with dd if=/dev/zero of=/dev/sdb before re-trying various build methods, but that seems to have had no effect. If the card is toast, is there anything I should look for specifically in a new card besides a faster class 10 card?
Thank you in advance for any help that is offered,
-Mike
somewhat related:
install_kernel.sh script in place of the "Setup micro SD card" steps). For
just ask..
("ERROR:
Did not find a cmdline Flattened Device Tree"
if you get this error, it means you didn't read the "uEnv.txt" file
and uncomment the appropriate uenvcmd line..
aka:
#uenvcmd=run loaduimage; run loadfdt; run mmcargs; bootz 0x80200000 - 0x815f0000
to:
then it'll load the flattened device tree file..
"RobertCNelson" Ubuntu scripts for BeagleBone? I searched around the Wiki,
but could not find any mention of micro SD card requirements. If not--is
Thanks for your help, Robert! But I get the same behavior using your automatic build scripts from the Wiki as well. One card works fine while the other doesn’t boot correctly (the four USER LEDs stay lit solid). I’m not changing anything in the automatic build process–just the micro SD card I’m using.
Can you please be a little more specific, just stating "automatic
build scripts" doesn't tell me anything that your trying to do.. As i
maintain a lot of scripts..
So based on the limited info, i'd say you didn't correctly setup the
second sd card.. "sudo fdisk -l" of it and a dump of uEnv.txt would
allow me to give you hint..
To clarify, I am just trying to use the setup_sdcard.sh script, for now. (http://elinux.org/BeagleBoardUbuntu#Raring_13.04_armhf). I have tried with both the --uboot bone and --uboot bone_dtb options. Both options produce a working image on one card, and a non-working image on the other.
Your absolutely right about the uEnv.txt file not looking right. On the PNY flash drive that I haven’t been able to get working, my uEnv.txt file seems to be corrupted. (Opening in nano, I get something like “^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^”, which gets repeated many times) Its also worth noting that when I insert this flash drive into my laptop, I get a “Unable to mount rootfs” pop-up message that doesn’t appear with I insert the working micro SD card.
Nothing else is changing between my attempts with one card and the other except for the card, itself.
Many thanks!
sudo fdisk -l for the “bad” card:
mdarling@mdarling:~$ sudo fdisk -l /dev/sdb
Disk /dev/sdb: 16.0 GB, 16012804096 bytes
64 heads, 32 sectors/track, 15271 cylinders, total 31275008 sectors
Units = sectors of 1 * 512 = 512 bytes
Disk identifier: 0x000557d5
Device Boot Start End Blocks Id System
/dev/sdb1 * 2048 133119 65536 e W95 FAT16 (LBA)
/dev/sdb2 133120 31275007 15570944 83 Linux
I have Kernel 3.8 in which I’m facing problems related to some library working because the libraries were designed for the kernel 3.2 ,can you guide me a bit Please on getting 3.2 kernel on the BBBLack?
